I’ve been experimenting with offline updates for docker-compose on a Verdin IMX8MM using a slightly customized (mostly drivers and services) TorizonCore 5.7.0.
First, I had to edit platform.py in torizoncore-builder to allow me to login to Docker Hub and use private registries with torizoncore-builder platform lockbox. This works and I ensured the file is properly canonicalized via torizoncore-builder bundle, which does have support for private registries and creates a canonical docker-compose.yml.
Now, I am able to upload a docker-compose.lock.yml file in canonical format to Torizon OTA, create a lockbox via the web interface and then use torizoncore-builder platform lockbox to generate it. I copy it onto a USB stick, plug the stick into the test device, and the update is initiated. All goes well until it reaches a certain tarball/image, where aktualizr-torizon complains that it finds a file with bad file type: 40960, see below.
Aug 24 13:09:47 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Current version for ECU ID: 9c6306b589af7dc5fa471e189444102fd4355f16c6903cf7d97e9b7759e60baf is unknown
Aug 24 13:09:47 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Image already fetched; skipping fetching
Aug 24 13:09:47 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Event: DownloadTargetComplete, Result - Success
Aug 24 13:09:47 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Event: AllDownloadsComplete, Result - Success
Aug 24 13:09:47 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Waiting for Secondaries to connect to start installation...
Aug 24 13:09:48 verdin-imx8mm-06944460 aktualizr-torizon[1025]: No update to install on Primary
Aug 24 13:09:48 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Event: InstallStarted
Aug 24 13:09:48 verdin-imx8mm-06944460 aktualizr-torizon[1025]: docker-compose file matches expected digest
Aug 24 13:09:48 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/2f779b3fac92271738cfaa66067167e29a7c1dd9bddd5f92e53c2d9326c9b5f2.tar
Aug 24 13:10:45 verdin-imx8mm-06944460 aktualizr-torizon[1025]: PROXY: sending device data to Torizon OTA.
Aug 24 13:10:51 verdin-imx8mm-06944460 aktualizr-torizon[1049]: Loaded image: jabbla/allora3-bt:digest_sha256_2f779b3fac92271738cfaa66067167e29a7c1dd9bddd5f92e53c2d9326c9b5f2
Aug 24 13:10:51 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/2f779b3fac92271738cfaa66067167e29a7c1dd9bddd5f92e53c2d9326c9b5f2.tar" finished, code: 0, status: success
Aug 24 13:10:51 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/8a74d7d66f11c3c238294d5f023314802587f6131f2eeb13048b6a798d9e6d5a.tar
Aug 24 13:11:24 verdin-imx8mm-06944460 aktualizr-torizon[1067]: Loaded image: jabbla/allora3-hw:digest_sha256_8a74d7d66f11c3c238294d5f023314802587f6131f2eeb13048b6a798d9e6d5a
Aug 24 13:11:24 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/8a74d7d66f11c3c238294d5f023314802587f6131f2eeb13048b6a798d9e6d5a.tar" finished, code: 0, status: success
Aug 24 13:11:24 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76.tar
Aug 24 13:11:25 verdin-imx8mm-06944460 aktualizr-torizon[1084]: Loaded image: eclipse-mosquitto:digest_sha256_e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76
Aug 24 13:11:25 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76.tar" finished, code: 0, status: success
Aug 24 13:11:25 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/118c6159a1372ef165332409d9f151ca954c060a77ea174470d5955e871a04d0.tar
Aug 24 13:11:50 verdin-imx8mm-06944460 aktualizr-torizon[1096]: Loaded image: jabbla/allora3-skippy:digest_sha256_118c6159a1372ef165332409d9f151ca954c060a77ea174470d5955e871a04d0
Aug 24 13:11:50 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/118c6159a1372ef165332409d9f151ca954c060a77ea174470d5955e871a04d0.tar" finished, code: 0, status: success
Aug 24 13:11:50 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/b67eabdd265a17d6d8582df00487288193cf1d7555fc64bc00ef8f8a8a0a62f8.tar
Aug 24 13:12:15 verdin-imx8mm-06944460 aktualizr-torizon[1109]: Loaded image: jabbla/allora3-speech:digest_sha256_b67eabdd265a17d6d8582df00487288193cf1d7555fc64bc00ef8f8a8a0a62f8
Aug 24 13:12:15 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/b67eabdd265a17d6d8582df00487288193cf1d7555fc64bc00ef8f8a8a0a62f8.tar" finished, code: 0, status: success
Aug 24 13:12:15 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/72da2b96284cbd9f09457c4d42daf6faecc274cce8d4cafe70c8e6452b583ca8.tar
Aug 24 13:13:13 verdin-imx8mm-06944460 aktualizr-torizon[1124]: Loaded image: jabbla/allora3-web:digest_sha256_72da2b96284cbd9f09457c4d42daf6faecc274cce8d4cafe70c8e6452b583ca8
Aug 24 13:13:13 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/72da2b96284cbd9f09457c4d42daf6faecc274cce8d4cafe70c8e6452b583ca8.tar" finished, code: 0, status: success
Aug 24 13:13:13 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/5374677586f3df47994effc1e42c96bb66671ae3bdf31e58f09e6cfa7e73200a.tar
Aug 24 13:15:02 verdin-imx8mm-06944460 aktualizr-torizon[1147]: Loaded image: jabbla/allora3-kiosk:digest_sha256_5374677586f3df47994effc1e42c96bb66671ae3bdf31e58f09e6cfa7e73200a
Aug 24 13:15:02 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/5374677586f3df47994effc1e42c96bb66671ae3bdf31e58f09e6cfa7e73200a.tar" finished, code: 0, status: success
Aug 24 13:15:02 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/2aba5915c2eb9ef942225ce0f442cf7ff65d759d9323dfc1f8a837e5ccb5a7cf.tar
Aug 24 13:15:33 verdin-imx8mm-06944460 aktualizr-torizon[1163]: Loaded image: jabbla/siab:digest_sha256_2aba5915c2eb9ef942225ce0f442cf7ff65d759d9323dfc1f8a837e5ccb5a7cf
Aug 24 13:15:33 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of "/media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/2aba5915c2eb9ef942225ce0f442cf7ff65d759d9323dfc1f8a837e5ccb5a7cf.tar" finished, code: 0, status: success
Aug 24 13:15:33 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading metadata from tarball: /media/3F62-C968/images/5019ebc3d57b7a598011e9005f88bfdac3132ed722aaafd474713ef267f2a846.images/73aa9327063a85d943cf31471bb123a1b61b7fc4585111cd29f034f74db9026a.tar
Aug 24 13:15:33 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Found in archive a file with bad file type: 40960
Aug 24 13:15:53 verdin-imx8mm-06944460 aktualizr-torizon[1025]: validateMetadata: Key '00dcf3b16735f3d15ba4e800c155877470bacc7dab40e7cd3665b3ab316aced9/layer.tar' not found in metamap [RE]
Aug 24 13:15:53 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Loading of tarballs aborted!
Aug 24 13:15:53 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Offline loading failed: Failed to load docker tarball 73aa9327063a85d943cf31471bb123a1b61b7fc4585111cd29f034f74db9026a.tar
Aug 24 13:15:53 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Rolling back container update
Aug 24 13:15:53 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Running docker-compose up
Aug 24 13:15:53 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Running command: /usr/bin/docker-compose --file /var/sota/storage/docker-compose/docker-compose.yml -p torizon up --detach --remove-orphans
Aug 24 13:15:57 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-bt ...
Aug 24 13:15:57 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-skippy ...
Aug 24 13:15:57 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-hw ...
Aug 24 13:15:57 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-speech ...
Aug 24 13:15:57 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting weston ...
Aug 24 13:15:57 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-web ...
Aug 24 13:16:01 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-bt ... done
Aug 24 13:16:01 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting weston ... done
Aug 24 13:16:04 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-hw ... done
Aug 24 13:16:05 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-speech ... done
Aug 24 13:16:05 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-skippy ... done
Aug 24 13:16:05 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting allora3-web ... done
Aug 24 13:16:05 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting torizon_kiosk_1 ...
Aug 24 13:16:17 verdin-imx8mm-06944460 aktualizr-torizon[1208]: Starting torizon_kiosk_1 ... done
Aug 24 13:16:18 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Removing not used containers, networks and images
Aug 24 13:16:18 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Running command: docker system prune -a --force
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: Deleted Images:
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/allora3-skippy:digest_sha256_118c6159a1372ef165332409d9f151ca954c060a77ea174470d5955e871a04d0
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:4aeebc27283dc48db2242d256531849c0277b127b913b8c30daed7b046442c56
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:f38535c140b1a12029f4aad4a7c6178eb2743fcd442396c6440eab6b5c348f6c
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:1f075959c2211236bb079a540c63fdd88649ca7f8d8ca5093576967b805f5306
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:acc315818877c3ed4924b0a5f5216a7fc8e24738896266147a6b297c7bf61079
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:06b9633e09d4bafb21e9a226e5e732bdc51623e870271c530b9c6c4d1bbad620
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:434771d56f00a58eebc8e95eb7156aeab8ba51a6c997c47e034e4fe1bc190a7f
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:04e18b2d0288731256c0dc05f86bcebd7a0e225c2b0e0f70282b056699223d4f
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/allora3-web:digest_sha256_72da2b96284cbd9f09457c4d42daf6faecc274cce8d4cafe70c8e6452b583ca8
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:dc3535888313f5436892e204bd384fa51a261c5b3c661b43886578b5ee9c032d
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:d90c757936d655ced5da2b19e57a19d2e695fcf3e0ccbaf35817836a26add052
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:dd06a753b729b999ed9fbf91ce0c108078f6c545cb043c7c3ec737f4757eb80c
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:17d915a880862a9b5fa6aa44e148ac4f2a4459858ee09fb2a4bfb7762082816e
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:5b25f149b458ea0dd770488b1194953e4b07178968e62b7e68fde8519829b21b
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:3e7b2564f1f0bda37a22ac866eeb845d43095fb4e01f2e9b792f8f0423ab138d
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:9776ae3e25911df74a9f9d811c6985e56379de7dcbf1513189a2023c6b205262
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:b310c601a3dfbf093116d9d2868b9bb4cc828b940fffd62f861aa13b500aecc4
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:772553d587d2937f0bfff453fb1adc190b2434c71576b1b7e297b9621fa96bc8
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:067db400488d44fd50ac08c5e057c19aba6c5f52111bfb63f6f549d4331186dd
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:5b7df235d876e8cd4a2a329ae786db3fb152eff939f88379c49bcaaabbafbd9c
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: eclipse-mosquitto:digest_sha256_e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:3d0dec29d43434d0455eb0a93d0cd7bcad3933466a5874ccfc26698aec0a685a
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:48d7f38658cefe6311d9a6e2627a82006b89dfb5a17e04a69852a053fde1abb0
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:5c44969593ff4ea310dc55e63f9270bace55394ef22462b9b65c4c339d54fce7
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:62170e181a92ced0deb88df006382d43977c9fc1ee8463603224492435f72735
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/siab:digest_sha256_2aba5915c2eb9ef942225ce0f442cf7ff65d759d9323dfc1f8a837e5ccb5a7cf
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:8f0b6531c3ce0adadeab80690cbc40f27309201fdb985cdeb2e9b52247c70b27
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:0bb24ae95afb130ffe874750e2157a750981637a43fc83353aa9857ac0c35449
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:c721dd31bb9f1c03e1c74b13776b886039667192151be8a4cd3349f3a29506e9
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:a0140c9b31e93345f25532937f9ef63afa2d1b9607da132ad778f8c0be0a31dd
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:f3cad9f8ac1ee2f04e09db4d66d14c7806b881917a632bed9ae1117c6b10e1f9
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/allora3-kiosk:digest_sha256_5374677586f3df47994effc1e42c96bb66671ae3bdf31e58f09e6cfa7e73200a
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/allora3-bt:digest_sha256_2f779b3fac92271738cfaa66067167e29a7c1dd9bddd5f92e53c2d9326c9b5f2
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/allora3-hw:digest_sha256_8a74d7d66f11c3c238294d5f023314802587f6131f2eeb13048b6a798d9e6d5a
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: untagged: jabbla/allora3-speech:digest_sha256_b67eabdd265a17d6d8582df00487288193cf1d7555fc64bc00ef8f8a8a0a62f8
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:62f8d52e4a858f72acad9fd04fe0ffc3b0c172135372f9c307c4d69f618b50fb
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:8a60c3c2f2175ba8b66aabf00d3ab1162bc95f6bc11ada238301d6e974efaa99
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: deleted: sha256:2d5280ab2cb20552f16c4b764fe6e07d1204e5a0ec1a4df88d2feeb0a1185d38
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1837]: Total reclaimed space: 324.4MB
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Running command: fw_setenv rollback 1
Aug 24 13:16:26 verdin-imx8mm-06944460 aktualizr-torizon[1025]: Running command: reboot
I investigated this, and in that archive there is a layer.tar that symlinks to another. Aktualizr-torizon cannot deal with this symlink and expects only directories or files in the archive, but the symlink is generated by platform.py calling docker save. In the aktualizr-torizon source, in dockertarballloader.cc, the method loadMetadataEntry contains the following check:
// Ensure file type is good.
if (archive_entry_filetype(entry) != AE_IFREG && archive_entry_filetype(entry) != AE_IFDIR) {
LOG_WARNING << "Found in archive a file with bad file type: " << archive_entry_filetype(entry);
return false;
I guess docker does not always symlink when saving a tarball and therefore this situation simply didn’t occur before?
Is there a way to prevent docker/torizoncore-builder from creating these symlinks? In any case, I think the fix is that Aktualizr-Torizon should be prepared to handle the eventuality of a symlink.
Kind regards and thanks for reading,
Ernest Van Hoecke
