Hi, I got a IMX8QM and a Ixora carrier board two days ago, from since I am trying to get HDMI output without success. I read here that HDMI should come pre-enabled in this module, but also I couldn’t find the apalis-imx8_hdmi_overlay.dtbo file in /boot/ostree/torizon-…/overlays. Also the overlays.txt file content is only “fdt_overlays=”, so I don’t know if I am understanding something wrong, or if it’s effectively not enabled at all.
I compiled the apalis-imx8_hdmi_overlay.dtbo manually, as explained here, and set overlays.txt to fdt_overlays=apalis-imx8_hdmi_overlay.dtbo, but the output I get from U-Boot is this:
U-Boot 2020.04-5.2.0-devel+git.586f79f64f6a (Jan 01 1970 - 00:00:00 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1B, Serial# 06738440
BuildInfo:
- SCFW 0d54291f, SECO-FW d63fdb21, IMX-MKIMAGE 8947fea3, ATF 7f1187b
- U-Boot 2020.04-5.2.0-devel+git.586f79f64f6a
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1007 bytes read in 12 ms (81.1 KiB/s)
## Executing script at 83100000
3849 bytes read in 21 ms (178.7 KiB/s)
166740 bytes read in 33 ms (4.8 MiB/s)
43 bytes read in 23 ms (1000 Bytes/s)
Applying Overlay: apalis-imx8_hdmi_overlay.dtbo
2049 bytes read in 34 ms (58.6 KiB/s)
failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND
12144143 bytes read in 290 ms (39.9 MiB/s)
Uncompressed size: 30507520 = 0x1D18200
9158067 bytes read in 231 ms (37.8 MiB/s)
ERROR: Did not find a cmdline Flattened Device Tree
Loading Ramdisk to fcd92000, end fd64ddb3 ... OK
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
This is sudo fbset output:
apalis-imx8-06738440:~$ sudo fbset
fbset: can't open '/dev/fb0': No such file or directory
This is dmesg output:
apalis-imx8-06738440:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.91-5.2.0-devel+git.a2bc7116a3fd (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1-TorizonCore SMP PREEMPT Thu Feb 4 16:40:01 UTC 2021
[ 0.000000] Machine model: Toradex Apalis iMX8QM/QP on Apalis Evaluation Board
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000096000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vdevbuffer, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080200000-0x00000008ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x8ff7c3500-0x8ff7c4fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080200000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x0000000086400000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000090000000-0x00000000901fffff]
[ 0.000000] node 0: [mem 0x0000000090500000-0x0000000091ffffff]
[ 0.000000] node 0: [mem 0x0000000094c00000-0x0000000094ffffff]
[ 0.000000] node 0: [mem 0x0000000095400000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000008ffffffff]
[ 0.000000] On node 0 totalpages: 993024
[ 0.000000] DMA32 zone: 7324 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 468736 pages, LIFO batch:63
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 33 pages/cpu s96984 r8192 d29992 u135168
[ 0.000000] pcpu-alloc: s96984 r8192 d29992 u135168 alloc=33*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 977508
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash ostree=/ostree/boot.1/torizon/b8dc4c5c34532da2b48ba7378de59d79582e277304451c82bd910e583def45fd/0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0xf8d92000-0xfcd92000] (64MB)
[ 0.000000] Memory: 2802120K/3972096K available (16188K kernel code, 1952K rwdata, 7612K rodata, 3968K init, 1174K bss, 186936K reserved, 983040K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 512 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] random: get_random_bytes called from start_kernel+0x318/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000003] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000714] Console: colour dummy device 80x25
[ 0.000725] printk: console [tty0] enabled
[ 0.000800] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.000808] pid_max: default: 32768 minimum: 301
[ 0.000885] LSM: Security Framework initializing
[ 0.000955] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000972] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002470] ASID allocator initialised with 32768 entries
[ 0.002546] rcu: Hierarchical SRCU implementation.
[ 0.007599] EFI services will not be available.
[ 0.007959] smp: Bringing up secondary CPUs ...
[ 0.008787] Detected VIPT I-cache on CPU1
[ 0.008816] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.008856] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.009672] Detected VIPT I-cache on CPU2
[ 0.009687] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.009704] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.010546] Detected VIPT I-cache on CPU3
[ 0.010560] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.010577] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.012206] CPU features: detected: EL2 vector hardening
[ 0.012218] CPU features: detected: Branch predictor hardening
[ 0.012224] Detected PIPT I-cache on CPU4
[ 0.012240] GICv3: CPU4: found redistributor 100 region 0:0x0000000051b80000
[ 0.012260] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.013045] Detected PIPT I-cache on CPU5
[ 0.013056] GICv3: CPU5: found redistributor 101 region 0:0x0000000051ba0000
[ 0.013068] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.013130] smp: Brought up 1 node, 6 CPUs
[ 0.013134] SMP: Total of 6 processors activated.
[ 0.013139] CPU features: detected: 32-bit EL0 Support
[ 0.013142] CPU features: detected: CRC32 instructions
[ 0.024023] CPU: All CPU(s) started at EL2
[ 0.024053] alternatives: patching kernel code
[ 0.025304] devtmpfs: initialized
[ 0.042429] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.042445] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.068003] pinctrl core: initialized pinctrl subsystem
[ 0.068784] NET: Registered protocol family 16
[ 0.075217] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.075229] audit: initializing netlink subsys (disabled)
[ 0.075397] audit: type=2000 audit(0.070:1): state=initialized audit_enabled=0 res=1
[ 0.075938] cpuidle: using governor ladder
[ 0.075952] cpuidle: using governor menu
[ 0.077419] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.079293] Serial: AMBA PL011 UART driver
[ 0.079337] imx mu driver is registered.
[ 0.079355] imx rpmsg driver is registered.
[ 0.130417] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.130423] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.130427] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.130430] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.131503] cryptd: max_cpu_qlen set to 1000
[ 0.136069] ACPI: Interpreter disabled.
[ 0.138418] iommu: Default domain type: Translated
[ 0.138532] vgaarb: loaded
[ 0.138871] SCSI subsystem initialized
[ 0.139049] libata version 3.00 loaded.
[ 0.139278] usbcore: registered new interface driver usbfs
[ 0.139312] usbcore: registered new interface driver hub
[ 0.139337] usbcore: registered new device driver usb
[ 0.141667] mc: Linux media interface: v0.10
[ 0.141691] videodev: Linux video capture interface: v2.00
[ 0.141760] pps_core: LinuxPPS API ver. 1 registered
[ 0.141763] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.141774] PTP clock support registered
[ 0.142140] EDAC MC: Ver: 3.0.0
[ 0.143869] No BMan portals available!
[ 0.144302] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[ 0.145088] No QMan portals available!
[ 0.146275] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 0.146764] FPGA manager framework
[ 0.146842] Advanced Linux Sound Architecture Driver Initialized.
[ 0.147728] Bluetooth: Core ver 2.22
[ 0.147753] NET: Registered protocol family 31
[ 0.147756] Bluetooth: HCI device and connection manager initialized
[ 0.147764] Bluetooth: HCI socket layer initialized
[ 0.147770] Bluetooth: L2CAP socket layer initialized
[ 0.147781] Bluetooth: SCO socket layer initialized
[ 0.149028] imx-scu scu: NXP i.MX SCU Initialized
[ 0.154376] random: fast init done
[ 0.194204] imx8qm-pinctrl scu:pinctrl: initialized IMX pinctrl driver
[ 0.198020] clocksource: Switched to clocksource arch_sys_counter
[ 0.493059] VFS: Disk quotas dquot_6.6.0
[ 0.493094] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.493832] pnp: PnP ACPI: disabled
[ 0.524711] thermal_sys: Registered thermal governor 'step_wise'
[ 0.524713] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.525205] NET: Registered protocol family 2
[ 0.525555] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.525588] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.525721] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.525994] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.526090] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.526142] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.526287] NET: Registered protocol family 1
[ 0.526574] RPC: Registered named UNIX socket transport module.
[ 0.526576] RPC: Registered udp transport module.
[ 0.526578] RPC: Registered tcp transport module.
[ 0.526580] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.526587] PCI: CLS 0 bytes, default 64
[ 0.526696] Trying to unpack rootfs image as initramfs...
[ 0.809438] Freeing initrd memory: 8940K
[ 0.810125] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.810973] kvm [1]: IPA Size Limit: 40bits
[ 0.811483] kvm [1]: vgic-v2@52020000
[ 0.811504] kvm [1]: GIC system register CPU interface enabled
[ 0.811606] kvm [1]: vgic interrupt IRQ1
[ 0.811723] kvm [1]: Hyp mode initialized successfully
[ 0.814912] Initialise system trusted keyrings
[ 0.814998] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.817470] NFS: Registering the id_resolver key type
[ 0.817488] Key type id_resolver registered
[ 0.817490] Key type id_legacy registered
[ 0.817497] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.817511] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
[ 0.826098] NET: Registered protocol family 38
[ 0.826107] Key type asymmetric registered
[ 0.826111] Asymmetric key parser 'x509' registered
[ 0.826134] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.826224] io scheduler mq-deadline registered
[ 0.826226] io scheduler kyber registered
[ 0.837000] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 0.838597] EINJ: ACPI disabled.
[ 0.944040] mxs-dma 5b810000.dma-apbh: initialized
[ 0.945246] Bus freq driver module loaded
[ 0.949717] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.952471] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 47, base_baud = 5000000) is a FSL_LPUART
[ 0.952765] fsl-lpuart 5a060000.serial: DMA tx channel request failed, operating without tx DMA
[ 0.952768] fsl-lpuart 5a060000.serial: DMA rx channel request failed, operating without rx DMA
[ 0.953034] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 48, base_baud = 5000000) is a FSL_LPUART
[ 0.953040] fsl-lpuart 5a070000.serial: Serial: Console lpuart rounded baud ratefrom 35971 to 115200
[ 0.960734] printk: console [ttyLP1] enabled
[ 0.961235] 5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 49, base_baud = 5000000) is a FSL_LPUART
[ 0.961475] fsl-lpuart 5a080000.serial: DMA tx channel request failed, operating without tx DMA
[ 0.961479] fsl-lpuart 5a080000.serial: DMA rx channel request failed, operating without rx DMA
[ 0.961819] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 50, base_baud = 5000000) is a FSL_LPUART
[ 0.963864] arm-smmu 51400000.iommu: probing hardware configuration...
[ 0.963869] arm-smmu 51400000.iommu: SMMUv2 with:
[ 0.963871] arm-smmu 51400000.iommu: stage 1 translation
[ 0.963874] arm-smmu 51400000.iommu: stage 2 translation
[ 0.963876] arm-smmu 51400000.iommu: nested translation
[ 0.963880] arm-smmu 51400000.iommu: stream matching with 32 register groups
[ 0.963889] arm-smmu 51400000.iommu: 32 context banks (0 stage-2 only)
[ 0.963894] arm-smmu 51400000.iommu: Supported page sizes: 0x61311000
[ 0.963896] arm-smmu 51400000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.963899] arm-smmu 51400000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 1.028349] imx-drm display-subsystem: parent device of /bus@57240000/ldb@572410e0/lvds-channel@0 is not available
[ 1.042371] brd: module loaded
[ 1.046672] loop: module loaded
[ 1.046890] zram: Added device: zram0
[ 1.050283] ahci-imx 5f020000.sata: Adding to iommu group 0
[ 1.050440] ahci-imx 5f020000.sata: can't get sata_ext clock.
[ 1.056510] imx ahci driver is registered.
[ 1.061945] libphy: Fixed MDIO Bus: probed
[ 1.063163] fec 5b040000.ethernet: Adding to iommu group 1
[ 1.064653] Freescale FM module, FMD API version 21.1.0
[ 1.065130] Freescale FM Ports module
[ 1.066067] VFIO - User Level meta-driver version: 0.3
[ 1.068553] cdns-usb3 5b110000.usb3: Adding to iommu group 2
[ 1.069501] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.069516] ehci-pci: EHCI PCI platform driver
[ 1.069561] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.070784] usbcore: registered new interface driver usb-storage
[ 1.070832] usbcore: registered new interface driver usbserial_generic
[ 1.070841] usbserial: USB Serial support registered for generic
[ 1.076128] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[ 1.079191] imx-sc-rtc scu:rtc: registered as rtc1
[ 1.080585] i2c /dev entries driver
[ 1.090101] sdhci: Secure Digital Host Controller Interface driver
[ 1.090105] sdhci: Copyright(c) Pierre Ossman
[ 1.090615] Synopsys Designware Multimedia Card Interface Driver
[ 1.091925] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.093121] sdhci-esdhc-imx 5b010000.mmc: Adding to iommu group 3
[ 1.093475] mmc0: CQHCI version 5.10
[ 1.124491] mmc0: SDHCI controller on 5b010000.mmc [5b010000.mmc] using ADMA
[ 1.126367] sdhci-esdhc-imx 5b020000.mmc: Adding to iommu group 3
[ 1.126786] mmc1: CQHCI version 5.10
[ 1.128582] sdhci-esdhc-imx 5b030000.mmc: Adding to iommu group 3
[ 1.128880] mmc2: CQHCI version 5.10
[ 1.139053] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.142426] caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
[ 1.142434] caam 31400000.crypto: job rings = 2, qi = 0
[ 1.153348] caam algorithms registered in /proc/crypto
[ 1.154913] caam 31400000.crypto: caam pkc algorithms registered in /proc/crypto
[ 1.154924] caam 31400000.crypto: registering rng-caam
[ 1.155253] Device caam-keygen registered
[ 1.160412] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.160592] usbcore: registered new interface driver usbhid
[ 1.160596] usbhid: USB HID core driver
[ 1.164383] random: crng init done
[ 1.168086] No fsl,qman node
[ 1.168093] Freescale USDPAA process driver
[ 1.168097] fsl-usdpaa: no region found
[ 1.168100] Freescale USDPAA process IRQ driver
[ 1.184838] [VPU Decoder] warning: init rtx channel failed, ret: -517
[ 1.184865] [VPU Decoder] failed to request mailbox, ret = -517
[ 1.188272] [VPU Encoder] warning: init rtx channel failed, ret: -517
[ 1.188280] [VPU Encoder] warning: init rtx channel failed, ret: -517
[ 1.188312] [VPU Encoder] fail to request mailbox, ret = -517
[ 1.190811] dvbdev: DVB: registering new adapter (PPM DVB adapter)
[ 1.191238] dvbdev: DVB: registering new adapter (PPM DVB adapter)
[ 1.192123] usbcore: registered new interface driver snd-usb-audio
[ 1.212206] mmc0: Command Queue Engine enabled
[ 1.212220] mmc0: new DDR MMC card at address 0001
[ 1.212674] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.212821] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 1.212967] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 1.213084] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[ 1.214151] mmcblk0: p1
[ 1.253475] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 59030000.spdif mapping ok
[ 1.255270] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 59020000.spdif mapping ok
[ 1.256149] imx-audmix imx-audmix.0: failed to find SAI platform device
[ 1.262831] imx-audmix: probe of imx-audmix.0 failed with error -22
[ 1.265836] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 1.266504] NET: Registered protocol family 26
[ 1.266945] NET: Registered protocol family 10
[ 1.267376] Segment Routing with IPv6
[ 1.267428] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.267671] NET: Registered protocol family 17
[ 1.267698] tsn generic netlink module v1 init...
[ 1.267730] Key type dns_resolver registered
[ 1.267996] registered taskstats version 1
[ 1.267998] Loading compiled-in X.509 certificates
[ 1.286135] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 1.294938] usb_phy_generic bus@5b000000:usb3-phy: bus@5b000000:usb3-phy supply vcc not found, using dummy regulator
[ 1.295046] usb_phy_generic bus@5b000000:usbphynop2: bus@5b000000:usbphynop2 supply vcc not found, using dummy regulator
[ 1.295654] i2c i2c-2: LPI2C adapter registered
[ 1.297893] sgtl5000 3-000a: sgtl5000 revision 0x11
[ 1.329469] usb3503 3-0008: switched to HUB mode
[ 1.329473] usb3503 3-0008: usb3503_probe: probed in hub mode
[ 1.329510] i2c i2c-3: LPI2C adapter registered
[ 1.332219] rtc-ds1307 4-0068: oscillator failed, set time!
[ 1.332285] rtc-ds1307 4-0068: registered as rtc0
[ 1.332315] i2c i2c-4: LPI2C adapter registered
[ 1.332804] i2c i2c-5: LPI2C adapter registered
[ 1.336018] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 1.336368] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 1.336613] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 1.336663] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 1.356777] dpu-core 56180000.dpu: driver probed
[ 1.358766] dpu-core 57180000.dpu: driver probed
[ 1.359036] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 1.359095] ahci-imx 5f020000.sata: No cache used with register defaults set!
[ 1.359330] ahci-imx 5f020000.sata: 5f020000.sata supply ahci not found, using dummy regulator
[ 1.359371] ahci-imx 5f020000.sata: 5f020000.sata supply phy not found, using dummy regulator
[ 1.359406] ahci-imx 5f020000.sata: 5f020000.sata supply target not found, using dummy regulator
[ 1.359486] ahci-imx 5f020000.sata: external osc is used.
[ 1.362312] ahci-imx 5f020000.sata: no ahb clock.
[ 1.362368] ahci-imx 5f020000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 1.362376] ahci-imx 5f020000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sadm sds apst
[ 1.362943] scsi host0: ahci-imx
[ 1.363145] ata1: SATA max UDMA/133 mmio [mem 0x5f020000-0x5f02ffff] port 0x100 irq 106
[ 1.378380] pps pps0: new PPS source ptp0
[ 1.379665] libphy: fec_enet_mii_bus: probed
[ 1.384966] fec 5b040000.ethernet eth0: registered PHC device 0
[ 1.388871] xhci-cdns3: xHCI Host Controller
[ 1.388888] xhci-cdns3: new USB bus registered, assigned bus number 1
[ 1.390303] xhci-cdns3: hcc params 0x200073c8 hci version 0x100 quirks 0x0000001000018010
[ 1.390861] hub 1-0:1.0: USB hub found
[ 1.390884] hub 1-0:1.0: 1 port detected
[ 1.391067] xhci-cdns3: xHCI Host Controller
[ 1.391075] xhci-cdns3: new USB bus registered, assigned bus number 2
[ 1.391083] xhci-cdns3: Host supports USB 3.0 SuperSpeed
[ 1.391125] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.391431] hub 2-0:1.0: USB hub found
[ 1.391450] hub 2-0:1.0: 1 port detected
[ 1.392572] imx_usb 5b0d0000.usb: 5b0d0000.usb supply vbus not found, using dummy regulator
[ 1.396184] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.396197] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 3
[ 1.418272] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.418929] hub 3-0:1.0: USB hub found
[ 1.418972] hub 3-0:1.0: 1 port detected
[ 1.423732] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.423750] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 4
[ 1.448039] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.448808] hub 4-0:1.0: USB hub found
[ 1.448844] hub 4-0:1.0: 1 port detected
[ 1.450502] gpio-fan gpio-fan: GPIO fan initialized
[ 1.453083] mmc1: CQHCI version 5.10
[ 1.453216] sdhci-esdhc-imx 5b020000.mmc: Got CD GPIO
[ 1.484712] mmc1: SDHCI controller on 5b020000.mmc [5b020000.mmc] using ADMA
[ 1.487153] mmc2: CQHCI version 5.10
[ 1.487222] sdhci-esdhc-imx 5b030000.mmc: Got CD GPIO
[ 1.518932] mmc2: SDHCI controller on 5b030000.mmc [5b030000.mmc] using ADMA
[ 1.551883] debugfs: Directory '59050000.sai' with parent 'apalis-imx8qm-sgtl5000' already present!
[ 1.561517] asoc-simple-card sound: sgtl5000 <-> 59050000.sai mapping ok
[ 1.566531] imx8qxp-lpcg-clk 5b260000.clock-controller: ignoring dependency for device, assuming no driver
[ 1.566779] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 1.567120] imx6q-pcie 5f000000.pcie: No cache used with register defaults set!
[ 1.567167] imx6q-pcie 5f010000.pcie: No cache used with register defaults set!
[ 1.573952] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.575243] rtc-ds1307 4-0068: hctosys: unable to read the hardware clock
[ 1.589239] ALSA device list:
[ 1.589245] #0: imx-hdmi-arc
[ 1.589249] #1: imx-spdif
[ 1.589251] #2: apalis-imx8qm-sgtl5000
[ 1.688523] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.728064] imx6q-pcie 5f010000.pcie: PCIe PLL locked after 0 us.
[ 1.728143] imx6q-pcie 5f010000.pcie: host bridge /bus@5f000000/pcie@0x5f010000 ranges:
[ 1.728195] imx6q-pcie 5f010000.pcie: IO 0x7ff80000..0x7ff8ffff -> 0x00000000
[ 1.728224] imx6q-pcie 5f010000.pcie: MEM 0x70000000..0x7fefffff -> 0x70000000
[ 1.828447] imx6q-pcie 5f010000.pcie: Link up
[ 1.828456] imx6q-pcie 5f010000.pcie: Link: Gen2 disabled
[ 1.828466] imx6q-pcie 5f010000.pcie: Link up, Gen1
[ 1.828653] imx6q-pcie 5f010000.pcie: PCI host bridge to bus 0000:00
[ 1.828667] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.828677] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.828687] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fefffff]
[ 1.828726] pci 0000:00:00.0: [1957:0000] type 01 class 0x060400
[ 1.828765] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[ 1.828783] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x00ffffff pref]
[ 1.828851] pci 0000:00:00.0: supports D1 D2
[ 1.828860] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 1.841214] pci 0000:01:00.0: [1b4b:2b42] type 00 class 0x020000
[ 1.841323] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 1.841366] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit pref]
[ 1.841681] pci 0000:01:00.0: supports D1 D2
[ 1.841691] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 1.841836] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with 5 GT/s x1 link)
[ 1.848059] imx6q-pcie 5f000000.pcie: PCIe PLL locked after 0 us.
[ 1.848120] imx6q-pcie 5f000000.pcie: host bridge /bus@5f000000/pcie@0x5f000000 ranges:
[ 1.848162] imx6q-pcie 5f000000.pcie: IO 0x6ff80000..0x6ff8ffff -> 0x00000000
[ 1.848189] imx6q-pcie 5f000000.pcie: MEM 0x60000000..0x6fefffff -> 0x60000000
[ 1.875896] pci 0000:00:00.0: BAR 0: assigned [mem 0x70000000-0x70ffffff]
[ 1.875908] pci 0000:00:00.0: BAR 6: assigned [mem 0x71000000-0x71ffffff pref]
[ 1.875917] pci 0000:00:00.0: BAR 15: assigned [mem 0x72000000-0x721fffff 64bit pref]
[ 1.875931] pci 0000:01:00.0: BAR 0: assigned [mem 0x72000000-0x720fffff 64bit pref]
[ 1.875963] pci 0000:01:00.0: BAR 2: assigned [mem 0x72100000-0x721fffff 64bit pref]
[ 1.875994] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.876004] pci 0000:00:00.0: bridge window [mem 0x72000000-0x721fffff 64bit pref]
[ 1.876437] pcieport 0000:00:00.0: PME: Signaling with IRQ 568
[ 2.018053] usb 4-1: new high-speed USB device number 2 using ci_hdrc
[ 2.219240] hub 4-1:1.0: USB hub found
[ 2.219347] hub 4-1:1.0: 3 ports detected
[ 2.538062] usb 4-1.3: new full-speed USB device number 3 using ci_hdrc
[ 2.694513] input: Genius Wireless Device as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb4/4-1/4-1.3/4-1.3:1.0/0003:0458:6001.0001/input/input2
[ 2.694852] hid-generic 0003:0458:6001.0001: input,hidraw0: USB HID v1.01 Mouse [Genius Wireless Device] on usb-ci_hdrc.1-1.3/input0
[ 2.698989] input: Genius Wireless Device System Control as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb4/4-1/4-1.3/4-1.3:1.1/0003:0458:6001.0002/input/input3
[ 2.768473] input: Genius Wireless Device Consumer Control as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb4/4-1/4-1.3/4-1.3:1.1/0003:0458:6001.0002/input/input4
[ 2.768786] input: Genius Wireless Device as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb4/4-1/4-1.3/4-1.3:1.1/0003:0458:6001.0002/input/input5
[ 2.769292] hid-generic 0003:0458:6001.0002: input,hiddev96,hidraw1: USB HID v1.01 Device [Genius Wireless Device] on usb-ci_hdrc.1-1.3/input1
[ 2.772193] input: Genius Wireless Device as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb4/4-1/4-1.3/4-1.3:1.2/0003:0458:6001.0003/input/input6
[ 2.838837] hid-generic 0003:0458:6001.0003: input,hidraw2: USB HID v1.01 Keyboard [Genius Wireless Device] on usb-ci_hdrc.1-1.3/input2
[ 2.848252] imx6q-pcie 5f000000.pcie: Phy link never came up
[ 2.848317] imx6q-pcie 5f000000.pcie: failed to initialize host
[ 2.854268] imx6q-pcie 5f000000.pcie: unable to add pcie port.
[ 2.865219] Freeing unused kernel memory: 3968K
[ 2.918430] Run /init as init process
[ 3.412764] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.756898] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.757613] systemd[1]: Detected architecture arm64.
[ 3.802670] systemd[1]: Set hostname to <apalis-imx8-06738440>.
[ 4.365295] systemd[1]: /usr/lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.sock; please update the unit file accordingly.
[ 4.378324] switch cluster 0 cpu-freq governor to schedutil
[ 4.428257] switch cluster 1 cpu-freq governor to schedutil
[ 4.447792] systemd[1]: Created slice system-getty.slice.
[ 4.449282] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.450376] systemd[1]: Created slice User and Session Slice.
[ 4.450605] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.450770] systemd[1]: Reached target Remote File Systems.
[ 4.450821] systemd[1]: Reached target Slices.
[ 4.450884] systemd[1]: Reached target Swap.
[ 4.464377] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 4.464525] systemd[1]: Reached target RPC Port Mapper.
[ 4.464871] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.465466] systemd[1]: Listening on Journal Audit Socket.
[ 4.465799] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.466197] systemd[1]: Listening on Journal Socket.
[ 4.466632] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.466936] systemd[1]: Listening on udev Control Socket.
[ 4.467221] systemd[1]: Listening on udev Kernel Socket.
[ 4.471309] systemd[1]: Mounting Huge Pages File System...
[ 4.475423] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.479744] systemd[1]: Mounting Kernel Debug File System...
[ 4.484588] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 4.489978] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.495518] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[ 4.496183] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 4.502017] systemd[1]: Starting Journal Service...
[ 4.507454] systemd[1]: Starting Load Kernel Modules...
[ 4.511765] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.516315] systemd[1]: Starting udev Coldplug all Devices...
[ 4.521142] systemd[1]: Starting Setup Virtual Console...
[ 4.530183] systemd[1]: Mounted Huge Pages File System.
[ 4.531287] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.531374] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.545005] systemd[1]: Mounted Kernel Debug File System.
[ 4.545548] systemd[1]: Mounted Temporary Directory (/tmp).
[ 4.548193] systemd[1]: Started Create list of static device nodes for the current kernel.
[ 4.549541] galcore: loading out-of-tree module taints kernel.
[ 4.550727] systemd[1]: Started Remount Root and Kernel File Systems.
[ 4.551650] systemd[1]: systemd-vconsole-setup.service: Succeeded.
[ 4.553661] systemd[1]: Started Setup Virtual Console.
[ 4.555164] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 4.555305] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 4.559795] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.566276] Galcore version 6.4.3.p1.305572
[ 4.587793] systemd[1]: Started Create Static Device Nodes in /dev.
[ 4.588517] systemd[1]: Reached target Local File Systems (Pre).
[ 4.588845] systemd[1]: var.mount: Directory /var to mount over is not empty, mounting anyway.
[ 4.592715] systemd[1]: Mounting /var...
[ 4.597138] systemd[1]: Starting udev Kernel Device Manager...
[ 4.608211] systemd[1]: Mounted /var.
[ 4.613979] systemd[1]: Mounting /var/volatile...
[ 4.621583] systemd[1]: Starting OSTree Remount OS/ Bind Mounts...
[ 4.626329] systemd[1]: Starting RPC Bind...
[ 4.638658] systemd[1]: Mounted /var/volatile.
[ 4.641476] systemd[1]: Started OSTree Remount OS/ Bind Mounts.
[ 4.642217] systemd[1]: Condition check resulted in Bind mount volatile /var/cache being skipped.
[ 4.642322] systemd[1]: Condition check resulted in Bind mount volatile /var/lib being skipped.
[ 4.646694] systemd[1]: Starting Load/Save Random Seed...
[ 4.646871] systemd[1]: Condition check resulted in Bind mount volatile /var/spool being skipped.
[ 4.647885] systemd[1]: Condition check resulted in Bind mount volatile /srv being skipped.
[ 4.648099] systemd[1]: Reached target Local File Systems.
[ 4.651406] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 4.651650] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 4.655350] systemd[1]: Started Systemd Timesync Update Fixes.
[ 4.656426] systemd[1]: Started RPC Bind.
[ 4.676281] systemd[1]: Received SIGRTMIN+20 from PID 480 (plymouthd).
[ 4.677711] systemd[1]: plymouth-read-write.service: Succeeded.
[ 4.679306] systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
[ 4.686469] systemd[1]: Started Load/Save Random Seed.
[ 4.689999] systemd[1]: systemd-timesyncd-update.service: Succeeded.
[ 4.738895] [drm] Initialized vivante 1.0.0 20170808 for 80000000.imx8_gpu1_ss on minor 0
[ 4.763160] openvswitch: Open vSwitch switching datapath
[ 4.767153] systemd[1]: Started Load Kernel Modules.
[ 4.767908] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 4.770780] systemd[1]: Mounting Kernel Configuration File System...
[ 4.774771] systemd[1]: Starting Apply Kernel Variables...
[ 4.781805] systemd[1]: Mounted Kernel Configuration File System.
[ 4.799992] systemd[1]: Started Apply Kernel Variables.
[ 5.007714] systemd[1]: Started udev Kernel Device Manager.
[ 5.077848] systemd[1]: Started udev Coldplug all Devices.
[ 5.081358] systemd[1]: Starting Show Plymouth Boot Screen...
[ 5.119024] systemd[1]: plymouth-start.service: Succeeded.
[ 5.120600] systemd[1]: Started Show Plymouth Boot Screen.
[ 5.121181] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[ 5.121466] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[ 5.368584] systemd[1]: Started Journal Service.
[ 5.387305] systemd-journald[568]: Received client request to flush runtime journal.
[ 5.427827] [VPU Encoder] enable mu for core[0]
[ 5.435501] [VPU Encoder] vpu encoder core[0] firmware version is 1.3.0
[ 5.483649] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.483658] [drm] No driver support for vblank timestamp query.
[ 5.483779] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 5.483850] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 5.485112] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 5.485674] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 5.486225] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 5.486759] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 5.516040] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video0 (81,2)
[ 5.528483] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video1 (81,3)
[ 5.550274] CAN device driver interface
[ 5.556596] flexcan 5a8d0000.can: 5a8d0000.can supply xceiver not found, using dummy regulator
[ 5.563198] flexcan 5a8e0000.can: 5a8e0000.can supply xceiver not found, using dummy regulator
[ 5.597723] [drm] Started firmware!
[ 5.599148] [drm] HDP FW Version - ver 34219 verlib 20560
[ 5.600913] cdns-mhdp-imx 56268000.hdmi: lane-mapping 0x93
[ 5.600935] cdns-mhdp-imx 56268000.hdmi: Connector's ddc i2c bus found
[ 5.617359] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_imx_ops [cdns_mhdp_imx])
[ 5.617982] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[ 5.620221] [drm] Cannot find any crtc or sizes
[ 5.856322] debugfs: Directory '59090000.sai' with parent 'imx-audio-hdmi-tx' already present!
[ 5.879974] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 59090000.sai mapping ok
[ 5.880074] debugfs: File 'Capture' in directory 'dapm' already present!
[ 5.909273] input: imx-audio-hdmi-tx HDMI Jack as /devices/platform/sound-hdmi/sound/card3/input7
[ 5.909310] fec 5b040000.ethernet ethernet0: renamed from eth0
[ 6.000845] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.023749] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.061653] mwifiex_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 6.061836] mwifiex_pcie: PCI memory map Virt0: 00000000d278c34f PCI memory map Virt2: 00000000f51f75dc
[ 7.130585] mwifiex_pcie 0000:01:00.0: info: FW download over, size 634228 bytes
[ 7.135679] Microchip KSZ9131 Gigabit PHY 5b040000.ethernet-1:07: attached PHY driver [Microchip KSZ9131 Gigabit PHY] (mii_bus:phy_addr=5b040000.ethernet-1:07, irq=281)
[ 7.978084] mwifiex_pcie 0000:01:00.0: WLAN FW is active
[ 8.018007] mwifiex_pcie 0000:01:00.0: Unknown api_id: 3
[ 8.018049] mwifiex_pcie 0000:01:00.0: Unknown api_id: 4
[ 8.018060] mwifiex_pcie 0000:01:00.0: Unknown GET_HW_SPEC TLV type: 0x217
[ 8.037032] mwifiex_pcie 0000:01:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p195)
[ 8.037133] mwifiex_pcie 0000:01:00.0: driver_version = mwifiex 1.0 (16.68.1.p195)
[ 8.078628] mwifiex_pcie 0000:01:00.0: uap0: changing to 2 not supported
[ 8.388109] usb 4-1.1: new high-speed USB device number 4 using ci_hdrc
[ 8.589989] usbcore: registered new interface driver btusb
[ 8.594243] Bluetooth: hci0: unexpected event for opcode 0x0000
[ 8.695941] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.695946] Bluetooth: BNEP filters: protocol multicast
[ 8.695960] Bluetooth: BNEP socket layer initialized
[ 31.838080] pcie_switch: disabling
[ 33.446468] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 33.450744] Bridge firewalling registered
[ 33.528216] audit: type=1325 audit(1613284828.291:2): table=nat family=2 entries=0
[ 33.628213] audit: type=1325 audit(1613284828.361:3): table=filter family=2 entries=0
[ 33.778392] audit: type=1325 audit(1613284828.531:4): table=nat family=2 entries=5
[ 33.848203] audit: type=1325 audit(1613284828.601:5): table=filter family=2 entries=4
[ 33.928289] audit: type=1325 audit(1613284828.671:6): table=filter family=2 entries=6
[ 33.988311] audit: type=1325 audit(1613284828.751:7): table=filter family=2 entries=8
[ 34.038223] audit: type=1325 audit(1613284828.811:8): table=filter family=2 entries=10
[ 34.098222] audit: type=1325 audit(1613284828.861:9): table=filter family=2 entries=11
[ 34.148187] audit: type=1325 audit(1613284828.921:10): table=filter family=2 entries=12
[ 34.160453] Initializing XFRM netlink socket
[ 34.238565] audit: type=1325 audit(1613284829.011:11): table=nat family=2 entries=7
[ 38.948323] kauditd_printk_skb: 31 callbacks suppressed
[ 38.948330] audit: type=1325 audit(1613284833.731:43): table=nat family=2 entries=11
[ 39.038168] audit: type=1325 audit(1613284833.771:44): table=nat family=2 entries=12
[ 39.088206] audit: type=1325 audit(1613284833.861:45): table=filter family=2 entries=23
[ 39.138169] audit: type=1325 audit(1613284833.911:46): table=filter family=2 entries=24
[ 39.238177] audit: type=1325 audit(1613284833.981:47): table=filter family=2 entries=25
[ 39.318344] audit: type=1325 audit(1613284834.061:48): table=filter family=2 entries=26
[ 39.378284] audit: type=1325 audit(1613284834.141:49): table=filter family=2 entries=27
[ 39.428137] audit: type=1325 audit(1613284834.201:50): table=filter family=2 entries=26
[ 39.478173] audit: type=1325 audit(1613284834.251:51): table=filter family=2 entries=27
[ 39.528184] audit: type=1325 audit(1613284834.301:52): table=filter family=2 entries=28
[ 40.246833] br-30b9faa6c244: port 1(vethe57da7d) entered blocking state
[ 40.246855] br-30b9faa6c244: port 1(vethe57da7d) entered disabled state
[ 40.247366] device vethe57da7d entered promiscuous mode
[ 40.780508] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[ 42.170132] eth0: renamed from veth0eccdd3
[ 42.230700] IPv6: ADDRCONF(NETDEV_CHANGE): vethe57da7d: link becomes ready
[ 42.230896] br-30b9faa6c244: port 1(vethe57da7d) entered blocking state
[ 42.230909] br-30b9faa6c244: port 1(vethe57da7d) entered forwarding state
[ 42.231188] IPv6: ADDRCONF(NETDEV_CHANGE): br-30b9faa6c244: link becomes ready
[ 43.252449] br-30b9faa6c244: port 2(vethbbfe364) entered blocking state
[ 43.252484] br-30b9faa6c244: port 2(vethbbfe364) entered disabled state
[ 43.252893] device vethbbfe364 entered promiscuous mode
[ 44.168173] kauditd_printk_skb: 19 callbacks suppressed
[ 44.168179] audit: type=1325 audit(1613284838.901:72): table=nat family=2 entries=0
[ 44.288160] audit: type=1325 audit(1613284839.001:73): table=filter family=2 entries=0
[ 44.368332] audit: type=1325 audit(1613284839.121:74): table=nat family=2 entries=5
[ 44.448411] audit: type=1325 audit(1613284839.191:75): table=nat family=2 entries=7
[ 44.508394] audit: type=1325 audit(1613284839.271:76): table=nat family=2 entries=8
[ 44.608432] audit: type=1325 audit(1613284839.331:77): table=nat family=2 entries=10
[ 44.678258] audit: type=1325 audit(1613284839.431:78): table=nat family=2 entries=11
[ 44.738466] audit: type=1325 audit(1613284839.501:79): table=nat family=2 entries=12
[ 44.828213] audit: type=1325 audit(1613284839.561:80): table=nat family=2 entries=13
[ 44.918229] audit: type=1325 audit(1613284839.651:81): table=nat family=2 entries=14
[ 45.009691] eth0: renamed from veth09960db
[ 45.079702] IPv6: ADDRCONF(NETDEV_CHANGE): vethbbfe364: link becomes ready
[ 45.079916] br-30b9faa6c244: port 2(vethbbfe364) entered blocking state
[ 45.079928] br-30b9faa6c244: port 2(vethbbfe364) entered forwarding state
I am new with embedded Linux. I only have little experience with Desktop Linux. I don’t know if I am doing or understanding something wrong, or if it is a bug/problem with the absence of .dtbo in the /boot partition.
Thank you in advance
EDIT: I also tried in U-Boot:
setenv tdxargs video=HDMI-A-1:1024x768
and
setenv tdxargs video=HDMI-A-1:1024x768@30
with no success. When that didn’t work, I rebooted to delete that environment variable, and booted. In that case I had HDMI screen for the first time ever. But after that I rebooted several times with no success.
Also, about the TorizonCore version I am using, I also tried with the latest TorizonCore quarterly release with the same results
