i need the AzureWave AW-CM276NF to enable ap mode and with the ip i have to open a flask server using python and after that i hav to enable the device to be in station mode using ssid’s and password. eanbling both simultaneously usiong connman only and hostapd
Hello!
To configure your AzureWave AW-CM276NF module to operate in both access point (AP) mode and station mode while running a Flask server, you can follow these steps on your Toradex device:
Setting Up AP Mode
Install Required Packages: Make sure
hostapdandConnManare installed on your system. You can typically install these using your package manager. -
Configure
hostapd:- Create a configuration file for
hostapd(e.g.,/etc/hostapd/hostapd.conf). - Example configuration:
interface=wlan0 driver=nl80211 ssid=YourAPSSID hw_mode=g channel=6 wmm_enabled=0 macaddr_acl=0 auth_algs=1 ignore_broadcast_ssid=0 wpa=2 wpa_passphrase=YourPassphrase wpa_key_mgmt=WPA-PSK rsn_pairwise=CCMP
Start
hostapd:- Run
hostapd /etc/hostapd/hostapd.confto start the AP.
- Run
Running a Flask Server
Install Flask: Use pip to install Flask (
pip install Flask). -
Create a Flask Application:
- Write a simple Flask app (e.g.,
app.py):from flask import Flask app = Flask(__name__) @app.route('/') def hello_world(): return 'Hello, World!' if __name__ == '__main__': app.run(host='0.0.0.0')
Run the Flask Server:
- Execute
python app.pyto start the server, accessible via the AP’s IP address.
- Execute
Switching to Station Mode
- Use ConnMan:
- First, stop
hostapdto disable AP mode. - Use
connmanctlto connect to a Wi-Fi network:connmanctl connmanctl> enable wifi connmanctl> scan wifi connmanctl> services connmanctl> agent on connmanctl> connect wifi_<hash>_managed_psk connmanctl> quit - Replace
<hash>with the actual hash of your network.
- First, stop
By following these steps, you can successfully configure your device to switch between AP and station modes while running a Flask server. Make sure to adjust configurations to fit your specific network and security needs.
This topic is being answered here.
