Hi @Svetoslav ,
Yes, adding all the banks to the docker-compose worked. I can read all the pins except one.
The only issue right now is with GPIO bank 1, offset 2 (MXM3 pin 15). For some reason I get an error trying to read or write information on it in the following way gpiod_ctxless_get_value(“gpiochip0”, 2, false, “gpio-toggle”); .
For example with GPIO bank 1, offset 6 (MXM3 pin 17) I can read value with gpiod_ctxless_get_value(“gpiochip0”, 6, false, “gpio-toggle”);
I couldn’t find anything else on that pin so I think it’s not used for anything else so it should be readable.
Just checked here, and GPIO bank 1 offset 2 is being used by regulator-pcie-switch:
torizon@apalis-imx6-05064592:~$ docker run --rm -it --device /dev/gpiochip0 torizonextras/arm32v7-gpiod
root@b6745be831e9:/# gpioinfo
gpiochip0 - 32 lines:
line 0: "MXM3_84" "regulator-usb-host-vbus" output active-high [used]
line 1: "MXM3_4" unused input active-high
line 2: "MXM3_15/GPIO7" "regulator-pcie-switch" output active-high [used]
line 3: "MXM3_96" unused input active-high
line 4: "MXM3_37" unused input active-high
line 5: unnamed unused input active-high
line 6: "MXM3_17/GPIO8" unused input active-high
line 7: "MXM3_14" unused input active-high
line 8: "MXM3_12" unused input active-high
line 9: "MXM3_2" unused input active-high
line 10: "MXM3_184" unused input active-high
line 11: "MXM3_180" unused input active-high
line 12: "MXM3_178" unused input active-high
line 13: "MXM3_176" unused input active-high
line 14: "MXM3_188" unused input active-high
line 15: "MXM3_186" unused input active-high
line 16: "MXM3_160" unused input active-high
line 17: "MXM3_162" unused input active-high
line 18: "MXM3_150" unused input active-high
line 19: "MXM3_144" unused input active-high
line 20: "MXM3_154" unused input active-high
line 21: "MXM3_146" unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: "MXM3_72" unused input active-high
line 25: unnamed "phy-reset" output active-high [used]
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed "PCIe reset" output active-high [used]
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
So the information I passed to you in my last message is incorrect: by default GPIO 1 pin 2 is not available out-of-the-box. Sorry for the mistake, I’ll correct my previous post.
In this case there are a few options you can do:
Use another GPIO pin from the list I passed before: I tested all the pins there, and with the exception of GPIO 1 pin 2 all the others should work.
Use a Device Tree Overlay to disable the PCIe regulator in order to use the pin. Keep in mind that this will likely disable PCIe on the module. You can use TorizonCore Builder with the ‘build’ command to create a TorizonCore image with it. Details on how to do this can be seen here:
TorizonCore Builder Details
- On your (Linux) host machine, download the TorizonCore Builder setup script if you haven’t done so:
mkdir -p ~/tcbdir/ && cd ~/tcbdir/
wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
- Source the script to initialize TorizonCore Builder:
cd ~/tcbdir/
source tcb-env-setup.sh
- Inside
~/tcbdir, clone Linux and the overlay repositories for TorizonCore 6:
git clone -b linux-6.0.y git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git
git clone -b master git://git.toradex.com/device-tree-overlays.git device-trees
Inside
~/tcbdircreate a directory namedimages. Download TorizonCore 6.2 and put the .tar file in theimagesdirectory. -
Inside
~/tcbdircreate a file namedapalis-imx6_enable_gpio1_2_overlay.dtswith the following content:
/dts-v1/;
/plugin/;
compatible = "toradex,apalis_imx6q";
®_pcie_switch {
status = "disabled";
- Inside
~/tcbdircreate a file namedtcbuild.yamlwith the following content:
tcbuild.yaml
input:
easy-installer:
local: images/torizon-core-docker-apalis-imx6-Tezi_6.2.0+build.2.tar
customization:
device-tree:
include-dirs:
- linux/include/
overlays:
clear: false
add:
- apalis-imx6_enable_gpio1_2_overlay.dts
output:
easy-installer:
local: apalis_imx6_tc6.2_enable_gpio1_2
# >> Information used by Toradex Easy Installer:
name: "TorizonCore (UPSTREAM)"
description: "TorizonCore with GPIO1 pin 2 (MXM3 pin 15) enabled in Userspace"
- Inside
~/tcbdirruntorizoncore-builder build. It will generate a directory namedapalis_imx6_tc6.2_enable_gpio1_2. Copy this directory to a USB stick, plug it to your module then load the latest release of Toradex Easy Installer on your module (don’t use the stable release).
Lucas Akira
