Apalis-TK1 LVDS drive strength not set by device tree
I have a couple of notes regarding the change:
included in BSP 2.8b4
The first issue is that currently the lvds-drive-strength property has been placed in the wrong device tree node, I’ve attached a patch that should fix the issue (it does for me).
The second issue is that NV_SOR_LANE4_DRIVE_CURRENT is still set fixed to 0x40, and this seems to cause artifacts if NV_SOR_LANE_DRIVE_CURRENT is set to a low current value (e.g. 0x04 = 1.6mA).
So with:
# grep DRIVE /sys/kernel/debug/tegra_sor/regs
NV_SOR_LANE_DRIVE_CURRENT(0)      04e  04040404
NV_SOR_LANE4_DRIVE_CURRENT(0)     050  00000004
I have no artifacts on the display, while with:
NV_SOR_LANE4_DRIVE_CURRENT(0)     050  00000040
I’m experiencing black horizontal lines on the display.
Please take a look at this issue.
Thanks,
Diego
Thank you for reporting the issue.
I’ve pushed a patch to our kernel git:
