I am trying to set the resolution of 7inch capacitive touch display for reference multimedia image to 800x480. If I use
fw_setenv fw_setenv vidargs video=mxcfb0:dcd,800x480M@60
it shows up in fw_printenv but has no effect. Here is the fw_printenv output -
arch=arm
baudrate=115200
board=colibri-imx6ull
board_name=colibri-imx6ull
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc0 usb0 dhcp
bootcmd=run ubiboot || run distro_bootcmd;
bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z “${fdtfile}” -a -n “${soc}”; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_usb0=devnum=0; run usb_boot
bootdelay=1
bootm_size=0x10000000
console=ttymxc0
cpu=armv7
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x88200000
fdt_board=eval-v3
ipaddr=192.168.10.2
kernel_addr_r=0x84200000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x84200000
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mtdids=nand0=gpmi-nand
mtdparts=mtdparts=gpmi-nand:512k(mx6ull-bcb),1536k(u-boot1)ro,1536k(u-boot2)ro,512k(u-boot-env),-(ubi)
netmask=255.255.255.0
preboot=test -n ${fdtfile} || setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb
pxefile_addr_r=0x88300000
ramdisk_addr_r=0x88400000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}…; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then part uuid ${devtype} ${devnum}:${distro_bootpart} distro_bootpart_uuid ; run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z “${fdtfile}” -a -n “${soc}”; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing…; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo EXTLINUX FAILED: continuing…; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing…; fi; done
scriptaddr=0x88280000
serverip=192.168.10.1
setethupdate=if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; tftpboot ${loadaddr} ${board}/flash_eth.img && source ${loadaddr}
setsdupdate=mmc rescan && setenv interface mmc && fatload ${interface} 0:1 ${loadaddr} ${board}/flash_blk.img && source ${loadaddr}
setup=setenv setupargs console=tty1 console=${console},${baudrate}n8 ${memargs} ${mtdparts}
setupdate=run setsdupdate || run setusbupdate || run setethupdate
setusbupdate=usb start && setenv interface usb && fatload ${interface} 0:1 ${loadaddr} ${board}/flash_blk.img && source ${loadaddr}
soc=mx6
splashimage=0x84200000
splashpos=m,m
ubiargs=ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1
ubiboot=run setup; setenv bootargs ${ubiargs} ${setupargs} ${tdxargs}; echo Booting from NAND…; ubi part ubi &&ubi read ${kernel_addr_r} kernel && ubi read ${fdt_addr_r} dtb && bootz ${kernel_addr_r} - ${fdt_addr_r}
ubifs_boot=if ubi part ${bootubipart} ${bootubioff} && ubifsmount ubi0:${bootubivol}; then devtype=ubi; devnum=ubi0; bootfstype=ubifs; distro_bootpart=${bootubivol}; run scan_dev_for_boot; ubifsumount; fi
update_uboot=nand erase.part u-boot1 && nand write ${loadaddr} u-boot1 ${filesize} && nand erase.part u-boot2 && nand write ${loadaddr} u-boot2 ${filesize}
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=toradex
vidargs=video=mxcfb0:dcd,800x480M@60
videomode=video=ctfb:x:640,y:480,depth:18,pclk:39722,le:48,ri:16,up:33,lo:10,hs:96,vs:2,sync:0,vmode:0
Looks like videomode setup has the final effect of display resolution. How do I change this to get 800x480 resolution?
Thanks and Regards,
Mansij
