Hello all,
I am currently working on a device tree overlay to enable CAN on ecspi1 on a Verdin IMX8MM module. I have a custom carrier board which has a MCP25625 chip.
I am using a Toradex 6.2 as a base image, with the imx8mm-verdin-nonwifi-yavia device tree. Currently I am making a device tree overlay for our own board.
Below, the CAN section of the overlay is written down.
&ecspi1 {
#address-cells = <1>;
#size-cells = <0>;
cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1>;
spidev@0 {
/* Use compatible "rohm,dh2228fv" to bind spidev driver */
compatible = "rohm,dh2228fv";
reg = <0>;
spi-max-frequency = <10000000>;
can2: can@0 {
compatible = "microchip,mcp25625";
clocks = <&clk40m>;
interrupt-parent = <&gpio1>;
interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
// interrupts-extended = <&gpio1 0 IRQ_TYPE_LEVEL_LOW>;
reg = <0>;
spi-max-frequency = <8500000>;
The problem occurs in the line containing the interrupt pins. I can solve the syntax error by including the following file in the header: #include "imx8mm-pinfunc.h, but when I do this, the toradex module does not show any messages with regards to the SPI anymore. So this made me believe that this was not the good solution. However, I also do not know what I should do to avoid the syntax error.
Does anyone has an idea on how to solve this?
Kind regards,
Anouk
