Thanks @henrique.tx
Waiting for a response for the issue.
Here is a strange finding in one of startups. It started with no screens. There was no light or anything on the screens.
And there are FAILED and DEPEND states at startup log.
There is no screen device under “/sys/class/drm/”
It might be related to weston.service.
Added a log, that I found might be usable.
[ OK ] Reached target Bluetooth Support.
[ OK ] Started User Manager for UID 0.
[ OK ] Started Session c1 of User root.
[FAILED] Failed to start Weston, a …mpositor, as a system service.
See ‘systemctl status weston.service’ for details.
[DEPEND] Dependency failed for Start a wayland application.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP…
[ OK ] Finished Record Runlevel Change in UTMP.TDX Wayland with XWayland 6.5.0-devel-202312+build.16 (kirkstone) apalis-imx8-07107600 -
Apalis-iMX8_Reference-Multimedia-Imageapalis-imx8-07107600 login: [ 12.519222] fec 5b040000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 12.527246] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes readyapalis-imx8-07107600 login:
apalis-imx8-07107600 login: root
root@apalis-imx8-07107600:~# ls /sys/class/drm/
card0 renderD128 version
root@apalis-imx8-07107600:~# systemctl status weston.service
x weston.service - Weston, a Wayland compositor, as a system service
Loaded: loaded (/lib/systemd/system/weston.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2022-04-28 18:42:44 UTC; 1min 29s ago
TriggeredBy: * weston.socket
Docs: man:weston(1)
man:weston.ini(5)
http://wayland.freedesktop.org/
Process: 873 ExecStart=/usr/bin/weston --modules=systemd-notify.so (code=exited, status=1/FAILURE)
Main PID: 873 (code=exited, status=1/FAILURE)Apr 28 18:42:43 apalis-imx8-07107600 systemd[1]: Starting Weston, a Wayland compositor, as a system service…
Apr 28 18:42:44 apalis-imx8-07107600 systemd[1]: weston.service: Main process exited, code=exited, status=1/FAILURE
Apr 28 18:42:44 apalis-imx8-07107600 systemd[1]: weston.service: Failed with result ‘exit-code’.
Apr 28 18:42:44 apalis-imx8-07107600 systemd[1]: Failed to start Weston, a Wayland compositor, as a system service.
Best regards
Ahmet
