Board dosent start after easy installer updating
hi
i have an imx6dl board, I saw new easy installer at start up, but no any torizon os compatible with module. I updated easy installer, but after reboot I have not any terminal, any OS, . the module is dead. I repeated this with another imx6, the same event happened.
canany one help?
I’m sorry to hear about the issues you’re experiencing with your iMX6DL board after updating the Toradex Easy Installer. Let’s try a few steps to troubleshoot and resolve this:
  1. USB Connection: Ensure your board is properly connected via USB. If possible, try using a different USB cable or port, as sometimes USB connection issues can affect the recovery process.
  2. Access the Serial Console: Connect to the serial console on UART1/UART_A. This will allow you to access the Easy Installer’s shell. Check the log file located at /var/volatile/tezi.log for any error messages that might indicate what went wrong during the update.
  3. Debugging with Boot Arguments: Consider appending Linux kernel parameters such as debug to the boot arguments. This can provide more detailed output from the kernel, which might help in diagnosing the issue.
By following these steps, you should be able to gather more information about the problem and potentially resolve the boot issue. If the issue persists, examining the logs and console output will be crucial in identifying the exact cause.
Toradex AI Assistant
iMX6Q Custom Board, u-boot, 100MBits Ethernet, not working, connected to RGMII - NXP Community.
thanks
I will send you logs on UART soon, but for the first time, when I started to install TORIZON OS, there wasn’t any compatible OS with my module, OS7,OS6.8, OS5.7 was incompatible. Do you know why?
Hello @tetaco,
As far as I understood, you are having issues with a Colibri imx6dl SoM, is that correct?
Could you also please confirm the PID8 of your module? You can find information on how to find the PID8 number here.
Also, please ensure you enter the recovery mode to run the Toradex Easy Installer.
You can find information on how to access it on this page. There, please select the IMX6DL SoM and the carrier board that you are using. You can also find information on how to run the Toradex Easy Installer in here.
Finally, I made a test using an IMX6DL module and the Aster Carrier Board and I managed to flash a TorizonOS image on it. The image that I used was the latest quarterly Colibri iMX6 release for Torizon OS 7 available on our download links page.
Please check the articles I indicated and try to flash the image again to see if it works. If you have any issues, please let me know so we can try to help you with it.
Marcio
