When running the command
bitbake tdx-reference-minimal-image
in oe-core the Parsing Recipes step is stuck at 94%.
I did all of the things mentioned here.
This is a new problem, this step worked before.
Thank you in advance
It sounds like you’re encountering a frustrating issue with the Bitbake process getting stuck at 94% during the parsing recipes step for the tdx-reference-minimal-image. Let’s go through some steps to help resolve this:
Clean the Cache: Sometimes, the Bitbake cache can become corrupted. Try cleaning it with the following commands:
bitbake -c cleanall tdx-reference-minimal-image
bitbake -c cleansstate tdx-reference-minimal-image
Then, attempt the Bitbake command again.
Check Configuration Files: Double-check your local.conf and bblayers.conf files for any errors or misconfigurations that might cause Bitbake to hang.
Verify Dependencies: Ensure all necessary dependencies and tools are installed on your host system, as missing ones can stall the build process.
Review Logs: Look into the Bitbake logs for any error messages or warnings. These logs are usually located in build/tmp/log/cooker/$MACHINE/.
Environment Setup: Make sure your build environment is correctly set up each time you open a new terminal by sourcing the environment setup script:
source export
If these steps don’t resolve the issue, consider any recent changes to your build environment or configuration that might have introduced the problem. Reverting those changes could help identify the cause.
I hope these suggestions help you get back on track. If the issue persists, further investigation into specific error messages in the logs will be necessary.
Toradex AI Assistant
If i leave the bitbake running eventually it will fail giving the following message.
Loading cache: 100% |############################################| Time: 0:00:00
Loaded 5375 entries from dependency cache.
WARNING: /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-kernel/linux/linux-toradex-upstream_mainline.bb: Exception during build_dependencies for fetcher_hashes_dummyfunc
WARNING: /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-kernel/linux/linux-toradex-upstream_mainline.bb: Error during finalise of /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-kernel/linux/linux-toradex-upstream_mainline.bb
ERROR: ExpansionError during parsing /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-kernel/linux/linux-toradex-upstream_mainline.bb
bb.data_smart.ExpansionError: Failure expanding variable fetcher_hashes_dummyfunc[vardepvalue], expression was ${@bb.fetch.get_hashvalue(d)} which triggered exception FetchError: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus,guid=f6257f71b19299b7cd0001e267c7faf5"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/hamed/dv-core/layers/openembedded-core/scripts:/home/hamed/dv-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-upstream/mainline/recipe-sysroot-native/usr/bin/arm-tdx-linux-gnueabi:/home/hamed/dv-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-upstream/mainline/recipe-sysroot/usr/bin/crossscripts:/home/hamed/dv-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-upstream/mainline/recipe-sysroot-native/usr/sbin:/home/hamed/dv-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-upstream/mainline/recipe-sysroot-native/usr/bin:/home/hamed/dv-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-upstream/mainline/recipe-sysroot-native/sbin:/home/hamed/dv-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-upstream/mainline/recipe-sysroot-native/bin:/home/hamed/dv-core/layers/openembedded-core/bitbake/bin:/home/hamed/dv-core/build/tmp/hosttools"; export HOME="/home/hamed"; git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git failed with exit code 126, output:
/home/hamed/.pyenv/libexec/pyenv: line 138: /home/hamed/.pyenv/libexec/pyenv-exec: Argument list too long
The variable dependency chain for the failure is: fetcher_hashes_dummyfunc[vardepvalue]
ERROR: Parsing halted due to errors, see error messages above
WARNING: /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-toradex_mainline.bb: Exception during build_dependencies for fetcher_hashes_dummyfunc
WARNING: /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-toradex_mainline.bb: Error during finalise of /home/hamed/dv-core/build/../layers/meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-toradex_mainline.bb
Summary: There were 4 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
Hello @tarik-dvpower,
Which BSP version are you trying to build and for which machine?
Did you add any custom layers?
Also which branch from the repo manifest did sou use? It would be great if you can show me your repo init command.
In local.conf I uncommented
MACHINE ?= "colibri-imx6"
and added
ACCEPT_FSL_EULA = "1"
I didn’t add any additional layers for this.
And the repo init command I used is this
repo init -u git://git.toradex.com/toradex-manifest.git -b scarthgap-7.x.y -m tdxref/default.xml
I could build a reference minimal image for Scarthgap following our documentation.
Could you please compare your build configuration with that of mine and see if anything is different:
Build Configuration:
BB_VERSION = "2.8.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-tdx-linux-gnueabi"
MACHINE = "colibri-imx6"
DISTRO = "tdx-xwayland-upstream"
DISTRO_VERSION = "7.2.0-devel-20250310123533+build.0"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-toradex-nxp = "HEAD:31b3db3238a833babf58768143570f8490e90ea5"
meta-freescale = "HEAD:a8a6b9d1b274f1a24e4d75243af1bbde011b2ebb"
meta-freescale-3rdparty = "HEAD:1dfc65dd2006b51d156be5bcda0e3c72c936ad0a"
meta-toradex-ti = "HEAD:8bf12dffab112d39b66fc4f7bde151dba9ba048c"
meta-arm-toolchain
meta-arm = "HEAD:3cadb81ffaa9f03b92e302843cb22a9cd41df34b"
meta-ti-bsp
meta-ti-extras = "HEAD:d1f9c4761e9f65f8a6f049f3ffdc85a8b0f0f63f"
meta-toradex-bsp-common = "HEAD:0351a84895d733077d5576d8937417581a1a43f9"
meta-oe
meta-filesystems
meta-networking
meta-multimedia
meta-python = "HEAD:4f11a12b2352bbdfafb6b7d956bf424af4992977"
meta-freescale-distro = "HEAD:b9d6a5d9931922558046d230c1f5f4ef6ee72345"
meta-toradex-demos = "HEAD:b5f15cefa15f1c9ef6aad6f594cb168dd531f3ec"
meta-qt5 = "HEAD:eb828418264a49b8d00035cb3d7b12fcea3be801"
meta-tpm = "HEAD:bc865c5276c2ab4031229916e8d7c20148dfbac3"
meta-toradex-distro = "HEAD:3ce5c481bafafd22130d58b01091d355fe95944f"
meta-poky = "HEAD:03c7935bcdb15fd903d26828085d49c00267b8d9"
meta = "HEAD:c74a6d6afc52606825e583cae1162e13a5369498"
If it doesn’t look the same, I recommend to do a clean build following the suggestions from @ToradexAI.
I encountered this same issue where the Yocto build process would hang during the “Parsing recipes” step.
Upon investigation, I found that a bug related to pyenv and Yocto git scripts was leading to an infinite loop. This behavior is documented in this pyenv bug report.
To resolve this, you can either uninstall pyenv or implement one of the workarounds suggested in the bug report, such as using pyenv with a different Python 3 version. Hope this helps!
