I have installed TorizonCore 6.3 through Toradex Easy Installer on iMX8QM on Ixora Board. Now, I want to downgrade to TorizonCore 5.7. Since the Toradex Easy Installer is removed after successful installation, I cannot use the same approach. I could not find any articles about this.
What would be the approach and steps to downgrade in my case?
Hello @hajili ,
From this article in the developer webpage:
If your module already has an Operating System flashed: If your module already have an Operating System and you want to install another OS, you can download an Easy Installer image and load Toradex Easy Installer into the module’s RAM through a host computer over USB OTG. See the Load Toradex Easy Installer article for instructions.
You can put your board in recovery mode, as explained here:
That will put Toradex Easy Installer in RAM, and then install another compatible version of TorizonCore, reference image or custom build.
Hello @hajili ,
Can you share the full name and version of the module that you have , as well as the version of Toradex Easy Installer that you are using?
One way to downgrade the OS would be through the recovery mode procedure (where you will put the module in recovery mode, flash Toradex Easy Installer, and then install the image version that you want from the feeds). However, since you have TorizonCore, you could simplify this whole procedure of upgrading/downgrading your device through the Torizon Platform. I would highly recommend you take a look at it.
The Toradex Quickstart guide walks you through some of the basic features of the platform such as how to provision your device on the platform, deploying remote OS and Application updates, fleet management, etc. You will find more about how to do the remote OS update here: Updating the Operating System with Torizon Cloud | Toradex Developer Center
In the meantime, I will try with your HW versions to see if I can reproduce the issue with the recovery mode procedure. I’ll keep you posted.
So I tried to reproduce this issue with the flashing of the easy installer getting stuck on the Apalis iMX8QM V1.1E module (I have a Linux PC, unfortunately, don’t have a windows PC here). For me, it just worked fine. Could you please connect to the serial console before you run the recovery script and see if it finishes the flashing of the easy installer? This will help to see if the script has actually been executed successfully.
On successful installation on Toradex Easy Installer, it should print out the following (as you see in the image below) on the serial console:
