I just build my first secure boot image and it is correctly deployed to the torizon cloud, but the naming on the torizon cloud packages view is pretty cumbersome.
see below:
Hello Richard,
Thank you for reaching out with your question. To change the package name when deploying to Torizon Cloud, you can use the TorizonCore Builder tool. This tool allows you to specify a custom name for your package using the --package-name argument during the signing and pushing process of your Torizon OS image or application package.
As for modifying the package description and tags, this is not something that can be done directly through Yocto configuration files. The Yocto Project is primarily focused on building and customizing the Torizon OS image itself, rather than managing metadata like package names, descriptions, or tags in Torizon Cloud.
For more detailed customization of package metadata, you would typically handle this through the TorizonCore Builder tool or directly within the Torizon Cloud interface after the package has been uploaded.
I hope this helps! If you have any more questions, feel free to ask.
If you want a different package name you can try setting this variable to something else. Then that should change the name of the package that gets uploaded to the cloud.
The tags as you can see are actually derived from the package name itself, so by changing the package name the tags will also modified.
For the package description this is something that can’t be changed from Yocto. This would need to either be changed in the Web UI. Or via API call to our server after the package has already been uploaded. The description is something that is specific to our Web UI/server implementation, which is why it can’t be easily changed from Yocto.
Thank you for the quick reply, i’ll check the Yocto variable.
In the meantime, is it also possible to change this data from the torizon web UI because i have not seen the option to do so, if this is the case then that would also solve the issue for me.
Once a package has been uploaded, it’s not possible to edit the name and version of the package. The package would need to be deleted and then re-uploaded with another name and version. This is because doing so may cause a lot of potential issues with our update framework which may cause updates to fail or get stuck in some cases.
As I said before though, the description of the package should be editable via the web UI.
I tried adding that line in my meta layer under recipe-images/image/my-image.bb (where I set the IMAGE_BASENAME) , but it doesn’t get applied.
Otherwise I tried adding it into conf/distro/my-distro.conf (where I set the DISTRO), but I got this error:
ERROR: Sota's config sanity checker detected a potential misconfiguration.
Please fix the cause of this error then you can continue to build.
Following is the list of potential problems / advisories:
OSTREE_BRANCHNAME Should only contain characters from the character set [a-zA-Z0-9._-].
Where should we set the variable OSTREE_BRANCHNAME in our custom meta-layer?
So to be clear I set it like this: OSTREE_BRANCHNAME:forcevariable = "foo".
That said the error you got suggests the value you were trying to set contains invalid characters. As stated by the error you got only alphanumeric characters plus the ., _, and - characters are valid for OSTREE_BRANCHNAME.
The sanity check in meta-updater/classes/sota_sanity.bbclass still causes an error.
The reason is the forward slash, which is not allowed. Is there a workaround for this?
Yet, we never got affected by this sanity check error. This seems to be an issue with the sanity-checker in meta-updater. For whatever reason, maybe due to precedence and ordering, it seems like the sanity checker does not check if the variable gets set in the distro configuration level, like in our case.
Secondly, and this is probably more relevant for you. The / should be allowed, we’ve been using this for years, and it’s a perfectly acceptable character in OSTree.
I suggest for now just overwrite the variable assignment in our meta-layer in the short term. Then maybe raise this with the maintainers of meta-updater to allow / characters, as they are valid.
