Dear Support Team,
according to below articles, the rpmsg function works well on Apalis iMX8QM v1.0B with Ycoto Linux BSP 3.04, but when we upgrade to latest HW Apalis iMX8QM V1.1B with latest Ycoto Linux BSP Reference-Multimedia-Image-Tezi_5.0.0-build.3 (20201006), it doesn’t work.
Then after some investigation, compared with the “imx8qm-mek.dts” and “imx8qm-mek-rpmsg.dts” files, we dound toradex device tree didn’t enable rpmsg node and virtual channel by default, so we made below device tree modification to make m40 rpmsg work, it do works with m40 str_echo demo.
diff --git a/arch/arm64/boot/dts/freescale/imx8qm-apalis-eval.dtsi b/arch/arm64/boot/dts/freescale/imx8qm-apalis-eval.dtsi
index ffa90243f635..c9a477cdce9d 100644
--- a/arch/arm64/boot/dts/freescale/imx8qm-apalis-eval.dtsi
+++ b/arch/arm64/boot/dts/freescale/imx8qm-apalis-eval.dtsi
@@ -426,3 +426,10 @@
+&rpmsg0 {
+ status = "okay";
diff --git a/arch/arm64/boot/dts/freescale/imx8qm-apalis-v1.1.dtsi b/arch/arm64/boot/dts/freescale/imx8qm-apalis-v1.1.dtsi
index 09e05dbdf6cb..c9772d21999e 100644
--- a/arch/arm64/boot/dts/freescale/imx8qm-apalis-v1.1.dtsi
+++ b/arch/arm64/boot/dts/freescale/imx8qm-apalis-v1.1.dtsi
@@ -215,12 +215,12 @@
no-map;
reg = <0 0x95000000 0 0x400000>;
vdevbuffer: vdevbuffer {
compatible = "shared-dma-pool";
reg = <0 0x90400000 0 0x100000>;
no-map;
/* global autoconfigured region for contiguous allocations */
linux,cma {
@@ -293,6 +293,66 @@
status = "disabled";
+ reserved-memory {
+ #address-cells = <2>;
+ #size-cells = <2>;
+ ranges;
+ vdev0vring0: vdev0vring0@90000000 {
+ compatible = "shared-dma-pool";
+ reg = <0 0x90000000 0 0x8000>;
+ no-map;
+ vdev0vring1: vdev0vring1@90008000 {
+ reg = <0 0x90008000 0 0x8000>;
+ no-map;
+ vdev1vring0: vdev1vring0@90010000 {
+ reg = <0 0x90010000 0 0x8000>;
+ no-map;
+ vdev1vring1: vdev1vring1@90018000 {
+ reg = <0 0x90018000 0 0x8000>;
+ no-map;
+ vdevbuffer: vdevbuffer {
+ reg = <0 0x90400000 0 0x100000>;
+ no-map;
&adc0 {
but when we extend this similar configration to m41 like below, after deploying device tree file, the module doesn’t boot with memory allocation error, seems there is some memory conflict, could you help advice on how can we modify to make m41 rpmsg work?
+&rpmsg0 {
+ status = "okay";
+&rpmsg1 {
+ status = "okay";
no-map;
no-map;
linux,cma {
+ reserved-memory {
+ ranges;
+ no-map;
+ no-map;
+ no-map;
+ no-map;
+ no-map;
+ vdev2vring0: vdev0vring0@90100000 {
+ reg = <0 0x90100000 0 0x8000>;
+ no-map;
+ vdev2vring1: vdev0vring1@90108000 {
+ reg = <0 0x90108000 0 0x8000>;
+ no-map;
+ vdev3vring0: vdev1vring0@90110000 {
+ reg = <0 0x90110000 0 0x8000>;
+ no-map;
+ vdev3vring1: vdev1vring1@90118000 {
+ reg = <0 0x90118000 0 0x8000>;
+ no-map;
&adc0 {
the boot failure console log is as below:
U-Boot 2020.04-5.0.0+git.f432a8c81b75 (Sep 30 2020 - 13:56:53 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1B, Serial# 06738378
BuildInfo:
- SCFW 732e719a, SECO-FW 376e3c15, IMX-MKIMAGE 6745ccdc, ATF
- U-Boot 2020.04-5.0.0+git.f432a8c81b75
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
MMC: no card present
Scanning mmc 0:1...
Found U-Boot script /boot.scr
3655 bytes read in 16 ms (222.7 KiB/s)
## Executing script at 83100000
102464 bytes read in 22 ms (4.4 MiB/s)
Loading hdp firmware from 0x000000009c000000 offset 0x0000000000002000
Loading hdp firmware Complete
164451 bytes read in 36 ms (4.4 MiB/s)
14 bytes read in 19 ms (0 Bytes/s)
9805711 bytes read in 321 ms (29.1 MiB/s)
Uncompressed size: 23144960 = 0x1612A00
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
ERROR: Failed to allocate 0x4c000 bytes below 0xffe00000.
device tree - allocation error
FDT creation failed! hanging...### ERROR ### Please RESET the board ###
Thanks and Best Regards
Simon
