I need to enable SPI0 to use CS3 (only), and I’m afraid I remain baffled by the device tree – I would be very grateful for advice!
My device tree is based on vf500-colibri-eval-v3.dts
, with my customisations replacing vf-colibri-eval-v3.dtsi
. At present I have device node /dev/spidev0.0
present (whereas presumably I should see /dev/spidev0.3
), and CS3 is not activated when driving this device.
I have the following entries in my device tree (plus a /
node, &uart0
, a working &dspi1
on its CS0, and some other immaterial fields):
&dspi0 {
bus-num = <0>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_dspi0>;
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <10000000>; /* 10 MHz */
&iomuxc {
vf610-colibri {
/* Override of original hog group. */
pinctrl_hog_0: hoggrp-0 {
fsl,pins = < /* Pins elided */ >;
pinctrl_dspi0: dspi0grp {
fsl,pins = <
VF610_PAD_PTC0__DSPI0_CS3 0x1182
VF610_PAD_PTB20__DSPI0_SIN 0x1181
VF610_PAD_PTB21__DSPI0_SOUT 0x1182
VF610_PAD_PTB22__DSPI0_SCK 0x1182
The dspi0
settings were largely copied from vf610-twr.dts
, but clearly simply changing the CS pin isn’t enough.
