i need the AzureWave AW-CM276NF to enable ap mode and with the ip i have to open a flask server using python and after that i hav to enable the device to be in station mode using ssid’s and password. eanbling both simultaneously
how can i do it ???
how can i do it ???
Hello!
To achieve your goal of enabling AP mode on the AzureWave AW-CM276NF module, setting up a Flask server, and then switching to station mode, you can follow these steps:
Enable AP Mode:
iw command to configure the Wi-Fi module in AP mode. Set the SSID and configure the IP address for the AP using hostapd to manage the AP settings.Set Up a Flask Server:
Switch to Station Mode:
nmcli (NetworkManager command-line tool) to connect to the specified Wi-Fi network with a command like:nmcli dev wifi connect "SSID" password "PASSWORD"
Simultaneous Operation:
By following these steps, you can configure your Toradex module to switch between AP and station modes while using a Flask server to manage the transition. Be sure to test each step thoroughly to handle any connectivity issues that may arise.
This topic is being answered here.
