GUI Desktop on verdin-imx8mp-
Hello, I’m actullay trying to acess the webacm on verdin-imx8mp using OpenCv I want to show the frames captured by Webcam on screen .
Also, Is it possible to have a desktop for this board like Raspberry has Raspbian desktop for its all Pi models?
To access the webcam on the Verdin iMX8M Plus using OpenCV and display the frames on the screen, you can utilize the GStreamer framework, which is pre-installed in the Reference Multimedia Image. You can use GStreamer to capture video from the webcam and then process it with OpenCV to display the frames.
Regarding having a desktop environment similar to Raspbian on Raspberry Pi, you can use Torizon, which is a Linux-based operating system provided by Toradex. Torizon supports running applications in containers, and you can install a desktop environment within a container using Debian packages. This setup allows you to have a graphical user interface on the Verdin iMX8M Plus.
For more detailed instructions, you might want to refer to the Toradex documentation on setting up a graphical environment and using GStreamer with OpenCV.
Use NPU with yolov5 on iMX8MP - NXP Community.
Hi @atharva.s
Are you using Torizon OS?
We also have a gstreamer capture example on our samples repo for Torizon
Sadly we don’t have a Desktop, like a personal computer, environment. Our main focus is on Torizon OS, which is based on containers for easy deployment and updates.
https://www.toradex.com/torizon
Thanks Allan. can you suggest me how can I show a GUI as I aim to capture the image from webcam and display it using computer vision alogos?
Hi @atharva.s
If you just want to capture the image and see it on the screen, the example from the sample should do exaclty that.
If you want to develop a GUI, we have this article with a great overview of GUI and some of the most commonly used frameworks.
