U-Boot 2020.07-5.7.2+git.d7ac31a7e7ac (Feb 15 2023 - 08:17:15 +0000)
CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 49C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 1, FSL_SDHC: 0
Loading Environment from MMC… OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB (eMMC) V1.1B, Serial# 14989988
SEC0: RNG instantiated
Net: eth0: ethernet@30be0000
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1…
Found U-Boot script /boot.scr
5962 bytes read in 14 ms (415 KiB/s)
Executing script at 87000000
Loading DeviceTree: imx7d-colibri-emmc-eval-v3.dtb
66361 bytes read in 17 ms (3.7 MiB/s)
52 bytes read in 10 ms (4.9 KiB/s)
Applying Overlay: colibri-imx7_lcd-lt170410_overlay.dtbo
1672 bytes read in 25 ms (64.5 KiB/s)
7034616 bytes read in 228 ms (29.4 MiB/s)
Bootargs: root=PARTUUID=a9d77350-02 ro rootwait console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:1280x800M-16@60
Kernel image @ 0x81000000 [ 0x000000 - 0x6b56f8 ]
Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Loading Device Tree to 8fecc000, end 8fefffff … OK
Starting kernel …
[ 0.000000] Linux version 5.4.193-5.7.2+git.b60d3160fd04 (oe-user@oe-host) (gcc version 9.5.0 (GCC)) #1 SMP Fri Dec 23 15:47:24 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Colibri iMX7D 1GB (eMMC) on Colibri Evaluation Board V3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 192 MiB at 0xb4000000
[ 0.000000] percpu: Embedded 15 pages/cpu s31692 r8192 d21556 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259328
[ 0.000000] Kernel command line: root=PARTUUID=a9d77350-02 ro rootwait console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:1280x800M-16@60
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 823960K/1045504K available (9216K kernel code, 506K rwdata, 3068K rodata, 1024K init, 392K bss, 24936K reserved, 196608K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000008] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000020] Switching to timer-based delay loop, resolution 125ns
[ 0.000319] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000346] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001572] arch_timer: multiple nodes in dt, skipping
[ 0.001896] Console: colour dummy device 80x30
[ 0.002263] printk: console [tty1] enabled
[ 0.002300] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.002333] pid_max: default: 32768 minimum: 301
[ 0.002485] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002518] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003319] CPU: Testing write buffer coherency: ok
[ 0.004157] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.004304] rcu: Hierarchical SRCU implementation.
[ 0.007428] smp: Bringing up secondary CPUs …
[ 0.008265] smp: Brought up 1 node, 2 CPUs
[ 0.008291] SMP: Total of 2 processors activated (32.00 BogoMIPS).
[ 0.008308] CPU: All CPU(s) started in SVC mode.
[ 0.008762] devtmpfs: initialized
[ 0.020113] random: get_random_u32 called from bucket_table_alloc+0x58/0x14c with crng_init=0
[ 0.020554] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.020843] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020888] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.028914] pinctrl core: initialized pinctrl subsystem
[ 0.030142] NET: Registered protocol family 16
[ 0.036164] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.037381] cpuidle: using governor menu
[ 0.044617] vdd1p0d: Bringing 0uV into 800000-800000uV
[ 0.044889] vdd1p0d: supplied by regulator-dummy
[ 0.045385] vdd1p2: supplied by regulator-dummy
[ 0.048641] DDR type is DDR3!
[ 0.056329] imx7d_enet_clk_sel: fec1: failed to get enet_out clock, assuming ext. clock source
[ 0.056386] imx7d_enet_clk_sel: fec2: found enet_out clock, assuming internal clock source
[ 0.056545] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.056572] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.057025] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.057713] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.059722] imx mu driver is registered.
[ 0.060271] imx rpmsg driver is registered.
[ 0.061637] MU is ready for cross core communication!
[ 0.079232] GPIO line 45 (LVDS_COLOR_MAP) hogged as output/low
[ 0.086762] GPIO line 203 (LVDS_POWER_ON) hogged as output/high
[ 0.086805] GPIO line 195 (LVDS_CH_MODE) hogged as output/high
[ 0.086832] GPIO line 194 (LVDS_RGB_MODE) hogged as output/low
[ 0.089666] reg-fixed-voltage regulator-module-3v3-eth: Failed to register regulator: -517
[ 0.090539] regulator-usbh-vbus GPIO handle specifies active low - ignored
[ 0.090752] VCC_USB[1-4]: supplied by 5V
[ 0.091502] SCSI subsystem initialized
[ 0.091778] usbcore: registered new interface driver usbfs
[ 0.091846] usbcore: registered new interface driver hub
[ 0.091907] usbcore: registered new device driver usb
[ 0.092056] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.092266] usb_phy_generic usbphynop3: usbphynop3 supply vcc not found, using dummy regulator
[ 0.092592] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.093925] i2c i2c-0: IMX I2C adapter registered
[ 0.094692] i2c i2c-3: IMX I2C adapter registered
[ 0.094909] videodev: Linux video capture interface: v2.00
[ 0.094987] pps_core: LinuxPPS API ver. 1 registered
[ 0.095005] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.095045] PTP clock support registered
[ 0.095352] Advanced Linux Sound Architecture Driver Initialized.
[ 0.096758] clocksource: Switched to clocksource arch_sys_counter
[ 0.096933] VFS: Disk quotas dquot_6.6.0
[ 0.097023] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.105736] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.106130] NET: Registered protocol family 2
[ 0.106345] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.107455] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.107508] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.107614] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.107769] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.107886] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.107956] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.108144] NET: Registered protocol family 1
[ 0.108679] RPC: Registered named UNIX socket transport module.
[ 0.108707] RPC: Registered udp transport module.
[ 0.108723] RPC: Registered tcp transport module.
[ 0.108738] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.109496] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.110660] Bus freq driver module loaded
[ 0.111678] Initialise system trusted keyrings
[ 0.111890] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 0.118269] NFS: Registering the id_resolver key type
[ 0.118319] Key type id_resolver registered
[ 0.118335] Key type id_legacy registered
[ 0.118361] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.118381] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.119055] Key type cifs.idmap registered
[ 0.119083] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.119533] fuse: init (API version 7.31)
[ 0.163637] Key type asymmetric registered
[ 0.163664] Asymmetric key parser ‘x509’ registered
[ 0.163697] io scheduler mq-deadline registered
[ 0.163714] io scheduler kyber registered
[ 0.170896] mxsfb 30730000.lcdif: 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.171131] fbcvt: 1280x800@60: CVT Name - 1.024MA
[ 0.171158] mxsfb 30730000.lcdif: Using timings from kernel parameters
[ 0.249731] Console: switching to colour frame buffer device 160x50
[ 0.266648] mxsfb 30730000.lcdif: initialized
[ 0.269186] mxs-dma 33000000.dma-apbh: initialized
[ 0.271349] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 56, base_baud = 1500000) is a IMX
[ 1.045855] printk: console [ttymxc0] enabled
[ 1.051013] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 57, base_baud = 1500000) is a IMX
[ 1.060542] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 58, base_baud = 1500000) is a IMX
[ 1.078750] loop: module loaded
[ 1.102416] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.109158] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.114870] ehci-fsl: Freescale EHCI Host controller driver
[ 1.120755] usbcore: registered new interface driver usb-storage
[ 1.128918] imx_usb 30b10000.usb: No over current polarity defined
[ 1.135583] imx_usb 30b20000.usb: No over current polarity defined
[ 1.144798] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.149869] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.186780] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.196327] hub 1-0:1.0: USB hub found
[ 1.203280] hub 1-0:1.0: 1 port detected
[ 1.215368] rtc-ds1307 3-0068: registered as rtc0
[ 1.224231] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.233832] i2c /dev entries driver
[ 1.242046] IR NEC protocol handler initialized
[ 1.249780] IR RC5(x/sz) protocol handler initialized
[ 1.257976] IR RC6 protocol handler initialized
[ 1.265613] IR JVC protocol handler initialized
[ 1.273227] IR Sony protocol handler initialized
[ 1.280904] IR SANYO protocol handler initialized
[ 1.288676] IR Sharp protocol handler initialized
[ 1.296357] IR MCE Keyboard/mouse protocol handler initialized
[ 1.305235] IR XMP protocol handler initialized
[ 1.314925] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.324719] sdhci: Secure Digital Host Controller Interface driver
[ 1.333934] sdhci: Copyright(c) Pierre Ossman
[ 1.341295] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.351606] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[ 1.392593] mmc1: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 1.431425] mmc0: SDHCI controller on 30b60000.usdhc [30b60000.usdhc] using ADMA
[ 1.444085] caam 30900000.caam: RNG4 SH0 was previously instantiated without prediction resistance. Tearing it down
[ 1.457852] caam 30900000.caam: Deinstantiated RNG4 SH0
[ 1.466319] caam 30900000.caam: Instantiated RNG4 SH0
[ 1.474549] caam 30900000.caam: RNG4 SH1 was previously instantiated without prediction resistance. Tearing it down
[ 1.488392] caam 30900000.caam: Deinstantiated RNG4 SH1
[ 1.525738] caam 30900000.caam: Instantiated RNG4 SH1
[ 1.534005] caam 30900000.caam: device ID = 0x0a16030000000000 (Era 8)
[ 1.543725] caam 30900000.caam: job rings = 3, qi = 0
[ 1.560828] caam algorithms registered in /proc/crypto
[ 1.570381] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 1.580802] caam 30900000.caam: registering rng-caam
[ 1.589237] Device caam-keygen registered
[ 1.599811] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.608512] usbcore: registered new interface driver usbhid
[ 1.617127] usbhid: USB HID core driver
[ 1.630761] coresight etm0: ETM 3.5 initialized
[ 1.633724] mmc0: new HS200 MMC card at address 0001
[ 1.638776] coresight etm1: ETM 3.5 initialized
[ 1.647152] mmcblk0: mmc0:0001 S40004 3.64 GiB
[ 1.658458] fsl-sai 308a0000.sai: failed to get mclk0 clock: -2
[ 1.661790] mmcblk0boot0: mmc0:0001 S40004 partition 1 4.00 MiB
[ 1.675192] NET: Registered protocol family 10
[ 1.679740] mmcblk0boot1: mmc0:0001 S40004 partition 2 4.00 MiB
[ 1.696220] mmcblk0rpmb: mmc0:0001 S40004 partition 3 4.00 MiB, chardev (248:0)
[ 1.696360] Segment Routing with IPv6
[ 1.713796] NET: Registered protocol family 17
[ 1.717250] mmcblk0: p1 p2
[ 1.721509] Bridge firewalling registered
[ 1.734373] 8021q: 802.1Q VLAN Support v1.8
[ 1.741869] tsn generic netlink module v1 init…
[ 1.749871] Key type dns_resolver registered
[ 1.764088] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 2 mkt segment 1 supported-hw 0x4 0x2
[ 1.767185] random: fast init done
[ 1.777372] Registering SWP/SWPB emulation handler
[ 1.790174] registered taskstats version 1
[ 1.796868] Loading compiled-in X.509 certificates
[ 1.835272] +V3.3_ETH: supplied by LDO1
[ 1.844591] pps pps0: new PPS source ptp0
[ 1.855498] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.864420] imx_usb 30b10000.usb: No over current polarity defined
[ 1.876997] usbmisc_imx 30b10200.usbmisc: vbus is error
[ 1.884803] usbmisc_imx 30b10200.usbmisc: Error occurs during detection: -22
[ 1.886082] crng init done
[ 1.900632] imx_thermal tempmon: Extended Commercial CPU temperature grade - max:105C critical:105C passive:95C
[ 1.916267] input: gpio-keys as /devices/soc0/gpio-keys/input/input0
[ 1.928578] rtc-ds1307 3-0068: setting system clock to 2023-08-31T02:31:31 UTC (1693449091)
[ 1.954122] ALSA device list:
[ 1.960582] No soundcards found.
[ 1.977114] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.988711] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.002159] devtmpfs: mounted
[ 2.009173] Freeing unused kernel memory: 1024K
[ 2.016563] Run /sbin/init as init process
[ 2.144241] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 2.174381] systemd[1]: Detected architecture arm.
Welcome to TDX Wayland with XWayland 5.7.2+build.21 (dunfell)!
[ 2.230325] systemd[1]: Set hostname to .
[ 2.678062] systemd[1]: /lib/systemd/system/gpsd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/gpsd.sock → /run/gpsd.sock; please update the unit file accordingly.
[ 2.748479] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 2.787984] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 2.827732] systemd[1]: Created slice system-weston.slice.
[ OK ] Created slice system-weston.slice.
[ 2.867805] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 2.907208] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 2.947239] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 2.987229] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 3.027007] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 3.067046] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.106987] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 3.147030] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.204853] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 3.247315] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 3.291140] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 3.327399] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 3.386219] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 3.399006] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.437707] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.478026] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.517484] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.557415] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.597629] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.613056] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.660661] systemd[1]: Mounting Kernel Debug File System…
[ 3.703451] systemd[1]: Mounting Temporary Directory (/tmp)…
[ 3.751484] systemd[1]: Starting Create list of static device nodes for the current kernel…
Starting Create list of st…odes for the current kernel…
[ 3.800784] systemd[1]: Starting RPC Bind…
Starting RPC Bind…
[ 3.839730] systemd[1]: Starting File System Check on Root Device…
[ 3.882861] systemd[1]: Starting Journal Service…
[ 3.902923] systemd[1]: Starting Load Kernel Modules…
[ 3.916361] systemd[1]: Starting udev Coldplug all Devices…
[ 3.934038] systemd[1]: Started RPC Bind.
[ OK [ 3.942138] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.953164] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted 3.963768] systemd[1]: Mounted Temporary Directory (/tmp).
1;39mPOSIX Message Queue File Sys[ 3.975808] systemd[1]: Started Create list of static device nodes for the current kernel.
tem.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[ 4.014997] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Load Kernel Modules.
Mounting FUSE Control File System…
Mounting Kernel Configuration File System…
Starting Apply Kernel Variables…
[ OK ] Started File System Check on Root Device.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
Starting Remount Root and Kernel File Systems…
[ 4.354408] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage…
[ 4.430805] systemd-journald[178]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev…
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile…
Starting udev Wait for Complete Device Initialization…
Starting udev Kernel Device Manager…
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed…
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Created slice system-systemd\x2dbacklight.slice.
[ 5.130375] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
Starting Load/Save Screen …ness of backlight:backlight…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Load/Save Screen B…htness of backlight:backlight.
[ 5.328513] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 5.444203] debugfs: Directory ‘308a0000.sai’ with parent ‘imx7-sgtl5000’ already present!
[ OK ] Started Network Time Synchronization.
[ 5.468048] asoc-simple-card sound: sgtl5000 ↔ 308a0000.sai mapping ok
[ 5.520035] imx-sdma 30bd0000.sdma: loaded firmware 4.5
[ 5.575797] spi_imx 30840000.spi: probed
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[ 6.107562] CAN device driver interface
[ 6.155542] mcp251x spi2.0: Cannot initialize MCP2515. Wrong wiring?
[ 6.164745] mcp251x spi2.0: Probe failed, err=19
[ 6.402205] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on GPS (Global P…ioning System) Daemon Sockets.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Save/Restore Sound Card State…
[ OK ] Started Kernel Logging Service.
[ OK ] Started System Logging Service.
[ OK ] Started D-Bus System Message Bus.
Starting IPv6 Packet Filtering Framework…
Starting IPv4 Packet Filtering Framework…
Starting Telephony service…
Starting Login Service…
[ OK ] Started Timestamping service.
Starting Load default [ 7.235009] Bluetooth: Core ver 2.22
USB gadget schema g1.schema…
[ OK ] Started Save/Restore[ 7.257842] NET: Registered protocol family 31
Sound Card State.
[ 7.265634] Bluetooth: HCI device and connection manager initialized
[ 7.279256] using random self ethernet address
[ 7.281512] Bluetooth: HCI socket layer initialized
[ 7.286305] using random host ethernet address
[ 7.294390] Bluetooth: L2CAP socket layer initialized
[ OK [ 7.315931] Bluetooth: SCO socket layer initialized
] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Reached target Network (Pre).
[ OK ] Reached target Sound Card.
Starting Connection service…
[ OK ] Started Telephony service.
[ 7.551284] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 7.558348] usb0: MAC 00:14:2d:ff:ff:ff
[ OK ] Started Load default USB gadget schema g1.schema.
[ OK ] Started Connection service.
[ OK ] Reached target Hardware activated USB gadget.
Starting Avahi mDNS/DNS-SD Stack…
Starting Network Service…
[ OK ] Started Login Service.
[ 7.731544] Micrel KSZ8041 30be0000.ethernet-1:00: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.ethernet-1:00, irq=POLL)
[ 7.741041] configfs-gadget gadget: high-speed config #1: c
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Hostname Service…
Starting WPA supplicant…
[ OK ] Started Network Service.
[ OK ] Started WPA supplicant.
[ OK ] Reached target Network.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions…
[ OK ] Started Permit User Sessions.
[ OK ] Started Hostname Service.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Reached target Login Prompts.
[ OK ] Started Weston Wayland Compositor.
Starting Start a wayland application…
[ OK ] Created slice User Slice of UID 0.
Starting User Runtime Directory /run/user/0…
[ OK ] Started User Runtime Directory /run/user/0.
Starting User Manager for UID 0…
[ 8.636799] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ OK ] Started User Manager for UID 0.
[ OK ] Started Session c1 of user root.
[ 9.837585] fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 9.845557] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ OK ] Started Start a wayland application.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
