I have been getting CPU4 kernel panic interrupts during the shutdown process (see log below). The A72 speed has been reduced in an overlay for better runtime stability in hot environments. Is there something I’m missing?
Background: I throttled the A72 speed to 1.296 GHz (down from 1.596 GHz) to prevent lock-ups while running in a hot environment. This solved a problem of locking-up (and rebooting) during start-up, however there is an interrupt error that occurs while attempting a clean shut-down.
Modifications: The build includes the following overlay to reduce the CPU speed
a72_opp_table: a72-opp-table {
/delete-node/ opp-1596000000;
Log error:
2024-12-21T00:54:34.072Z Dec 21 00:54:33 pppd[2127]: Sent 159736 bytes, received 35649 bytes.
2024-12-21T00:54:34.072Z D[ 166.623178] SError Interrupt on CPU4, code 0xbf000002 -- SError
[ 166.623190] CPU: 4 PID: 35 Comm: kworker/4:0H Not tainted 5.15.77 #1
[ 166.623202] Hardware name: EMU 3 Apalis iMX8QM V1.1 (DT)
[ 166.623209] Workqueue: kblockd blk_mq_run_work_fn
[ 166.623239] pstate: 800000c5 (Nzcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 166.623251] pc : esdhc_readl_le+0xc/0x188
[ 166.623266] lr : sdhci_send_command+0x5dc/0xd10
[ 166.623279] sp : ffff8000097bb930
[ 166.623283] x29: ffff8000097bb930 x28: ffff00080198f7c8 x27: ffff000801947000
[ 166.623300] x26: ffff00080003b000 x25: 0000000000000000 x24: 0000000000000000
[ 166.623313] x23: ffff00080198f948 x22: ffff800009022000 x21: 0000000000000003
[ 166.623325] x20: ffff00080198f948 x19: ffff00080003b580 x18: ffff800009022b08
[ 166.623337] x17: 0000000000000000 x16: 0000000000000001 x15: 0000000000002000
[ 166.623349] x14: 0000000000000000 x13: ffff0008019bb200 x12: 0000000000000000
[ 166.623362] x11: 000000088fd3f000 x10: ffff8000097bb958 x9 : 0000000000000e43
[ 166.623374] x8 : 0000000000002000 x7 : 0000000000001000 x6 : ffff0008019bb200
[ 166.623386] x5 : ffff00080003b810 x4 : 0000000000000000 x3 : ffff00080003b810
[ 166.623398] x2 : 0000000000000008 x1 : 0000000000000024 x0 : ffff00080003b580
[ 166.623415] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 166.623421] CPU: 4 PID: 35 Comm: kworker/4:0H Not tainted 5.15.77 #1
[ 166.623431] Hardware name: EMU 3 Apalis iMX8QM V1.1 (DT)
[ 166.623435] Workqueue: kblockd blk_mq_run_work_fn
[ 166.623449] Call trace:
[ 166.623452] dump_backtrace+0x0/0x1b0
[ 166.623468] show_stack+0x14/0x58
[ 166.623480] dump_stack_lvl+0x64/0x7c
[ 166.623492] dump_stack+0x14/0x2c
[ 166.623500] panic+0x15c/0x364
[ 166.623508] add_taint+0x0/0xb0
[ 166.623520] arm64_serror_panic+0x68/0x78
[ 166.623528] do_serror+0x24/0x58
[ 166.623534] el1h_64_error_handler+0x30/0x48
[ 166.623549] el1h_64_error+0x74/0x78
[ 166.623557] esdhc_readl_le+0xc/0x188
[ 166.623567] sdhci_send_command_retry+0x44/0x1c0
[ 166.623579] sdhci_request+0xf4/0x140
[ 166.623590] __mmc_start_request+0x5c/0x140
[ 166.623602] mmc_start_request+0x80/0xa8
[ 166.623612] mmc_blk_mq_issue_rq+0x648/0xaf8
[ 166.623620] mmc_mq_queue_rq+0x1d4/0x330
[ 166.623628] blk_mq_dispatch_rq_list+0x124/0x940
[ 166.623642] blk_mq_do_dispatch_sched+0x2b4/0x318
[ 166.623652] __blk_mq_sched_dispatch_requests+0xf4/0x1d8
[ 166.623661] blk_mq_sched_dispatch_requests+0x34/0x70
[ 166.623670] __blk_mq_run_hw_queue+0x7c/0xa0
[ 166.623682] blk_mq_run_work_fn+0x20/0x28
[ 166.623692] process_one_work+0x15c/0x3c8
[ 166.623706] worker_thread+0x13c/0x548
[ 166.623717] kthread+0xf0/0x128
[ 166.623729] ret_from_fork+0x10/0x20
[ 166.623740] SMP: stopping secondary CPUs
[ 167.770801] SMP: failed to stop secondary CPUs 0,4
[ 167.770814] Kernel Offset: disabled
[ 167.770816] CPU features: 0x800820b1,20000842
[ 167.770823] Memory Limit: none
[ 168.033852] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
