How to play DRM (Digital rights management) media on Apalis / Torizon system, like: Spotify
To play DRM-protected media like Spotify on your Apalis iMX8 with Torizon, you need to integrate the Widevine library into your application. Here are the steps you can follow to solve this problem:
  1. Ensure Widevine Library Availability: You need to include the Widevine library in your Docker container. This library might not be available in standard Torizon images, so you will likely need to create a custom Docker image that includes the Widevine library and its dependencies.
  2. Custom Docker Image: Modify your Dockerfile to install the necessary dependencies for Widevine support. You will need to obtain the Widevine library from a legitimate source and ensure compliance with any licensing agreements.
  3. Check for Existing Solutions: Look into the Torizon documentation and community forums for any existing Docker images or community-contributed solutions that include Widevine support. This could save you time and effort.
  4. Configuration: Make sure your application is configured to use the Widevine library. This may involve setting up the appropriate environment variables or configuration files required by the Spotify Web SDK and Web Playback SDK to access Widevine.
  5. Testing and Debugging: After integrating Widevine, thoroughly test the playback functionality. Debug any issues that arise during playback to ensure successful integration.
If you encounter difficulties, consider reaching out to the Toradex support team or community forums for specific guidance on integrating Widevine with Torizon on the Apalis iMX8.
Apalis IMX8 Evaluation board no video output (DVI or VGA).
