Clibri Evaluation Boardについて
Clibri Evaluation Board Rev 3.2にCol iMx6DL 512MB V1.1Aを刺し、Power ON/OFFスイッチを押しても、起動しなくなりました。
ON時に、RESET LEDと3.3V/5V LEDは、瞬間点灯しますが直ぐに消えてしまいます。
復旧の方法をご教授ください。
I’m sorry to hear about the boot issue you’re experiencing with your Colibri iMX6DL module on the Colibri Evaluation Board Rev 3.2. Here are some steps you can take to troubleshoot the problem:
  1. Check Power Supply: Ensure that the power supply is providing the correct voltage and current. The evaluation board typically requires a 5V power supply. Verify that the power adapter is functioning correctly and that the power cable is securely connected.
  2. Inspect Connections: Double-check all connections between the Colibri module and the evaluation board. Make sure the module is properly seated in the connector and that there are no bent pins or debris.
  3. Examine LEDs: The brief illumination of the RESET and 3.3V/5V LEDs suggests a possible power or reset issue. Ensure there are no short circuits on the board and that the reset button is not stuck or malfunctioning.
  4. Test with Minimal Configuration: Remove any additional peripherals or accessories connected to the evaluation board. Test the board with only the essential components to rule out any external device causing the issue.
  5. Check for Hardware Damage: Inspect the evaluation board and the Colibri module for any visible signs of damage, such as burnt components or broken traces.
  6. Recovery Mode: If the board still does not boot, consider attempting to boot the module in recovery mode. This may involve using a USB connection to a host PC and following specific recovery procedures for the iMX6DL module.
  7. Consult Documentation: Refer to the Colibri iMX6DL datasheet and the Colibri Evaluation Board V3.2 datasheet for any specific configuration or jumper settings that might affect the boot process.
I hope these steps help you resolve the issue. If the problem persists, further investigation into the system configuration may be necessary.
Toradex AI Assistant
No U-boot display trying to recover Colibri iMX6.
別のiMx6 Boradは、動作します。
動作しなくなったボードは、初めは動作していました。
TEZIの再インストールを行っていました。
SDを準備して、run distro_bootcmdを実行し、再起動したら起動しなくなりました。
インストールが正常に完了しなかった可能性があり、その結果eMMCの内容が破損し、正しくブートできなくなったようです。
モジュールをリカバリーモードにして、PCからToradex Easy Installerを起動する必要があります。
Colibri iMX6DL 512MB V1.1AをColibri Evaluation Board Rev 3.2でリカバリーモードにする方法については、以下のリンクをご確認ください:
リカバリーモード手順
リカバリーモードに入った後の手順:
  1. 最新のToradex Easy InstallerのイメージをホストPCにダウンロードしてください。
    ダウンロードリンク
  2. Toradex Easy InstallerをPCからモジュールにロードしてください。
    ロード手順
以上の手順を試していただき、状況をご共有ください。
