Hardware accelerated encoding using gstreamer within a docker container
I can do GPU encoding with the multimedia reference image using the gstreamer plugin v4l2h264enc. However, none of the example containers from the toradex documentation nor gstreamer example container have gstreamer v4l2h264enc. I have also tried installing the gstreamer1.0-plugins-good-imx package on the wayland-base-vivante:2 container. Currently streaming using the x264enc in a docker container results in maxed out CPU loads. How can I install imx’s v4l2h264enc in a docker container?
HW: Apalis iMX8 QuadMax 4GB
Greetings @joshua,
Can you share what version of TorizonCore you are using. Given this I’ll go ahead and take a look at this on my side.
Hi Jeremias,
We built the multimedia reference image following the online instructions except with the addition of docker.
root@apalis-imx8-07307976:~# uname -a
Linux apalis-imx8-07307976 5.4.193-5.7.1-devel+git.f78299297185 #1 SMP PREEMPT Mon Jul 11 14:42:03 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
Joshua
I now successfully built the docker container following these instructions.
I had to use docker buildx build --platform linux/arm64 to build it as I am on a linux/amd64 system. However, v4l2h264enc still doesn’t work inside the docker container with the following error message.
root@apalis-imx8-07307976:/gst-plugin-pylon# gst-launch-1.0 videotestsrc ! v4l2h264enc ! fakesink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Redistribute latency...
ERROR: from element /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0: Device '/dev/video13' does support non-contiguous planes
Additional debug info:
../sys/v4l2/gstv4l2object.c(4012): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0:
Device wants 2 planes
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
ERROR: from element /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0: Could not get/set settings from/on resource.
../sys/v4l2/gstv4l2object.c(3462): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0:
Device is in streaming mode
Freeing pipeline ...
Running v4l2-ctl --info shows:
root@apalis-imx8-07307976:/gst-plugin-pylon# v4l2-ctl --info
Driver Info:
	Driver name      : mxc-jpeg decode
	Card type        : mxc-jpeg decoder
	Bus info         : platform:58400000.jpegdec
	Driver version   : 5.4.193
	Capabilities     : 0x84204000
		Video Memory-to-Memory Multiplanar
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04204000
		Streaming
		Extended Pix Format
I was able to reproduce your results on my side as well. After some looking around I noticed this message in our Gstreamer article:
VPU is not yet supported on Torizon.
This may at least partially explain the issue here. Though let me double-check with our team internally to make sure this is still accurate.
After consulting with our team internally I was able to come up with something. So first of all to get v4l2h264enc working you need to use the downstream gstreamer packages as detailed here: How to use Gstreamer on Torizon OS | Toradex Developer Center
Once I did that pipelines with v4l2h264enc were now working:
root@e903a1fbbb7c:/# gst-launch-1.0 videotestsrc ! v4l2h264enc ! fakesink
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:09.151688780
Setting pipeline to READY ...
root@e903a1fbbb7c:/# gst-launch-1.0 videotestsrc num-buffers=150 ! video/x-raw, width=640, height=480 ! v4l2h264enc ! filesink location=test.h264
Got EOS from element "pipeline0".
Execution ended after 0:00:01.051328730
root@e903a1fbbb7c:/# gst-launch-1.0 filesrc location=test.h264 ! h264parse ! v4l2h264dec ! autovideosink
Execution ended after 0:00:04.999721924
Total showed frames (150), playing for (0:00:05.000571542), fps (29.997).
Now all that said the team did confirm accelerated VPU support was still not complete. So even with this I’m not sure if you will get the performance you were looking for.
Hi Jeremias,
Sorry for the delayed response. I was able to successfully follow those instructions and got a container with gpu accelerated encoding. Thank you. What is the best way to monitor the gpu usage? I have tried the gputop container and the numbers just show all 0’s.
Running cat /proc/cmdline shows galcore.powerManagement=0 galcore.showArgs=1 galcore.gpuProfiler=1
Thanks,
Joshua
Try using the arrow keys to move over some pages you can see more usage statistics that way. Though as I said before we don’t have gstreamer VPU hardware accelerated yet so I’m unsure if you’ll see any hardware activity from this in the tool here.
