I got the following error when starting VScode:
Failed to connect to the remote extension host server (Error: WebSocket close with status code 1006)
I noticed that the WSL was failing to connect so I closed VSCode went through the following steps.
C:\Windows\System32>wsl --list --verbose
NAME STATE VERSION
Torizon Running 2
C:\Windows\System32>wsl sudo service docker status
Docker is not running … failed!
C:\Windows\System32>wsl sudo service docker start
Starting Docker: docker.
Docker is running.
NAME STATE VERSION
Torizon Running 2
Welcome to the Torizon WSL 2 v1.0.0
usermod: Permission denied.
usermod: cannot lock /etc/passwd; try again later.
xonsh: For full traceback set: $XONSH_SHOW_TRACEBACK = True
subprocess.CalledProcessError: Command ‘[‘usermod’, ‘-aG’, ‘sudo’, ‘SAbrahamian’]’ returned non-zero exit status 1.
Bye!
Trying to run wsl gives me this usermod error. I didn’t explicitly change my user permissions so I ran the following:
C:\Windows\System32>wsl id SAbrahamian
uid=1000(SAbrahamian) gid=1000(SAbrahamian) groups=1000(SAbrahamian),20(dialout),27(sudo),996(docker)
I should have super user permissions. So to double check this I ran this but it hung up after I entered my password.
C:\Windows\System32>wsl sudo whoami
[sudo] password for SAbrahamian:
I had successfully been working around the WSL error by opening a terminal, shutting down WSL, restart docker, then restarting WSL. Now its not working. Here is the log when I start VSCode.
INFO Started local extension host with pid 7028.
INFO [AgentHost:remote] Initializing (enabled=false, remoteAuthority=wsl+torizon)
INFO [AgentHost:remote] Disabled via "chat.agentHost.enabled" or web runtime. Not connecting.
INFO [AccountPolicyGate] apply: state=inactive, reason=undefined, isRestricted=false
ERR navigator is now a global in nodejs, please see https://aka.ms/vscode-extensions/navigator for additional info on this error.: PendingMigrationError: navigator is now a global in nodejs, please see https://aka.ms/vscode-extensions/navigator for additional info on this error.
at get (file:///c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/1b50d58d73/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:837:7243)
at Ye (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:49943)
at R (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:45899)
at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:49796
at k (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:331335)
at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:379045
at Object.f [as use] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:403567)
at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:402921
at Object.watch (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:402932)
at b (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:404804)
at e.<computed> [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:378323)
at e.r [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:349209)
at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:387122
at p (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:341770)
at e.<computed> [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:386312)
at t.r [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:349209)
at Array.<anonymous> (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:56537)
at Et (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:51449)
at u (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:56498)
at he (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:150349)
at e.<computed> (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:153613)
at Object.initialize (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:349963)
at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:67620
at e.<computed> [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:67545)
at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:356456
at async c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:355860
INFO Invoking resolveAuthority(wsl)...
INFO [LocalProcess0][resolveAuthority(wsl,1)][0ms] obtaining proxy...
INFO [LocalProcess0][resolveAuthority(wsl,1)][4ms] invoking...
INFO [LocalProcess0][resolveAuthority(wsl,1)][1007ms] waiting...
INFO [LocalProcess0][resolveAuthority(wsl,1)][2018ms] waiting...
INFO [LocalProcess0][resolveAuthority(wsl,1)][2038ms] returned WebSocket(127.0.0.1:60735)
INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:60735)' after 2038 ms
INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28)...
INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a)...
INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) was successful after 81 ms.
INFO [reconnection-grace-time] Client received grace time from server: 10800000ms (10800s)
INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a) was successful after 183 ms.
ERR Ignoring python.analysis.indexing.followSymlinkedFolders as python.analysis.indexing is true
INFO [remote-connection][ExtensionHost][e4309…][reconnect] received socket close event (wasClean: false, code: 1006, reason: ).
ERR CloseEvent
INFO [remote-connection][ExtensionHost][e4309…][reconnect] starting reconnecting loop. You can get more information with the trace log level.
INFO [remote-connection][ExtensionHost][e4309…][reconnect] starting reconnection with grace time: 10800000ms (10800s)
INFO [remote-connection][ExtensionHost][e4309…][reconnect] resolving connection...
INFO [remote-connection][ExtensionHost][e4309…][reconnect] connecting to WebSocket(127.0.0.1:60735)...
Overwriting grammar scope name to file mapping for scope source.python.
Old grammar file: file:///c%3A/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/1b50d58d73/resources/app/extensions/python/syntaxes/MagicPython.tmLanguage.json.
New grammar file: vscode-remote://wsl%2Btorizon/home/SAbrahamian/.vscode-server/extensions/ms-python.vscode-pylance-2026.2.1/grammars/PylancePython.tmLanguage
Overwriting grammar scope name to file mapping for scope source.yaml.
Old grammar file: file:///c%3A/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/1b50d58d73/resources/app/extensions/yaml/syntaxes/yaml.tmLanguage.json.
New grammar file: vscode-remote://wsl%2Btorizon/home/SAbrahamian/.vscode-server/extensions/redhat.vscode-yaml-1.23.0/syntaxes/yaml.tmLanguage.json
INFO [remote-connection][Management ][bcd2d…][reconnect] received socket close event (wasClean: false, code: 1006, reason: ).
ERR CloseEvent
INFO [remote-connection][Management ][bcd2d…][reconnect] starting reconnecting loop. You can get more information with the trace log level.
INFO [remote-connection][Management ][bcd2d…][reconnect] starting reconnection with grace time: 10800000ms (10800s)
INFO [remote-connection][Management ][bcd2d…][reconnect] resolving connection...
INFO [LocalProcess0][resolveAuthority(wsl,2)][0ms] obtaining proxy...
INFO [LocalProcess0][resolveAuthority(wsl,2)][0ms] invoking...
INFO [LocalProcess0][resolveAuthority(wsl,2)][5ms] returned WebSocket(127.0.0.1:60735)
INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:60735)' after 5 ms
INFO [remote-connection][Management ][bcd2d…][reconnect] connecting to WebSocket(127.0.0.1:60735)...
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fbin%2F1b50d58d73426c9171299ec4…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fextensions%2Fms-python.python-…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fextensions%2Fms-vscode.powersh…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fextensions%2Fms-vscode.makefil…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fextensions%2Fms-azuretools.vsc…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fextensions%2Ftoradex.apollox-v…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
WebSocket connection to 'ws://127.0.0.1:60735/stable-1b50d58d73426c9171299ec4037d01365d995b78?reconnectionToken=e43090be-35a5-424e-824f-b73bf5cb6e7a&reconnection=true&skipWebSocketFrames=false' failed:
INFO Settings Sync: Account status changed from uninitialized to available
INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a) returned an error after 282 ms.
ERR
ERR [remote-connection][ExtensionHost][e4309…][reconnect][WebSocket(127.0.0.1:60735)] socketFactory.connect() failed or timed out. Error:
ERR
INFO [remote-connection][ExtensionHost][e4309…][reconnect] A temporarily not available error occurred while trying to reconnect, will try again...
INFO [remote-connection][ExtensionHost][e4309…][reconnect] waiting for 5 seconds before reconnecting...
vscode-remote-resource?path=%2Fhome%2FSAbrahamian%2F.vscode-server%2Fextensions%2Fms-python.vscode-…:1 Failed to load resource: net::ERR_EMPTY_RESPONSE
WebSocket connection to 'ws://127.0.0.1:60735/stable-1b50d58d73426c9171299ec4037d01365d995b78?reconnectionToken=bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28&reconnection=true&skipWebSocketFrames=false' failed:
INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) returned an error after 112 ms.
ERR
ERR [remote-connection][Management ][bcd2d…][reconnect][WebSocket(127.0.0.1:60735)] socketFactory.connect() failed or timed out. Error:
ERR
INFO [remote-connection][Management ][bcd2d…][reconnect] A temporarily not available error occurred while trying to reconnect, will try again...
INFO [remote-connection][Management ][bcd2d…][reconnect] waiting for 5 seconds before reconnecting...
INFO [perf] Render performance baseline is 9ms
INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a) returned an error after 63 ms.
ERR
ERR
INFO [LocalProcess0][resolveAuthority(wsl,3)][0ms] obtaining proxy...
INFO [LocalProcess0][resolveAuthority(wsl,3)][0ms] invoking...
INFO [LocalProcess0][resolveAuthority(wsl,3)][0ms] returned WebSocket(127.0.0.1:60735)
INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:60735)' after 0 ms
INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) returned an error after 60 ms.
ERR
ERR
INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a) returned an error after 61 ms.
ERR
ERR
INFO [remote-connection][ExtensionHost][e4309…][reconnect] waiting for 10 seconds before reconnecting...
INFO [LocalProcess0][resolveAuthority(wsl,4)][0ms] obtaining proxy...
INFO [LocalProcess0][resolveAuthority(wsl,4)][0ms] invoking...
INFO [LocalProcess0][resolveAuthority(wsl,4)][1ms] returned WebSocket(127.0.0.1:60735)
INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:60735)' after 1 ms
INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) returned an error after 61 ms.
ERR
ERR
INFO [remote-connection][Management ][bcd2d…][reconnect] waiting for 10 seconds before reconnecting...
INFO [remote-connection][Management ][bcd2d…][reconnect] received socket timeout event (reason: unacknowledgedMessage, unacknowledgedMsgCount: 50, timeSinceOldestUnacknowledgedMsg: 20348, timeSinceLastReceivedSomeData: 20006).
ERR
ERR
INFO [LocalProcess0][resolveAuthority(wsl,5)][0ms] obtaining proxy...
INFO [LocalProcess0][resolveAuthority(wsl,5)][0ms] invoking...
INFO [LocalProcess0][resolveAuthority(wsl,5)][0ms] returned WebSocket(127.0.0.1:60735)
ERR
ERR
INFO [remote-connection][ExtensionHost][e4309…][reconnect] received socket timeout event (reason: keepAlive, unacknowledgedMsgCount: 0, timeSinceOldestUnacknowledgedMsg: undefined, timeSinceLastReceivedSomeData: 24958).
ERR
ERR
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,6)][0ms] obtaining proxy...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,6)][0ms] invoking...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,6)][1ms] returned WebSocket(127.0.0.1:60735)
log.ts:117 INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:60735)' after 1 ms
log.ts:117 INFO [remote-connection][Management ][bcd2d…][reconnect] connecting to WebSocket(127.0.0.1:60735)...
log.ts:117 INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28)...
browserSocketFactory.ts:80 WebSocket connection to 'ws://127.0.0.1:60735/stable-1b50d58d73426c9171299ec4037d01365d995b78?reconnectionToken=bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28&reconnection=true&skipWebSocketFrames=false' failed:
constructor @ browserSocketFactory.ts:80
log.ts:117 INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) returned an error after 58 ms.
log.ts:117 ERR CodeExpectedError: WebSocket close with status code 1006
at WebSocket.<anonymous> (browserSocketFactory.ts:167:20)
logToConsole @ log.ts:117
log.ts:117 ERR [remote-connection][Management ][bcd2d…][reconnect][WebSocket(127.0.0.1:60735)] socketFactory.connect() failed or timed out. Error:
log.ts:117 INFO [remote-connection][Management ][bcd2d…][reconnect] A temporarily not available error occurred while trying to reconnect, will try again...
log.ts:117 INFO [remote-connection][Management ][bcd2d…][reconnect] waiting for 10 seconds before reconnecting...
log.ts:117 INFO [remote-connection][Management ][bcd2d…][reconnect] received socket timeout event (reason: unacknowledgedMessage, unacknowledgedMsgCount: 51, timeSinceOldestUnacknowledgedMsg: 40349, timeSinceLastReceivedSomeData: 40007).
log.ts:117 INFO [remote-connection][ExtensionHost][e4309…][reconnect] resolving connection...
log.ts:117 INFO [remote-connection][ExtensionHost][e4309…][reconnect] connecting to WebSocket(127.0.0.1:60735)...
log.ts:117 INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a)...
browserSocketFactory.ts:80 WebSocket connection to 'ws://127.0.0.1:60735/stable-1b50d58d73426c9171299ec4037d01365d995b78?reconnectionToken=e43090be-35a5-424e-824f-b73bf5cb6e7a&reconnection=true&skipWebSocketFrames=false' failed:
log.ts:117 INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a) returned an error after 72 ms.
log.ts:117 ERR [remote-connection][ExtensionHost][e4309…][reconnect][WebSocket(127.0.0.1:60735)] socketFactory.connect() failed or timed out. Error:
log.ts:117 INFO [remote-connection][ExtensionHost][e4309…][reconnect] A temporarily not available error occurred while trying to reconnect, will try again...
log.ts:117 INFO [remote-connection][ExtensionHost][e4309…][reconnect] waiting for 10 seconds before reconnecting...
log.ts:117 INFO [remote-connection][Management ][bcd2d…][reconnect] resolving connection...
log.ts:117 INFO Invoking resolveAuthority(wsl)...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,7)][0ms] obtaining proxy...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,7)][0ms] invoking...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,7)][1ms] returned WebSocket(127.0.0.1:60735)
log.ts:117 INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) returned an error after 64 ms.
log.ts:117 INFO [remote-connection][ExtensionHost][e4309…][reconnect] received socket timeout event (reason: keepAlive, unacknowledgedMsgCount: 0, timeSinceOldestUnacknowledgedMsg: undefined, timeSinceLastReceivedSomeData: 44959).
log.ts:117 INFO Creating a socket (renderer-ExtensionHost-e43090be-35a5-424e-824f-b73bf5cb6e7a) returned an error after 62 ms.
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,8)][0ms] obtaining proxy...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,8)][0ms] invoking...
log.ts:117 INFO [LocalProcess0][resolveAuthority(wsl,8)][2ms] returned WebSocket(127.0.0.1:60735)
log.ts:117 INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:60735)' after 2 ms
log.ts:117 INFO Creating a socket (renderer-Management-bcd2dfd4-6573-4d9f-a48f-d0ae8bbf3c28) returned an error after 60 ms.
