Hi @avionics,
Thanks for the testing. So we now know that updating the bin is not enough, the .ko should be updated as well.
Ok, I will test if I can update the kernel modules alongside the binary, I’ll reply to you when I have something. About the LVDS though, I made a quick search and it appears that it’s possible to make it work on the downstream kernel, not the upstream. You will only need to activate the LVDS on your device tree.
Have you already tried that?
There is a reference on our website: Display Output, Resolution and Timings (Linux)
I’ve also find some tickets about this topic:
- Apalis TK1 LVDS Configuration
- Apalis-TK1 LVDS drive strength not set by device tree
- LVDS on Apalis TK1 and IXORA
Hiago.
