I tried to create an ApolloX TCB project that rebuilds the “TorizonCore with Evaluation Container” 6.3.0-devel-202305+build.7.container for Verdin iMX8M-Plus.
- I cloned
linuxanddevice-treesrepos as described here - I downloaded the binaries of TorizonCore from the above link and I installed it on the SoM
- I copied
docker-compose.yamlfrom the SoM into TCB project on my PC - I changed
tcbuild.yamlin this way (I suppose it is how it should be to build “TorizonCore with Evaluation Container”, but I added theverdin-imx8mp_hmp_overlay.dtsoverlay too)
# Documentation https://developer.toradex.com/torizon/os-customization/torizoncore-builder-workflow/#customizing-the-configuration-file
# Configuration file outline:
# ⚠️ Mouse hover to the properties to see documentation
# ⚠️ ctrl+space inside a object or property to get the autocompletion tips
input:
# Input section items (required).
# ⚠️ change it for your needs
easy-installer:
toradex-feed:
version: "6.3.0"
release: monthly
machine: verdin-imx8mp
distro: torizon
variant: torizon-core-docker
build-number: 7
build-date: 202305
customization:
# Customization section items.
splash-screen: splashScreen.png
device-tree:
include-dirs:
- linux/include
custom: linux/arch/arm64/boot/dts/freescale/imx8mp-verdin-wifi-dev.dts
overlays:
add:
- device-trees/overlays/verdin-imx8mp_hdmi_overlay.dts
- device-trees/overlays/verdin-imx8mp_dsi-to-hdmi_overlay.dts
- device-trees/overlays/verdin-imx8mp_spidev_overlay.dts
- device-trees/overlays/verdin-imx8mp_hmp_overlay.dts
output:
# Output section items (required).
easy-installer:
local: tcbhmp-TCB-CUSTOM3
bundle:
compose-file: docker-compose.yml
ostree:
branch: tcb-hmp
commit-subject: tcbhmp
- I run
tcb-buildtask from ApolloX and the image is built - when I install it on the SoM, it cannot boot with the error below:
Applying Overlay: verdin-imx8mp_hmp_overlay.dtbo
2503 bytes read in 2 ms (1.2 MiB/s)
13348705 bytes read in 43 ms (296.1 MiB/s)
11600629 bytes read in 38 ms (291.1 MiB/s)
Uncompressing Kernel Image
## Flattened Device Tree blob at 50200000
Booting using the fdt blob at 0x50200000
ERROR: Failed to allocate 0x3a000 bytes below 0x100000000.
device tree - allocation error
FDT creation failed!
resetting ...
and this is the issue reported here.
After the fixI can build the image.
Two questions:
- is my
tcbuild.yamlthe right one? - Is it possible to configure
tcbuild.yamlso thatfdt_highis set automatically during the build?
