Apalis I.MX6 Device Tree Overlay for UART2
Dear all,
We have made a custom carrier board base in Apalis eval board. Now we are creating a Device Tree Overlay to use UART2 without RTS and CTS lines, because we need those gpios for manages other things, so our idea is to only use TX and RX lines as they are defined in Device Tree “imx6q-apalis-eval.dts”
We have compiled our Device Tree Overlay and we are able to manage the MXM3_128 (MX6QDL_PAD_SD4_DAT6__UART2_RTS_B) and MXM3_130 (X6QDL_PAD_SD4_DAT5__UART2_CTS_B) as gpio, but the problem is that the UART2 is not receiving nor even transmitting anything.
If we do not load our Device Tree Overlay, the UART2 is receiving OK.
We are thinking that we have to modify the device tree because what we want, it is not possible from device tree overlay.
Do you have any ideas to test?. Thank you very much.
Our hardware is:
Apalis iMX6D 1GB IT
Custom board base in Apalis Eval Board v1.1
Linux apalis-imx6-10806407 6.1.22-6.2.0 (Reference image Apalis-iMX6_Reference-Multimedia-Image-upstream)
This is our Device Tree Overlay:
/dts-v1/;
/plugin/; //Indicates a Device Tree Overlay
// Header file with pin definitions
#include <imx6dl-pinfunc.h>
    compatible = "toradex,apalis_imx6q";// Set hardware compatibility
&pwm1 {
    status = "disabled";
&pwm2 {
&pwm3 {
&pwm4 {
 &uart2 {
    fsl,dte-mode;
    pinctrl-names = "default";
 	pinctrl-0 = <&pinctrl_uart2_dte2>;
&iomuxc {
    pinctrl-0 = <&pinctrl_gpio_custom>;  // Pin group available in userspace i.e. as GPIO
    pinctrl_gpio_custom: gpiocustom {
        fsl,pins = <
            MX6QDL_PAD_SD4_DAT5__GPIO2_IO13		0x130b0  /* SODIMM  128 */
            MX6QDL_PAD_SD4_DAT6__GPIO2_IO14     0x130b0  /* SODIMM  130 */
            MX6QDL_PAD_GPIO_9__GPIO1_IO09       0x130b0  /* SODIMM  2 */
            MX6QDL_PAD_GPIO_1__GPIO1_IO01       0x130b0  /* SODIMM  4 */
            MX6QDL_PAD_SD4_DAT1__GPIO2_IO09     0x130b0  /* SODIMM  6 */
            MX6QDL_PAD_SD4_DAT2__GPIO2_IO10     0x130b0  /* SODIMM  8 */
	/* DTE mode */
	pinctrl_uart2_dte2: uart2dtegrp {
		fsl,pins = <
			MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA	0x1b0b1
			MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA	0x1b0b1
Hi @aarribas !
Welcome to Toradex Community! :tada:
Please feel free to browse around :smiley:
From our device tree file imx6qdl-apalis.dtsi, you can see that we have the uart-has-rtscts property enabled:
Due to the Device Tree [Overlay] mechanism, you just can’t delete this property using a Device Tree Overlay.
Therefore you will need to create a new Device Tree file (not Overlay) to be able to remove the uart-has-rts-cts property from the uart2 node.
You should be able to use the delete-property instruction: Device Tree Technical Overview | Toradex Developer Center
Just to be clear: the delete-property (and the delete-node) instruction won’t work as expected in a Device Tree Overlay.
It is possible that using the delete-property on the uart-has-rtscts property will solve your issue.
It would be great if you could try it and let us know :slight_smile:
Btw, we have a very nice device tree documentation. Be sure to check it to learn more about Device Trees and Device Tree Overlays :wink:
Hello @henrique.tx,
I just modified the imx6qdl-apalis.dtsi file from Kernel and recompiled the the device tree for apalis eval board as indicated in your documentation.
Now I have the uart 2 configured as dte without rts and cts support. Also I can manage the gpios of rts and cts. Below is my modified file.
I am going to modified the device tree in this way to use several other peripheral as gpios, LCD, PWM…
 * Copyright 2014-2022 Toradex
 * Copyright 2012 Freescale Semiconductor, Inc.
 * Copyright 2011 Linaro Ltd.
#include <dt-bindings/pwm/pwm.h>
	model = "Toradex Apalis iMX6Q/D Module";
	compatible = "toradex,apalis_imx6q", "fsl,imx6q";
	/* Will be filled by the bootloader */
	memory@10000000 {
		device_type = "memory";
		reg = <0x10000000 0>;
	backlight: backlight {
		compatible = "pwm-backlight";
		brightness-levels = <0 45 63 88 119 158 203 255>;
		default-brightness-level = <4>;
		enable-gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&pinctrl_gpio_bl_on>;
		power-supply = <&reg_module_3v3>;
		pwms = <&pwm4 0 5000000 PWM_POLARITY_INVERTED>;
	clk_ov5640_osc: clk-ov5640-osc {
		compatible = "fixed-clock";
		#clock-cells = <0>;
		clock-frequency = <24000000>;
	gpio-keys {
		compatible = "gpio-keys";
		pinctrl-0 = <&pinctrl_gpio_keys>;
		key-wakeup {
			debounce-interval = <10>;
			gpios = <&gpio1 4 GPIO_ACTIVE_LOW>;
			label = "Wake-Up";
			linux,code = <KEY_WAKEUP>;
			wakeup-source;
	lcd_display: disp0 {
		compatible = "fsl,imx-parallel-display";
		#address-cells = <1>;
		#size-cells = <0>;
		interface-pix-fmt = "rgb24";
		pinctrl-0 = <&pinctrl_ipu1_lcdif>;
		port@0 {
			reg = <0>;
			lcd_display_in: endpoint {
				remote-endpoint = <&ipu1_di1_disp1>;
		port@1 {
			reg = <1>;
			lcd_display_out: endpoint {
				remote-endpoint = <&lcd_panel_in>;
	panel_dpi: panel-dpi {
		compatible = "edt,et057090dhu";
		backlight = <&backlight>;
		port {
			lcd_panel_in: endpoint {
				remote-endpoint = <&lcd_display_out>;
	panel_lvds: panel-lvds {
		compatible = "panel-lvds";
		port {
			lvds_panel_in: endpoint {
				remote-endpoint = <&lvds0_out>;
	reg_module_3v3: regulator-module-3v3 {
		compatible = "regulator-fixed";
		regulator-always-on;
		regulator-max-microvolt = <3300000>;
		regulator-min-microvolt = <3300000>;
		regulator-name = "+V3.3";
	reg_module_3v3_audio: regulator-module-3v3-audio {
		regulator-name = "+V3.3_AUDIO";
	reg_ov5640_1v8_d_o_vdd: regulator-ov5640-1v8-d-o-vdd {
		regulator-max-microvolt = <1800000>;
		regulator-min-microvolt = <1800000>;
		regulator-name = "DOVDD/DVDD_1.8V";
		/* Note: The CSI module uses on-board 3.3V_SW supply */
		vin-supply = <&reg_module_3v3>;
	reg_ov5640_2v8_a_vdd: regulator-ov5640-2v8-a-vdd {
		regulator-max-microvolt = <2800000>;
		regulator-min-microvolt = <2800000>;
		regulator-name = "AVDD/AFVDD_2.8V";
	reg_usb_otg_vbus: regulator-usb-otg-vbus {
		enable-active-high;
		gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&pinctrl_regulator_usbotg_pwr>;
		regulator-max-microvolt = <5000000>;
		regulator-min-microvolt = <5000000>;
		regulator-name = "usb_otg_vbus";
	/* on module USB hub */
	reg_usb_host_vbus_hub: regulator-usb-host-vbus-hub {
		enable-active-high;
		gpio = <&gpio3 28 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&pinctrl_regulator_usbhub_pwr>;
		regulator-name = "usb_host_vbus_hub";
		startup-delay-us = <2000>;
	reg_usb_host_vbus: regulator-usb-host-vbus {
		enable-active-high;
		gpio =  <&gpio1 0 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&pinctrl_regulator_usbh_pwr>;
		regulator-name = "usb_host_vbus";
		vin-supply = <&reg_usb_host_vbus_hub>;
	sound {
		compatible = "fsl,imx-audio-sgtl5000";
		audio-codec = <&codec>;
		audio-routing =
			"LINE_IN", "Line In Jack",
			"MIC_IN", "Mic Jack",
			"Mic Jack", "Mic Bias",
			"Headphone Jack", "HP_OUT";
		model = "imx6q-apalis-sgtl5000";
		mux-ext-port = <4>;
		mux-int-port = <1>;
		ssi-controller = <&ssi1>;
	sound_spdif: sound-spdif {
		compatible = "fsl,imx-audio-spdif";
		spdif-controller = <&spdif>;
		spdif-in;
		spdif-out;
		model = "imx-spdif";
&audmux {
	pinctrl-0 = <&pinctrl_audmux>;
&can1 {
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&pinctrl_flexcan1_default>;
	pinctrl-1 = <&pinctrl_flexcan1_sleep>;
&can2 {
	pinctrl-0 = <&pinctrl_flexcan2_default>;
	pinctrl-1 = <&pinctrl_flexcan2_sleep>;
&clks {
	fsl,pmic-stby-poweroff;
/* Apalis SPI1 */
&ecspi1 {
	cs-gpios = <&gpio5 25 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&pinctrl_ecspi1>;
/* Apalis SPI2 */
&ecspi2 {
	cs-gpios = <&gpio2 26 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&pinctrl_ecspi2>;
&gpio1 {
	gpio-line-names = "MXM3_84",
			  "MXM3_4",
			  "MXM3_15/GPIO7",
			  "MXM3_96",
			  "MXM3_37",
			  "MXM3_17/GPIO8",
			  "MXM3_14",
			  "MXM3_12",
			  "MXM3_2",
			  "MXM3_184",
			  "MXM3_180",
			  "MXM3_178",
			  "MXM3_176",
			  "MXM3_188",
			  "MXM3_186",
			  "MXM3_160",
			  "MXM3_162",
			  "MXM3_150",
			  "MXM3_144",
			  "MXM3_154",
			  "MXM3_146",
			  "MXM3_72";
&gpio2 {
	gpio-line-names = "MXM3_148",
			  "MXM3_152",
			  "MXM3_156",
			  "MXM3_158",
			  "MXM3_1/GPIO1",
			  "MXM3_3/GPIO2",
			  "MXM3_5/GPIO3",
			  "MXM3_7/GPIO4",
			  "MXM3_95",
			  "MXM3_6",
			  "MXM3_8",
			  "MXM3_123",
			  "MXM3_126",
			  "MXM3_128",
			  "MXM3_130",
			  "MXM3_132",
			  "MXM3_253",
			  "MXM3_251",
			  "MXM3_283",
			  "MXM3_281",
			  "MXM3_279",
			  "MXM3_277",
			  "MXM3_243",
			  "MXM3_235",
			  "MXM3_231",
			  "MXM3_229",
			  "MXM3_233",
			  "MXM3_198",
			  "MXM3_275",
			  "MXM3_273",
			  "MXM3_207",
			  "MXM3_122";
&gpio3 {
	gpio-line-names = "MXM3_271",
			  "MXM3_269",
			  "MXM3_301",
			  "MXM3_299",
			  "MXM3_297",
			  "MXM3_295",
			  "MXM3_293",
			  "MXM3_291",
			  "MXM3_289",
			  "MXM3_287",
			  "MXM3_249",
			  "MXM3_247",
			  "MXM3_245",
			  "MXM3_286",
			  "MXM3_239",
			  "MXM3_35",
			  "MXM3_205",
			  "MXM3_203",
			  "MXM3_201",
			  "MXM3_116",
			  "MXM3_114",
			  "MXM3_262",
			  "MXM3_274",
			  "MXM3_124",
			  "MXM3_110",
			  "MXM3_120",
			  "MXM3_263",
			  "MXM3_265",
			  "MXM3_135",
			  "MXM3_261",
			  "MXM3_259";
&gpio4 {
	gpio-line-names = "",
			  "MXM3_194",
			  "MXM3_136",
			  "MXM3_134",
			  "MXM3_140",
			  "MXM3_138",
			  "MXM3_220",
			  "MXM3_18",
			  "MXM3_16",
			  "MXM3_214",
			  "MXM3_216",
			  "MXM3_164";
&gpio5 {
	gpio-line-names = "MXM3_159",
			  "MXM3_257",
			  "MXM3_200",
			  "MXM3_196",
			  "MXM3_204",
			  "MXM3_202",
			  "MXM3_191",
			  "MXM3_197",
			  "MXM3_77",
			  "MXM3_195",
			  "MXM3_221",
			  "MXM3_225",
			  "MXM3_223",
			  "MXM3_227",
			  "MXM3_209",
			  "MXM3_211",
			  "MXM3_118",
			  "MXM3_112",
			  "MXM3_187",
			  "MXM3_185";
&gpio6 {
	gpio-line-names = "MXM3_183",
			  "MXM3_181",
			  "MXM3_179",
			  "MXM3_177",
			  "MXM3_175",
			  "MXM3_173",
			  "MXM3_255",
			  "MXM3_83",
			  "MXM3_91",
			  "MXM3_13/GPIO6",
			  "MXM3_11/GPIO5",
			  "MXM3_79",
			  "MXM3_190",
			  "MXM3_193",
			  "MXM3_89";
&gpio7 {
			  "MXM3_99",
			  "MXM3_85",
			  "MXM3_217",
			  "MXM3_215";
&gpr {
	ipu1_csi0_mux {
		#size-cells = <0>;
		port@1 {
			reg = <1>;
			ipu1_csi0_mux_from_parallel_sensor: endpoint {
				remote-endpoint = <&adv7280_to_ipu1_csi0_mux>;
&fec {
	pinctrl-0 = <&pinctrl_enet>;
	phy-mode = "rgmii-id";
	phy-handle = <&ethphy>;
	phy-reset-duration = <10>;
	phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
	mdio {
		#size-cells = <0>;
		ethphy: ethernet-phy@7 {
			interrupt-parent = <&gpio1>;
			interrupts = <30 IRQ_TYPE_LEVEL_LOW>;
			reg = <7>;
&hdmi {
	pinctrl-0 = <&pinctrl_hdmi_ddc &pinctrl_hdmi_cec>;
/* I2C1_SDA/SCL on MXM3 209/211 (e.g. RTC on carrier board) */
&i2c1 {
	clock-frequency = <100000>;
	pinctrl-names = "default", "gpio";
	pinctrl-0 = <&pinctrl_i2c1>;
	pinctrl-1 = <&pinctrl_i2c1_gpio>;
	scl-gpios = <&gpio5 27 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
	sda-gpios = <&gpio5 26 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
	atmel_mxt_ts: touchscreen@4a {
		compatible = "atmel,maxtouch";
		/* These GPIOs are muxed with the iomuxc node */
		interrupt-parent = <&gpio6>;
		interrupts = <10 IRQ_TYPE_EDGE_FALLING>;	/* MXM3_11 */
		reg = <0x4a>;
		reset-gpios = <&gpio6 9 GPIO_ACTIVE_LOW>;	/* MXM3_13 */
 * PWR_I2C: power I2C to audio codec, PMIC, temperature sensor and
 * touch screen controller
&i2c2 {
	pinctrl-0 = <&pinctrl_i2c2>;
	pinctrl-1 = <&pinctrl_i2c2_gpio>;
	scl-gpios = <&gpio4 12 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
	sda-gpios = <&gpio4 13 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
	pmic: pmic@8 {
		compatible = "fsl,pfuze100";
		reg = <0x08>;
		regulators {
			sw1a_reg: sw1ab {
				regulator-boot-on;
				regulator-max-microvolt = <1875000>;
				regulator-min-microvolt = <300000>;
				regulator-ramp-delay = <6250>;
			sw1c_reg: sw1c {
				regulator-boot-on;
			sw3a_reg: sw3a {
				regulator-boot-on;
				regulator-max-microvolt = <1975000>;
				regulator-min-microvolt = <400000>;
			swbst_reg: swbst {
				regulator-boot-on;
				regulator-max-microvolt = <5150000>;
			snvs_reg: vsnvs {
				regulator-boot-on;
				regulator-max-microvolt = <3000000>;
				regulator-min-microvolt = <1000000>;
			vref_reg: vrefddr {
				regulator-boot-on;
			vgen1_reg: vgen1 {
				regulator-boot-on;
				regulator-max-microvolt = <1550000>;
				regulator-min-microvolt = <800000>;
			vgen2_reg: vgen2 {
				regulator-boot-on;
			vgen3_reg: vgen3 {
				regulator-boot-on;
			vgen4_reg: vgen4 {
				regulator-boot-on;
			vgen5_reg: vgen5 {
				regulator-boot-on;
			vgen6_reg: vgen6 {
				regulator-boot-on;
	codec: sgtl5000@a {
		compatible = "fsl,sgtl5000";
		#sound-dai-cells = <0>;
		clocks = <&clks IMX6QDL_CLK_CKO>;
		pinctrl-0 = <&pinctrl_sgtl5000>;
		reg = <0x0a>;
		VDDA-supply = <&reg_module_3v3_audio>;
		VDDIO-supply = <&reg_module_3v3>;
		VDDD-supply = <&vgen4_reg>;
	/* STMPE811 touch screen controller */
	stmpe811@41 {
		compatible = "st,stmpe811";
		blocks = <0x5>;
		id = <0>;
		interrupts = <10 IRQ_TYPE_LEVEL_LOW>;
		interrupt-controller;
		interrupt-parent = <&gpio4>;
		irq-trigger = <0x1>;
		pinctrl-0 = <&pinctrl_touch_int>;
		reg = <0x41>;
		/* 3.25 MHz ADC clock speed */
		st,adc-freq = <1>;
		/* 12-bit ADC */
		st,mod-12b = <1>;
		/* internal ADC reference */
		st,ref-sel = <0>;
		/* ADC conversion time: 80 clocks */
		st,sample-time = <4>;
		stmpe_ts: stmpe_touchscreen {
			compatible = "st,stmpe-ts";
			/* 8 sample average control */
			st,ave-ctrl = <3>;
			/* 7 length fractional part in z */
			st,fraction-z = <7>;
			 * 50 mA typical 80 mA max touchscreen drivers
			 * current limit value
			st,i-drive = <1>;
			/* 1 ms panel driver settling time */
			st,settling = <3>;
			/* 5 ms touch detect interrupt delay */
			st,touch-det-delay = <5>;
		stmpe_adc: stmpe_adc {
			compatible = "st,stmpe-adc";
			#io-channel-cells = <1>;
			/* forbid to use ADC channels 3-0 (touch) */
			st,norequest-mask = <0x0F>;
 * I2C3_SDA/SCL (CAM) on MXM3 pin 201/203 (e.g. camera sensor on carrier
 * board)
&i2c3 {
	pinctrl-0 = <&pinctrl_i2c3>;
	pinctrl-1 = <&pinctrl_i2c3_gpio>;
	scl-gpios = <&gpio3 17 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
	sda-gpios = <&gpio3 18 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
	adv_7280: adv7280@21 {
		compatible = "adi,adv7280";
		adv,force-bt656-4;
		pinctrl-0 = <&pinctrl_ipu1_csi0>;
		reg = <0x21>;
		port {
			adv7280_to_ipu1_csi0_mux: endpoint {
				bus-width = <8>;
				remote-endpoint = <&ipu1_csi0_mux_from_parallel_sensor>;
	ov5640_csi_cam: ov5640_mipi@3c {
		compatible = "ovti,ov5640";
		AVDD-supply = <&reg_ov5640_2v8_a_vdd>;
		DOVDD-supply = <&reg_ov5640_1v8_d_o_vdd>;
		DVDD-supply = <&reg_ov5640_1v8_d_o_vdd>;
		clock-names = "xclk";
		clocks = <&clks IMX6QDL_CLK_CKO2>;
		pinctrl-0 = <&pinctrl_cam_mclk>;
		powerdown-gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>;
		reg = <0x3c>;
		reset-gpios = <&gpio2 4 GPIO_ACTIVE_LOW>;
		port {
			ov5640_to_mipi_csi2: endpoint {
				clock-lanes = <0>;
				data-lanes = <1 2>;
				remote-endpoint = <&mipi_csi_from_ov5640>;
&ipu1_di1_disp1 {
	remote-endpoint = <&lcd_display_in>;
&ldb {
	lvds-channel@0 {
		port@4 {
			reg = <4>;
			lvds0_out: endpoint {
				remote-endpoint = <&lvds_panel_in>;
	lvds-channel@1 {
		fsl,data-mapping = "spwg";
		fsl,data-width = <18>;
		port@4 {
			reg = <4>;
			lvds1_out: endpoint {
&mipi_csi {
	#size-cells = <0>;
	port@0 {
		reg = <0>;
		mipi_csi_from_ov5640: endpoint {
			clock-lanes = <0>;
			data-lanes = <1 2>;
			remote-endpoint = <&ov5640_to_mipi_csi2>;
&pwm1 {
	pinctrl-0 = <&pinctrl_pwm1>;
&pwm2 {
	pinctrl-0 = <&pinctrl_pwm2>;
&pwm3 {
	pinctrl-0 = <&pinctrl_pwm3>;
&pwm4 {
	pinctrl-0 = <&pinctrl_pwm4>;
&spdif {
	pinctrl-0 = <&pinctrl_spdif>;
&ssi1 {
&uart1 {
	fsl,dte-mode;
	pinctrl-0 = <&pinctrl_uart1_dte_simple>;
	/* Delete the uart-has-rtscts property so these pins can be used as IO */
	/delete-property/fsl,uart-has-rtscts;
&uart2 {
	fsl,dte-mode;
	pinctrl-0 = <&pinctrl_uart2_dte_simple>;
&uart4 {
	fsl,dte-mode;
	pinctrl-0 = <&pinctrl_uart4_dte>;
&uart5 {
	fsl,dte-mode;
	pinctrl-0 = <&pinctrl_uart5_dte>;
&usbotg {
	pinctrl-0 = <&pinctrl_usbotg>;
/* MMC1 */
&usdhc1 {
	bus-width = <8>;
	cd-gpios = <&gpio4 20 GPIO_ACTIVE_LOW>;
	disable-wp;
	no-1-8-v;
	pinctrl-0 = <&pinctrl_usdhc1_4bit &pinctrl_usdhc1_8bit &pinctrl_mmc_cd>;
	vqmmc-supply = <&reg_module_3v3>;
/* SD1 */
&usdhc2 {
	bus-width = <4>;
	disable-wp;
	no-1-8-v;
	pinctrl-0 = <&pinctrl_usdhc2>;
/* eMMC */
&usdhc3 {
	bus-width = <8>;
	no-1-8-v;
	non-removable;
	pinctrl-0 = <&pinctrl_usdhc3>;
&weim {
&iomuxc {
	/* Mux the Apalis GPIOs */
	pinctrl-0 = <&pinctrl_apalis_gpio1 &pinctrl_apalis_gpio2
		     &pinctrl_apalis_gpio3 &pinctrl_apalis_gpio4
		     &pinctrl_apalis_gpio5 &pinctrl_apalis_gpio6
		     &pinctrl_apalis_gpio7 &pinctrl_apalis_gpio8
	pinctrl_apalis_gpio1: apalisgpio1grp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x130b0
	pinctrl_apalis_gpio2: apalisgpio2grp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x130b0
	pinctrl_apalis_gpio3: apalisgpio3grp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x130b0
	pinctrl_apalis_gpio4: apalisgpio4grp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x130b0
	pinctrl_apalis_gpio5: apalisgpio5grp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_RB0__GPIO6_IO10 0x130b0
	pinctrl_apalis_gpio6: apalisgpio6grp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_WP_B__GPIO6_IO09 0x130b0
	pinctrl_apalis_gpio7: apalisgpio7grp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x130b0
	pinctrl_apalis_gpio8: apalisgpio8grp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x130b0
	pinctrl_audmux: audmuxgrp {
		fsl,pins = <
			MX6QDL_PAD_DISP0_DAT20__AUD4_TXC	0x130b0
			MX6QDL_PAD_DISP0_DAT21__AUD4_TXD	0x130b0
			MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS	0x130b0
			MX6QDL_PAD_DISP0_DAT23__AUD4_RXD	0x130b0
	pinctrl_cam_mclk: cammclkgrp {
		fsl,pins = <
			/* CAM sys_mclk */
			MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x00b0
	pinctrl_ecspi1: ecspi1grp {
		fsl,pins = <
			MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x100b1
			MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x100b1
			MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x100b1
			/* SPI1 cs */
			MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x000b1
	pinctrl_ecspi2: ecspi2grp {
		fsl,pins = <
			MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x100b1
			MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x100b1
			MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x100b1
			/* SPI2 cs */
			MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x000b1
	pinctrl_enet: enetgrp {
		fsl,pins = <
			MX6QDL_PAD_ENET_MDIO__ENET_MDIO		0x100b0
			MX6QDL_PAD_ENET_MDC__ENET_MDC		0x100b0
			MX6QDL_PAD_RGMII_TXC__RGMII_TXC		0x10030
			MX6QDL_PAD_RGMII_TD0__RGMII_TD0		0x10030
			MX6QDL_PAD_RGMII_TD1__RGMII_TD1		0x10030
			MX6QDL_PAD_RGMII_TD2__RGMII_TD2		0x10030
			MX6QDL_PAD_RGMII_TD3__RGMII_TD3		0x10030
			MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL	0x10030
			MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK	0x100b0
			MX6QDL_PAD_RGMII_RXC__RGMII_RXC		0x1b030
			MX6QDL_PAD_RGMII_RD0__RGMII_RD0		0x1b030
			MX6QDL_PAD_RGMII_RD1__RGMII_RD1		0x1b030
			MX6QDL_PAD_RGMII_RD2__RGMII_RD2		0x1b030
			MX6QDL_PAD_RGMII_RD3__RGMII_RD3		0x1b030
			MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL	0x1b030
			/* Ethernet PHY reset */
			MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25	0x000b0
			/* Ethernet PHY interrupt */
			MX6QDL_PAD_ENET_TXD0__GPIO1_IO30	0x000b1
	pinctrl_flexcan1_default: flexcan1defgrp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x1b0b0
			MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x1b0b0
	pinctrl_flexcan1_sleep: flexcan1slpgrp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x0
			MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x0
	pinctrl_flexcan2_default: flexcan2defgrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x1b0b0
			MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x1b0b0
	pinctrl_flexcan2_sleep: flexcan2slpgrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x0
			MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x0
	pinctrl_gpio_bl_on: gpioblongrp {
		fsl,pins = <
			MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x1b0b0
	pinctrl_gpio_keys: gpio1io04grp {
		fsl,pins = <
			/* Power button */
			MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0
	pinctrl_hdmi_cec: hdmicecgrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0
	pinctrl_hdmi_ddc: hdmiddcgrp {
		fsl,pins = <
			MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL 0x4001b8b1
			MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA 0x4001b8b1
	pinctrl_i2c1: i2c1grp {
		fsl,pins = <
			MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1
			MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1
	pinctrl_i2c1_gpio: i2c1gpiogrp {
		fsl,pins = <
			MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x4001b8b1
			MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x4001b8b1
	pinctrl_i2c2: i2c2grp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1
			MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1
	pinctrl_i2c2_gpio: i2c2gpiogrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x4001b8b1
			MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x4001b8b1
	pinctrl_i2c3: i2c3grp {
		fsl,pins = <
			MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1
			MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1
	pinctrl_i2c3_gpio: i2c3gpiogrp {
		fsl,pins = <
			MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x4001b8b1
			MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x4001b8b1
	pinctrl_ipu1_csi0: ipu1csi0grp { /* parallel camera */
		fsl,pins = <
			MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12  0xb0b1
			MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13  0xb0b1
			MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14  0xb0b1
			MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15  0xb0b1
			MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16  0xb0b1
			MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17  0xb0b1
			MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18  0xb0b1
			MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19  0xb0b1
			MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0xb0b1
			MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC    0xb0b1
			MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC   0xb0b1
	pinctrl_ipu1_lcdif: ipu1lcdifgrp {
		fsl,pins = <
			MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK	0x61
			/* DE */
			MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15	0x61
			/* HSync */
			MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02	0x61
			/* VSync */
			MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03	0x61
			MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00	0x61
			MX6QDL_PAD_EIM_DA8__IPU1_DISP1_DATA01	0x61
			MX6QDL_PAD_EIM_DA7__IPU1_DISP1_DATA02	0x61
			MX6QDL_PAD_EIM_DA6__IPU1_DISP1_DATA03	0x61
			MX6QDL_PAD_EIM_DA5__IPU1_DISP1_DATA04	0x61
			MX6QDL_PAD_EIM_DA4__IPU1_DISP1_DATA05	0x61
			MX6QDL_PAD_EIM_DA3__IPU1_DISP1_DATA06	0x61
			MX6QDL_PAD_EIM_DA2__IPU1_DISP1_DATA07	0x61
			MX6QDL_PAD_EIM_DA1__IPU1_DISP1_DATA08	0x61
			MX6QDL_PAD_EIM_DA0__IPU1_DISP1_DATA09	0x61
			MX6QDL_PAD_EIM_EB1__IPU1_DISP1_DATA10	0x61
			MX6QDL_PAD_EIM_EB0__IPU1_DISP1_DATA11	0x61
			MX6QDL_PAD_EIM_A17__IPU1_DISP1_DATA12	0x61
			MX6QDL_PAD_EIM_A18__IPU1_DISP1_DATA13	0x61
			MX6QDL_PAD_EIM_A19__IPU1_DISP1_DATA14	0x61
			MX6QDL_PAD_EIM_A20__IPU1_DISP1_DATA15	0x61
			MX6QDL_PAD_EIM_A21__IPU1_DISP1_DATA16	0x61
			MX6QDL_PAD_EIM_A22__IPU1_DISP1_DATA17	0x61
			MX6QDL_PAD_EIM_A23__IPU1_DISP1_DATA18	0x61
			MX6QDL_PAD_EIM_A24__IPU1_DISP1_DATA19	0x61
			MX6QDL_PAD_EIM_D31__IPU1_DISP1_DATA20	0x61
			MX6QDL_PAD_EIM_D30__IPU1_DISP1_DATA21	0x61
			MX6QDL_PAD_EIM_D26__IPU1_DISP1_DATA22	0x61
			MX6QDL_PAD_EIM_D27__IPU1_DISP1_DATA23	0x61
	pinctrl_ipu2_vdac: ipu2vdacgrp {
		fsl,pins = <
			MX6QDL_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK 0xd1
			MX6QDL_PAD_DI0_PIN15__IPU2_DI0_PIN15       0xd1
			MX6QDL_PAD_DI0_PIN2__IPU2_DI0_PIN02        0xd1
			MX6QDL_PAD_DI0_PIN3__IPU2_DI0_PIN03        0xd1
			MX6QDL_PAD_DISP0_DAT0__IPU2_DISP0_DATA00   0xf9
			MX6QDL_PAD_DISP0_DAT1__IPU2_DISP0_DATA01   0xf9
			MX6QDL_PAD_DISP0_DAT2__IPU2_DISP0_DATA02   0xf9
			MX6QDL_PAD_DISP0_DAT3__IPU2_DISP0_DATA03   0xf9
			MX6QDL_PAD_DISP0_DAT4__IPU2_DISP0_DATA04   0xf9
			MX6QDL_PAD_DISP0_DAT5__IPU2_DISP0_DATA05   0xf9
			MX6QDL_PAD_DISP0_DAT6__IPU2_DISP0_DATA06   0xf9
			MX6QDL_PAD_DISP0_DAT7__IPU2_DISP0_DATA07   0xf9
			MX6QDL_PAD_DISP0_DAT8__IPU2_DISP0_DATA08   0xf9
			MX6QDL_PAD_DISP0_DAT9__IPU2_DISP0_DATA09   0xf9
			MX6QDL_PAD_DISP0_DAT10__IPU2_DISP0_DATA10  0xf9
			MX6QDL_PAD_DISP0_DAT11__IPU2_DISP0_DATA11  0xf9
			MX6QDL_PAD_DISP0_DAT12__IPU2_DISP0_DATA12  0xf9
			MX6QDL_PAD_DISP0_DAT13__IPU2_DISP0_DATA13  0xf9
			MX6QDL_PAD_DISP0_DAT14__IPU2_DISP0_DATA14  0xf9
			MX6QDL_PAD_DISP0_DAT15__IPU2_DISP0_DATA15  0xf9
	pinctrl_mmc_cd: mmccdgrp {
		fsl,pins = <
			 /* MMC1 CD */
			MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x000b0
	pinctrl_pwm1: pwm1grp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_9__PWM1_OUT 0x1b0b1
	pinctrl_pwm2: pwm2grp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_1__PWM2_OUT 0x1b0b1
	pinctrl_pwm3: pwm3grp {
		fsl,pins = <
			MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1
	pinctrl_pwm4: pwm4grp {
		fsl,pins = <
			MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x1b0b1
	pinctrl_regulator_usbh_pwr: regusbhpwrgrp {
		fsl,pins = <
			/* USBH_EN */
			MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x0f058
	pinctrl_regulator_usbhub_pwr: regusbhubpwrgrp {
		fsl,pins = <
			/* USBH_HUB_EN */
			MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x0f058
	pinctrl_regulator_usbotg_pwr: regusbotgpwrgrp {
		fsl,pins = <
			/* USBO1 power en */
			MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x0f058
	pinctrl_reset_moci: resetmocigrp {
		fsl,pins = <
			/* RESET_MOCI control */
			MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x0f058
	pinctrl_sd_cd: sdcdgrp {
		fsl,pins = <
			/* SD1 CD */
			MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x000b0
	pinctrl_sgtl5000: sgtl5000grp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_5__CCM_CLKO1	0x130b0
	pinctrl_spdif: spdifgrp {
		fsl,pins = <
			MX6QDL_PAD_GPIO_16__SPDIF_IN  0x1b0b0
			MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x1b0b0
	pinctrl_touch_int: touchintgrp {
		fsl,pins = <
			/* STMPE811 interrupt */
			MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x1b0b0
	/* Additional DTR, DSR, DCD */
	pinctrl_uart1_ctrl: uart1ctrlgrp {
		fsl,pins = <
			MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x1b0b0
			MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x1b0b0
			MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x1b0b0
	pinctrl_uart1_dce: uart1dcegrp {
		fsl,pins = <
			MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1
			MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1
	/* DTE mode */
	pinctrl_uart1_dte: uart1dtegrp {
		fsl,pins = <
			MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x1b0b1
			MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x1b0b1
			MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x1b0b1
			MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x1b0b1
	/* DTE mode simple */
	pinctrl_uart1_dte_simple: uart1dtesimgrp {
		fsl,pins = <
	pinctrl_uart2_dce: uart2dcegrp {
		fsl,pins = <
			MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA	0x1b0b1
			MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA	0x1b0b1
	/* DTE mode */
	pinctrl_uart2_dte: uart2dtegrp {
		fsl,pins = <
			MX6QDL_PAD_SD4_DAT6__UART2_RTS_B	0x1b0b1
			MX6QDL_PAD_SD4_DAT5__UART2_CTS_B	0x1b0b1
	pinctrl_uart2_dte_simple: uart2dtesimgrp {
		fsl,pins = <
	pinctrl_uart4_dce: uart4dcegrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x1b0b1
			MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x1b0b1
	/* DTE mode */
	pinctrl_uart4_dte: uart4dtegrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL0__UART4_RX_DATA 0x1b0b1
			MX6QDL_PAD_KEY_ROW0__UART4_TX_DATA 0x1b0b1
	pinctrl_uart5_dce: uart5dcegrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL1__UART5_TX_DATA 0x1b0b1
			MX6QDL_PAD_KEY_ROW1__UART5_RX_DATA 0x1b0b1
	/* DTE mode */
	pinctrl_uart5_dte: uart5dtegrp {
		fsl,pins = <
			MX6QDL_PAD_KEY_COL1__UART5_RX_DATA 0x1b0b1
			MX6QDL_PAD_KEY_ROW1__UART5_TX_DATA 0x1b0b1
	pinctrl_usbotg: usbotggrp {
		fsl,pins = <
			MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x17059
	pinctrl_usdhc1_4bit: usdhc1-4bitgrp {
		fsl,pins = <
			MX6QDL_PAD_SD1_CMD__SD1_CMD    0x17071
			MX6QDL_PAD_SD1_CLK__SD1_CLK    0x10071
			MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17071
			MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17071
			MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17071
			MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17071
	pinctrl_usdhc1_8bit: usdhc1-8bitgrp {
		fsl,pins = <
			MX6QDL_PAD_NANDF_D0__SD1_DATA4 0x17071
			MX6QDL_PAD_NANDF_D1__SD1_DATA5 0x17071
			MX6QDL_PAD_NANDF_D2__SD1_DATA6 0x17071
			MX6QDL_PAD_NANDF_D3__SD1_DATA7 0x17071
	pinctrl_usdhc2: usdhc2grp {
		fsl,pins = <
			MX6QDL_PAD_SD2_CMD__SD2_CMD    0x17071
			MX6QDL_PAD_SD2_CLK__SD2_CLK    0x10071
			MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17071
			MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17071
			MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17071
			MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17071
	pinctrl_usdhc3: usdhc3grp {
		fsl,pins = <
			MX6QDL_PAD_SD3_CMD__SD3_CMD    0x17059
			MX6QDL_PAD_SD3_CLK__SD3_CLK    0x10059
			MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059
			MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059
			MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059
			MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059
			MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059
			MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059
			MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059
			MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059
			/* eMMC reset */
			MX6QDL_PAD_SD3_RST__SD3_RESET  0x17059
Hi @aarribas!
Thanks for the feedback!
It is great to know that it worked for you :smiley:
Please don’t forget to mark the suitable message as the Solution, so other users are aware of the solution :wink:
Have a nice day!
