I downloaded the torizon-core image manually and delivered via USB Apalis-iMX8_ToradexEasyInstaller_2.0b6-20201102 since only the pre-provisioned version seemed to be available on the EasyInstaller streams.
I manually change
Enable 2 wifi networks, one as subscriber, one in AP mode
disable docker-compose service and define a custom service that runs docker-compose from /var/sota/storage/docker-compose with additional StartPre and StopPos commands
Provision and install docker-compose.yml from Torizon OTA
I have observed nothing in journalctl that would explain this behaviour. The systems start up normally and nothing seems out of the ordinary and then spontaneously restart sometimes hours later. Adding a big fan on top of the heatsink made no difference, we also have a lot of Apalis iMX8 with a similar setup on TorizonCore 1.5.1 that will run without a fan for weeks. Increasing the uptane polling_period seemed to reduce the reset frequency a little bit, but even at polling_period=300-1800 they will reset after 6-7 hours
Is there any known issue with torizon-core-docker-rt-apalis-imx8-Tezi_5.3.0+build.7 that might be related? 1.5.3-build7 is in my understanding the latest available quarterly release for docker-rt without pre-provisioned containers.
Is there a chance that no using the RT version might change anything in this regard? Our application is not currently using RT functionality but might in the future.
Just found IMX8 apalis is not booting up - #20 by oklemencic with might be related, is there any way to identify by serial number whether a Ixora v1.2 might be affected? I have carrier boards from various production batches available here.
How much is your hat interface board consuming? Though Ixora 1.2 has an increased power supply ampacity you still can overload it if additional peripheral connected.
There is nothing on the interface board that loads the Ixora supply, the Ixora is actually supplied 12V from the hat. only a couple of serial interfaces that are supplied separately and a short-term back-up power supply if power should drop out.
Even when supplying 12V directly from a lab supply it reboots sometimes.
We are using Apalis IMX8QM 4GB WiFi/IT V1.1C at the moment.
I was able to solve the issue in the meantime. The solution was to use version without PREEMPT_RT applied. All problems disappeared when switching from torizon-core-docker-rt-apalis-imx8-Tezi_5.3.0+build.7 to torizon-core-docker-apalis-imx8-Tezi_5.3.0+build.7.
We have not found the underlying cause of the intermittent reset when flashing the docker-rt variant. Hope this is helpful.
Hi @grafue, thanks for sharing-- glad to hear it’s not just me. I am using a very similar setup to you (same Apalis IMX8QM SOM version, Ixora carrier board, etc.) and I experienced the same rebooting issue when using the RT TorizonCore image. Sometimes it would last up to 12 hours before a reboot. Other times it reboot every 10 minutes. Most of the time the system was just sitting idle, not running any application code. I lived with the issue for several months. Like you, my problem went away after switching to the non-real-time kernel. (Right now I’m at 18 days of uptime, so that’s a good sign!) Unfortunately I wasn’t able to make any progress at figuring out the root cause (and my motivation is low because my application does not have strict real-time requirements). Just wanted to share so you’d know it affects more people!
Yes those steps should suffice to reproduce @jeremias.tx . As discussed in my initial post I also apply some manual changes and overlays and replace the default docker-compose service but between @dcullen and me it sounds like even the bare install should trigger the issue with this hardware combo. Can confirm that sometimes is appears more often, sometimes takes a long time - nothing obvious that influences the frequency.
One important point to make is that I did not flash our systems from EasyInstaller but downloaded the image manually from the server, maybe there is something wrong in the Release/tagging process there.
I have not used any BSPs other than Torizon so I know nothing about reboot issues in those circumstances.
Yes, those steps look correct. I had hoped to give you some specific version information so I dug through my notes. I definitely experienced the issue with this nightly build:
“TorizonCore with evaluation containers (PREEMPT_RT)” 5.3.0-devel-2021-06+build.14.container
I later switched to a quarterly release (5.3.0+build.7.container I believe) in hopes of resolving it but still experienced the same behavior. Unfortunately my notes don’t have any more detailed than that.
Also, I have not tried try running the RT Reference BSP. (I’ve dabbled with the non-real-time Reference BSP, but not the RT version. For what it’s worth, I’m happy to report that the non-real-time version gave me no issues.)
A few more observations:
Like @grafue, there has been no obvious relationship between my activities on the device and the frequency of the reboots.
I have used various device tree overlays and various docker-compose services, but none of that seems to correlate with the frequency of reboots.
Like @grafue, I also first assumed a power supply issue, but tried a couple options and the issue persisted. In fact, now that I think about it, I’m pretty sure I also observed this issue with the Apalis Evaluation Board, in addition to the Ixora Carrier Board.
Thank you to you both for the reports and additional information regarding this issue. I think I have enough information to bring this forward internally. I’ll see if we can do some testing on the real-time images leading up to this next quarterly release of TorizonCore.
If either of you have any additional information about this issue, please continue to comment in this thread here.
Unfortunately after some testing we have not been able to reproduce this issue yet. In our tests we’ve done the following:
Flash an Apalis i.MX8QM with TorizonCore Preempt-RT image (5.4 nightly).
Instead of just leaving the module running idle, we decided to run a RT stress tests to simulate some load on the device.
Left device running with stress test, unattended, observing occasionally to see if any reboot has occurred.
One of these tests ran for over 1 day straight with no reboots. It’d hard to say if there’s an underlying issue here or not. If there is, then it doesn’t seem to be very reproducible.
If possible I ask if both of you could try and reproduce this issue with a recent PREEMPT-RT nightly. I noticed when you both encountered this issue it seemed to be on version 5.3.0. If you could try 5.4.0 that would be appreciated. Furthermore when you run your tests, if you could only connect the bare minimum cables to the hardware to avoid any other factors.
Since we were unable to reproduce this I can only assume there might be some other factor in both of your setups. Perhaps power related? Or network possibly?
Please let me know if either of you discover any additional information that we can investigate further.
I am having the exact same issue mentioned here. My board will sometimes run for hours and sometimes just for a few minutes.
I am running:
TorizonCore with PREEMPT_RT 5.6.0+build.13
I am running only the carrier board and the SOM with the cable kit included power supply. Only connected via ethernet to a local LAN and the serial console port. No user applications are running.
Unfortunately we never got around to addressing this issue. It has been difficult for us to track down as it seems sporadic and hard to reproduce for us.
For further information what module of ours are you using here?
The setup was simply the RT evaluation container image installed with the easy installer. No user applications/images installed so the board was basically idle. I have since switch to the non RT kernel image and this runs perfectly.
For this application I do not need hard RT behavior. Hopefully you guys can figure out a fix I do have a future project I would love to use Toradex boards with that would require hard RT.
I have already switch to the non RT image and everything works as expected without random reboots.
@jeremias.tx Just looking to see if there is any update regarding this issue? I am also experiencing the same issue with this for the RT patch. I am about to test the non RT patch and will update to let you know if anything resolves using the non RT patch. but as the original issue states, there is no indicators for the reboot in journactl.
FYI: this is a custom yocto project based of kernel: 5.4.193-rt74-5.7.1-devel+git.b60d3160fd04 #1-TorizonCore SMP PREEMPT_RT
