Hi ,
We are using tdx-reference-multimedia-image for Apalis iMX8. We are using Yocto Project dunfell to build this image.
How to add "apt install " packages as a part of yocto build.
Following two steps added:
EXTRA_IMAGE_FEATURES ?= “debug-tweaks package-management”
PACKAGE_CLASSES ?= " package_deb"`
After $ bitbake tdx-reference-multimedia-image
Error Like:
ERROR: Nothing RPROVIDES ‘debug-tweaks’
NOTE: Runtime target ‘debug-tweaks’ is unbuildable, removing…
Missing or unbuildable dependency chain was: [‘debug-tweaks’]
ERROR: Required build target ‘nhp-image’ has no buildable providers.
Missing or unbuildable dependency chain was: [‘nhp-image’, ‘debug-tweaks’]
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Please suggest how to add an apt install package for yocto build.
Deepak Jewargi
Hi @djewargi ,
Please note with Yocto BSP only opkg is supported, also we do not maintain any online feeds for same. That said please check below community post if this helps
Thanks @RudolfStreif ,
it worked, now update is happening good, but while running
$apt-get upgrade
I’m facing this issue
root@colibri-imx6-10909128:~# apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages have been kept back:
attr automake base-files base-passwd bash-completion bonnie++ cpp evtest file g++ gawk gcc hostapd libattr1 libcap-dev libcrypt-dev libgmp-dev…
Also you can check our TorizonCore OS where you can use Debian package manager inside docker container.
Torizon is an Easy-to-Use Industrial Linux Platform, that simplifies the development and maintenance of Linux devices. The Torizon's primary component is Torizon OS: a minimal embedded Linux image featuring, among other essential services, a...
Ritesh Kumar
