Bluetooth Failed at Scan/Discovery for Keyboard
We previously fixed the Bluetooth unavailable issue in both Boot2qt and Toradex BSP 6 images posted here.
Now the bluetooth failed occasionally when trying to scan or discover Keyboard:
root@colibri-imx6ull-06488061:~# bluetoothctl
Agent registered
[CHG] Controller DC:F5:05:11:3D:60 Pairable: yes
[bluetooth]# devices Paired
Device D1:85:77:CA:F2:10 BLE Keyboard 6063S
[bluetooth]# remove D1:85:77:CA:F2:10
[DEL] Primary Service (Handle 0x0000)
/org/bluez/hci0/dev_D1_85_77_CA_F2_10/service000a
00001801-0000-1000-8000-00805f9b34fb
Generic Attribute Profile
[DEL] Characteristic (Handle 0x0000)
/org/bluez/hci0/dev_D1_85_77_CA_F2_10/service000b/char000c
00002a29-0000-1000-8000-00805f9b34fb
Manufacturer Name String
/org/bluez/hci0/dev_D1_85_77_CA_F2_10/service000b/char000e
00002a50-0000-1000-8000-00805f9b34fb
PnP ID
0000180a-0000-1000-8000-00805f9b34fb
Device Information
[DEL] Descriptor (Handle 0x0000)
/org/bluez/hci0/dev_D1_85_77_CA_F2_10/service0010/char0011/desc0013
00002902-0000-1000-8000-00805f9b34fb
Client Characteristic Configuration
00002a19-0000-1000-8000-00805f9b34fb
Battery Level
0000180f-0000-1000-8000-00805f9b34fb
Battery Service
[DEL] Device D1:85:77:CA:F2:10 BLE Keyboard 6063S
Device has been removed
[bluetooth]# [ 4554.492518] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 4554.497827] Bluetooth: hci0: Unable to disable scanning: -110
[ 4554.505563] Bluetooth: hci0: command 0x200c tx timeout
[ 4554.519288] Bluetooth: hci0: stop background scanning failed: -110
[bluetooth]# scan on
[bluetooth]# sca[ 4574.091843] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 4574.097249] Bluetooth: hci0: Unable to disable scanning: -110
[ 4574.104453] Bluetooth: hci0: Unable to disable scanning: -110
[ 4574.110619] Bluetooth: hci0: command 0x200c tx timeout
Failed to start discovery: org.bluez.Error.InProgress
[bluetooth]# scan off
Failed to stop discovery: org.bluez.Error.Failed
[bluetooth]# [ 4576.171821] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 4576.177186] Bluetooth: hci0: Unable to disable scanning: -110
[ 4576.184399] Bluetooth: hci0: command 0x200c tx timeout
[ 4576.197797] Bluetooth: hci0: stop background scanning failed: -110
[bluetooth]# quit
Agent registered
[bluetooth]# scaan on
[bluetooth]# scan o[ 4833.771243] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 4833.776606] Bluetooth: hci0: Unable to disable scanning: -110
[ 4833.784985] Bluetooth: hci0: command 0x200c tx timeout
[ 4833.790373] Bluetooth: hci0: Unable to disable scanning: -110
[bluetooth]# scan off[ 4835.851809] Bluetooth: hci0: command 0x200c tx timeout
[ 4835.857220] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 4835.862686] Bluetooth: hci0: Unable to disable scanning: -110
[ 4835.868504] Bluetooth: hci0: stop background scanning failed: -110
[bluetooth]#
[bluetooth]# quit
root@colibri-imx6ull-06488061:/lib/systemd/system# systemctl daemon-reload
root@colibri-imx6ull-06488061:/lib/systemd/system# systemctl restart bluetooth
[ 5271.051050] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 5271.056583] Bluetooth: hci0: command 0x200c tx timeout
[ 5271.062676] Bluetooth: hci0: Unable to disable scanning: -110
root@colibri-imx6ull-06488061:/lib/systemd/system# [ 5281.768713] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 5281.774075] Bluetooth: hci0: Unable to disable scanning: -110
[ 5281.780776] Bluetooth: hci0: command 0x200c tx timeout
[ 5281.787235] Bluetooth: hci0: stop background scanning failed: -110
[ 5283.850722] Bluetooth: hci0: command 0x200c tx timeout
[ 5283.856127] Bluetooth: hci0: Opcode 0x200c failed: -110
[ 5283.868187] Bluetooth: hci0: Unable to disable scanning: -110
[ 5283.874011] Bluetooth: hci0: stop background scanning failed: -110
^C
root@colibri-imx6ull-06488061:/lib/systemd/system# [ 5285.930706] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5285.938598] Bluetooth: hci0: command 0x200c tx timeout
[ 5285.943875] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[ 5288.008252] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5288.014448] Bluetooth: hci0: command 0x200c tx timeout
[ 5290.090792] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5290.098491] Bluetooth: hci0: command 0x200c tx timeout
[ 5292.170740] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5292.178541] Bluetooth: hci0: command 0x200c tx timeout
[ 5294.248233] Bluetooth: hci0: command 0x200c tx timeout
[ 5294.253720] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5296.330712] Bluetooth: hci0: command 0x200c tx timeout
[ 5296.336199] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5298.410717] Bluetooth: hci0: command 0x200c tx timeout
[ 5298.416256] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5300.490722] Bluetooth: hci0: command 0x200c tx timeout
[ 5300.496200] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[ 5302.570738] Bluetooth: hci0: command 0x200c tx timeout
[ 5302.576221] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[ 5304.650730] Bluetooth: hci0: command 0x200c tx timeout
[ 5304.656262] Bluetooth: hci0: Opcode 0x0c13 failed: -110
[ 5306.730704] Bluetooth: hci0: command 0x200c tx timeout
[ 5306.736188] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[ 5308.810779] Bluetooth: hci0: command 0x200c tx timeout
[ 5308.816264] Bluetooth: hci0: Opcode 0x0c52 failed: -110
[ 5310.890751] Bluetooth: hci0: command 0x200c tx timeout
[ 5310.896562] Bluetooth: hci0: Opcode 0x0c13 failed: -110
Again this issue does not always happen. But all the failures seemed to happen when scanning after a device was paired. Any help would be greatly appreciated. Thank you.
Below is hardware and software info:
root@colibri-imx6ull-06488061:~# tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 6.6.69-7.1.0-00039-g0f10503b36ba #1 SMP PREEMPT Thu Jan 2 09:32:11 UTC 2025
Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 no_console_suspend=1 vt.global_cursor_default=0 console=ttymxc0,115200n8 consoleblank=0
Distro name: NAME=“TDX Wayland with XWayland Upstream”
Distro version: VERSION_ID=6.8.0-devel-20240809223737-build.0
Distro variant: -
Hostname: colibri-imx6ull-06488061
Hardware info
HW model: Toradex Colibri iMX6ULL 512MB on Colibri Evaluation Board V3
Toradex version: 0040 V1.1A
Serial number: 06488061
Processor arch: armv7l
I’m sorry to hear about the Bluetooth scanning issues you’re experiencing with your Colibri iMX6ULL module. Let’s go through some steps that might help resolve this problem:
  1. Update Software: Ensure your system is running the latest version of the Toradex BSP and BlueZ. Updates often include bug fixes that could address your issue.
  2. Inspect Bluetooth Configuration: Double-check your Bluetooth configuration files to ensure they are correctly set up. Misconfigurations can sometimes lead to operational issues.
  3. Examine Kernel Logs: The logs you provided show command timeouts (e.g., Opcode 0x200c failed: -110). These errors suggest communication issues between the Bluetooth stack and the hardware. Reviewing the kernel logs (dmesg) for additional error messages might provide more context.
  4. Restart Bluetooth Services: As a temporary workaround, restarting the Bluetooth service can sometimes resolve transient issues. You can do this by running systemctl restart bluetooth.
  5. Test with Different Devices: If possible, try using the Bluetooth functionality with different devices to determine if the issue is specific to the keyboard or a broader problem.
  6. Investigate Power Management Settings: Power management settings can sometimes interfere with Bluetooth operations. Ensure that the Bluetooth device is not being put into a low-power state that affects its functionality.
I hope these steps help you resolve the issue. If the problem persists, further investigation into the software environment might be necessary.
Toradex AI Assistant
Bluetooth Failed on Colibri iMx6ULL.
Hi @wjzhang
Thanks for the report. We have a report of similar issues that our WiFi/BT expert is investigating. It’s not clear that it is the same issue but it does look suspiciously so. I will report back when we get some results of his investigation.
Regards
Drew
Hello @wjzhang,
Could you give more details about what was the status of the module before you executed the “remove” command? Did you have the module running for a while, or was this after a reboot?
Can you consistently reproduce this behavior with the steps you mentioned?
Thanks in advance,
Rafael
Hi @wjzhang ,
Any updates here?
Hi Rafael
Sorry for my late response.
The module was successfully paired with my BT keyboard prior to the “remove” command. In the bluetoothctl console, I was trying to scan and pair with the keyboard again because the issue happened most likely at re-scan after the keyboard was paired and removed.
The module had been running for a while
I can reproduce the behavior more than 50% of the time.
Thank you
William
Hi Michael,
I have updated the kernel to version 6.11. So far I have not seen the failure reported in the original post. That seems to have fixed the issue.
William
Glad to hear your problem is resolved. Thank you for the update!
