We are working on a custom carrier board for the Aquila AM69. Attempting to bring up a Displayport panel and finding that the DP_AUX channel does not appear to be functional. During startup we see that HPD is correctly detected. The SW then indicates it can not read DP aux addr 0. But monitoring AUX P/N with an o-scope indicates no traffic on the bus.
Testing the same SW build and same SOM on the Aquilla V1.0 dev board works properly.
Do you have any suggestions on what might be the cause of non-functional AUX bus? Or ideas on how to debug this interface?
Have verified the HW wiring appears correct on Custom board. The Aux bus is a straight connection from Aquilla connector to eDP header.
DisplayPort AUX Channel Issues on Custom Aquila AM69 Carrier Board
Based on your description of the DisplayPort AUX channel not functioning on your custom carrier board while working correctly on the Aquila Development Board, here are several potential causes and debugging approaches:
Hardware Version Considerations
First, verify which version of the Aquila AM69 module you’re using(1). The V1.1A revision includes several important fixes that could affect DisplayPort functionality(1). Key hardware upgrades in V1.1A include:
Errata #1: Added a dedicated 25MHz crystal for the Ethernet PHY to solve clock jitter issues(1)
Errata #3: Series capacitors added on USB_2_SS_TX lines(1)
Errata #4: VBUS input voltage divider added for 5V tolerance(1)
Errata #5: CTRL_RESET_MICO# signal compliance fix(1)
DisplayPort Signal Requirements
According to the Aquila Carrier Board Design Guide, DisplayPort interfaces require specific signal handling(2). The MIPI DSI signals are documented with specific pin assignments(2):
DSI_1_D0_P/N through DSI_1_D3_P/N (A44/A43 through A32/A31)
Associated I2C and GPIO signals for control
Debugging Approaches
Signal Integrity Verification
Verify that your AUX P/N differential pair routing maintains proper impedance matching
Check for any series capacitors or termination resistors that might be missing or incorrect
Ensure the AUX channel routing length matches the reference design
Power Domain Analysis
Confirm all power domains are properly sequenced and stable
Verify that the DisplayPort power rails are within specification
Module Version Compatibility
If using V1.0A modules, consider the potential impact of the hardware errata mentioned above(1)
The V1.1A revision addresses several signal integrity issues that could indirectly affect DisplayPort operation(1)
Reference Design Comparison
Compare your custom carrier board schematic against the Aquila Development Board reference design
Pay particular attention to pull-up/pull-down resistors, termination, and signal routing
Software Considerations
The boot logs from similar DisplayPort issues show that the system attempts to read receiver capabilities and EDID data(3). The failure to read AUX address 0 with no oscilloscope activity suggests a hardware-level issue rather than a software configuration problem.
Recommended Next Steps
Hardware Audit: Perform a detailed comparison of your AUX channel implementation against the Aquila Development Board V1.3A reference design(1)
Module Version Check: Verify which Aquila AM69 module revision you’re using and consider the hardware errata impacts(1)
Signal Integrity Testing: Use proper differential probes to verify AUX signal integrity and timing
Power Analysis: Ensure all DisplayPort-related power domains are stable and within specification
The fact that the same software and module work correctly on the development board strongly suggests a hardware implementation difference on your custom carrier board.
We were able to solve our main issue (AUX reversed Polarity)
But in our testing we found that the Aux channel would not perform a read unless HPD was detected. We disabled HPD detect and the Aux read still did not occur. Debug messages in Linux seemed to indicate that a read had been attempted.
Is there a procedure that would force an AUX channel read regardless if the HPD is detected or not?
Glad you got it working. Talking with my colleagues, it may be possible to force the EDID, which would possibly bypass the need for reading the data from the display.
