Thanks for the response.
Actually i want to know how to drive Toradex LVDS LCD with Apalis Imx.8 and Ixora Carrier board.
Please guide me how to fix the problem.
@rudhi.tx
I’m trying to configure the LVDS out on the imx8qm and HDMI together but facing some issues!!
I can’t configure the Toradex LVDS LCD Touch panle!!
Thank you in advance for your help.
Starting Weston, a Wayland…ositor, as a system service...
[ OK ] Started Hostname Service.
[ 9.191012] audit: type=1334 audit(1702905477.600:10): prog-id=13 op=LOAD
[ 9.198167] audit: type=1334 audit(1702905477.608:11): prog-id=14 op=LOAD
Starting User Database Manager...
[ OK ] Started User Database Manager.
[ OK ] Created slice User Slice of UID 0.
Starting User Runtime Directory /run/user/0...
[ OK ] Finished User Runtime Directory /run/user/0.
Starting User Manager for UID 0...
[ OK ] Started User Manager for UID 0.
[ OK ] Started Session c1 of User root.
[FAILED] Failed to start Weston, a …mpositor, as a system service.
See 'systemctl status weston.service' for details.
[DEPEND] Dependency failed for Start a wayland application.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
TDX Wayland with XWayland 6.4.0+build.8 (kirkstone) apalis-imx8-07306835 -
Apalis-iMX8_Reference-Multimedia-Image
apalis-imx8-07306835 login:
Thanks for sending the logs.
Regarding the issue with not getting the HDMI and LVDS display working together with your SoM: This is a known issue from our side. To gather more information on that, please get in contact with your account manager.
About the issue with failed Weston service: If you enable just the overlay for LVDS display (apalis-imx8_panel-cap-touch-10inch-lvds_overlay.dtb) as you already did, this service should not fail and you should be able to see the output on the display. This works fine with our reference multimedia image (I tested specifically on version 6.4.0+build.8). I would recommend you try this again from scratch by installing a multimedia image on your module.
[ 10.516479] audit: type=1334 audit(1702913569.284:10): prog-id=13 op=LOAD
[ 10.523705] audit: type=1334 audit(1702913569.292:11): prog-id=14 op=LOAD
Starting User Database Manager...[ 10.531992] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
and end of it tired_face:
root@apalis-imx8:~# systemctl status weston.service
x weston.service - Weston, a Wayland compositor, as a system service
Loaded: loaded (/lib/systemd/system/weston.service; enabled; vendor >
Active: failed (Result: exit-code) since Mon 2023-12-18 15:32:50 UTC>
TriggeredBy: * weston.socket
Docs: man:weston(1)
man:weston.ini(5)
http://wayland.freedesktop.org/
Process: 835 ExecStart=/usr/bin/weston --modules=systemd-notify.so (c>
Main PID: 835 (code=exited, status=1/FAILURE)
Dec 18 15:32:49 apalis-imx8 systemd[1]: Starting Weston, a Wayla>
Dec 18 15:32:50 apalis-imx8 systemd[1]: weston.service: Main pro>
Dec 18 15:32:50 apalis-imx8 systemd[1]: weston.service: Failed w>
Dec 18 15:32:50 apalis-imx8 systemd[1]: Failed to start Weston, >
root@apalis-imx8:~#
Also can you share dts file of precompiled dtbo(apalis-imx8_panel-cap-touch-10inch-lvds_overlay)??
Please guide me how to fix the problem!
Thanks.
Are you using an LVDS display you bought from Toradex?
Have you made any customizations to the image (for example, modified the device tree) that you are using? In that case, can you reflash the module with a new multimedia image from the Toradex Easy Installer feeds and test the display with that?
