But,unfortunately I couldnt get any video on the display(monitor).
I even tried to use some monitor , but I see nothing there.
I have also tried the tdx-reference-mulitmedia image,but it also dosnt work and same results.
There is nothing displayed on the screen, during U-Boot or in Linux boot even recovery boot with easy installer.
Hi
Thank you for answering
Carrier board: Apalis Evaluation board Rev.1.1
Core board:Apalis IMX8QM 4GB WB
I said no
Unfortunately i cant see anything
But i have terminal debug CommandLine and can load easy installer using recovery mode But there inst any video display
when i load Toradex Easy Installer 5.7.1+build.13 () and plugin DVI connector to display
i face bellow messages
U-Boot 2020.04-5.7.1+git.33bb8e968332 (Sep 06 2022 - 15:34:09 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.0B, Serial# 06540920
BuildInfo:
- SCFW 216a2c2e, SECO-FW c9de51c0, IMX-MKIMAGE 6a315dbc, ATF 2fa8c63
- U-Boot 2020.04-5.7.1+git.33bb8e968332
switch to partitions #0, OK
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for mfgtools
, using default environment
Run bootcmd_mfg: select_dt_from_module_version && fastboot 0
We are in is_imx8
Getting phy ctrl
Starting download of 3246 bytes
downloading of 3246 bytes finished
Starting download of 43 bytes
downloading of 43 bytes finished
Starting download of 106496 bytes
downloading of 106496 bytes finished
Starting download of 48235620 bytes
downloading of 48235620 bytes finished
## Executing script at 82e00000
Loading hdp firmware from 0x000000009c000000 offset 0x0000000000002000
Loading hdp firmware Complete
Bootargs: quiet video=LVDS-1:d video=HDMI-A-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall clk_ignore_unused pci=nomsi
## Loading kernel from FIT Image at 8a000000 ...
Using 'conf-imx8qm-apalis-eval.dtb' configuration
Trying 'kernel-1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x8a000108
Data Size: 10801175 Bytes = 10.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x96000000
Entry Point: 0x96000000
Hash algo: sha256
Hash value: 6c4c20cd3c58a7eef0789a58148836db02bfe1e6b5946d3779a1d67e88f51d93
Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 8a000000 ...
Trying 'ramdisk-1' ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x8ab9ca40
Data Size: 36052992 Bytes = 34.4 MiB
OS: Linux
Load Address: 0xa0000000
Entry Point: unavailable
Hash algo: sha256
Hash value: 17528c0a9da50e4511b5951bcad114877f44a6cfcfe60c1e3979e7b1ef955fbe
Loading ramdisk from 0x8ab9ca40 to 0xa0000000
## Loading fdt from FIT Image at 8a000000 ...
Trying 'fdt-imx8qm-apalis-eval.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x8aa4d238
Data Size: 167627 Bytes = 163.7 KiB
Load Address: 0x87000000
Hash algo: sha256
Hash value: 7329e3f897946b08753d339754887cb803bfb74780b091ea48eb6b6c96aaf40e
Loading fdt from 0x8aa4d238 to 0x87000000
Using 'conf-apalis-imx8_hdmi_overlay.dtbo' configuration
Trying 'fdt-apalis-imx8_hdmi_overlay.dtbo' fdt subimage
Data Start: 0x8ab9792c
Data Size: 2177 Bytes = 2.1 KiB
Load Address: 0x870f0000
Hash algo: sha256
Hash value: 75d00dae6d1d5de88ccd2ea8be1ba975496ee7a8d507eae6b5871089b4bd45f4
Loading fdt from 0x8ab9792c to 0x870f0000
Booting using the fdt blob at 0x87000000
Uncompressing Kernel Image
Loading Ramdisk to fb3ec000, end fd64e000 ... OK
Loading Device Tree to 00000000fb3c0000, end 00000000fb3ebe8e ... OK
Starting kernel ...
[ 0.146280] No BMan portals available!
[ 0.147483] No QMan portals available!
[ 0.776827] imx-audmix imx-audmix.0: failed to find SAI platform device
[ 0.872457] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 0.879986] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 1.320592] debugfs: Directory '59050000.sai' with parent 'apalis-imx8qm-sgtl5000' already present!
[ 1.342410] rtc-ds1307 4-0068: hctosys: unable to read the hardware clock
Running /etc/rc.local...
Starting udev
[ 2.393466] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 2.778772] debugfs: Directory '59090000.sai' with parent 'imx-audio-hdmi-tx' already present!
[ 2.787727] debugfs: File 'Capture' in directory 'dapm' already present!
System time was Thu Jan 1 00:00:02 UTC 1970.
Setting the System Clock using the Hardware Clock as reference...
hwclock: RTC_RD_TIME: Invalid argument
System Clock set. System local time is now Thu Jan 1 00:00:02 UTC 1970.
Tue Sep 6 15:47:08 UTC 2022
Saving the System Clock time to the Hardware Clock...
Hardware Clock updated to Tue Sep 6 15:47:08 UTC 2022.
[ 3.154427] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
# ip addr show
to display the Ethernet IP address(es) or use USB RNDIS at IP 192.168.11.1.
Check our documentation at:
https://developer.toradex.com/software/toradex-easy-installer
/ # [ 97.847505] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 97.854812] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 106.795179] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 108.000015] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
/ # [ 152.773679] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 152.781041] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 168.996458] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
[ 169.003792] [drm:cdns_hdmi_connector_get_modes] *ERROR* Invalid edid
Hello @hhami
Please note that the iMX8 SoM’s don’t have a VGA output. See section 5.6.4 of the Apalis data sheet for more information.
Regarding the DVI output, what kind of monitor are you using. If it is a DVI-A monitor it will not work, because the DVI connector in the evaluation board does not have the analog signal pins connected.
Have you tried to use the HDMI connection to check if that works?
Not sure if that helps, but for me the display worked when I connected the board to the monitor using a DVI-DVI cable, I initially tried with DVI-VGA cable but it didn’t work (same monitor).
