Hi @jeremias.tx,
Thanks for the timely reply.
I’ve performed each test in my original post with a fresh, but older, image, installed via TEZI. So the docker-compose file would not have been touched by an update yet, nor by anything else.
Yes, I only see this issue with synchronous updates. At first my concern was that the way I automate the lockbox creation on the Torizon Platform was wrong, since I just push both the OS and app update in a POST request without anything to indicate it’s a synchronous update. I can share this code if you want. But that’s the way I noticed my browser doing it also, and I’ve repeated all tests in the first post by manually initialising a lockbox on the platform and then generating it via TCB without any automation.
Yes, it happens every time. In fact, I’ve never gotten synchronous updates to work in the last few months. Even when I generate them from scratch. I will have to try different lockboxes generated from a different compose file. I’ve tested many lockboxes, but all with a similar compose file (just small edits as we update our applications, different mounts and permissions, an extra container, etc.).
I’ve used the same drive most of the time, but we have also used different drives to no avail. I’ve now reformatted the drive (FAT32 filesystem, same as before) and tried again, the same Unable to read filesystem statistics: error code -1
appears. But what’s interesting to me is that after the reboot, if I insert the drive again and the compose update begins, that error is not there. If it is a drive error, that surprises me. Relevant snippet from the start of that update procedure:
Sep 06 16:25:17 verdin-imx8mm-07218224 aktualizr-torizon[862]: Offline Updates are enabled
Sep 06 16:25:17 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: starting thread.
Sep 06 16:25:17 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: listening to connections...
Sep 06 16:30:21 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: unexpected error when waiting for data!
Sep 06 16:35:23 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: unexpected error when waiting for data!
Sep 06 16:40:25 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: unexpected error when waiting for data!
Sep 06 16:45:27 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: unexpected error when waiting for data!
Sep 06 16:50:29 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: unexpected error when waiting for data!
Sep 06 16:50:32 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: maximum epoll errors reached. Exiting thread!
Sep 06 16:50:32 verdin-imx8mm-07218224 aktualizr-torizon[862]: PROXY: sending device data to Torizon OTA.
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: fetchMetaOffUpd() called with source_path: "/media/JABBLA-USB/update/"
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: Current version for ECU ID: f82e870baba06082c7755214c4de4edd1bf68e37aa9609dba72b680feeefe95f is unknown
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: New updates found in Director metadata. Checking Image repo metadata...
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: 1 new update found in both Director and Image repo metadata.
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: Event: UpdateCheckComplete, Result - Updates available
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: Update available. Acquiring the update lock...
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: Image already fetched; skipping fetching
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: Event: DownloadTargetComplete, Result - Success
Sep 06 17:59:48 verdin-imx8mm-07218224 aktualizr-torizon[862]: Event: AllDownloadsComplete, Result - Success
Sep 06 17:59:49 verdin-imx8mm-07218224 aktualizr-torizon[862]: Waiting for Secondaries to connect to start installation...
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: No update to install on Primary
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Event: InstallStarted
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Reading config: "/etc/sota/conf.d/100-offline-updates.toml"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Reading config: "/usr/lib/sota/conf.d/20-sota-device-cred.toml"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Reading config: "/usr/lib/sota/conf.d/30-rollback.toml"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Reading config: "/usr/lib/sota/conf.d/40-hardware-id.toml"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Reading config: "/usr/lib/sota/conf.d/50-secondaries.toml"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Reading config: "/usr/lib/sota/conf.d/60-polling-interval.toml"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Use existing SQL storage: "/var/sota/sql.db"
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: docker-compose file matches expected digest
Sep 06 17:59:50 verdin-imx8mm-07218224 aktualizr-torizon[862]: Loading metadata from tarball: /media/JABBLA-USB/update/images/acabe145ed192ce110dbb32b832730cba19b5eac77034748e8e055caa630af41.images/66cd4908444fd0a62337b8b87493ec19855b0c72747a60415d8cdb7ddc1d96ab.tar
Sep 06 18:00:05 verdin-imx8mm-07218224 aktualizr-torizon[2992]: Loaded image: jabbla/allora3-bt:digest_sha256_66cd4908444fd0a62337b8b87493ec19855b0c72747a60415d8cdb7ddc1d96ab
Sep 06 18:00:06 verdin-imx8mm-07218224 aktualizr-torizon[862]: Loading of "/media/JABBLA-USB/update/images/acabe145ed192ce110dbb32b832730cba19b5eac77034748e8e055caa630af41.images/66cd4908444fd0a62337b8b87493ec19855b0c72747a60415d8cdb7ddc1d96ab.tar" finished, code: 0, status: success
Sep 06 18:00:06 verdin-imx8mm-07218224 aktualizr-torizon[862]: Loading metadata from tarball: /media/JABBLA-USB/update/images/acabe145ed192ce110dbb32b832730cba19b5eac77034748e8e055caa630af41.images/eb8a8af46ce73a26a6f7fd3f6eaa794cd6e51df85b640dc0bc6c77b7ecbec443.tar
I have now repeated the process many times, formatting the drive each time, starting from a clean TorizonCore image (preprovisioned for offline updates and with our other changes) and the behaviour is exactly the same. I created the lockbox from scratch now, just applying my symlink patch. I’ve edited the update image to allow for persistent logging. This reveals more. Something does fail with the drive, but I do not think it is specific to my drive. The full, fairly large, log starting from when I inserted the drive (via a USB hub that plugs into our USB Type C port, but I’ve also tried with a normal USB Type C drive without the hub) is attached. These FAT errors do not appear to always be the same, as I’ve only noticed this one once before. But that might just be a measurement problem since it does seem to cause a kernel panic.
fat_failure_log.txt (101.7 KB)
I’ve also included the log from the following boot below, but only the aktualizr-torizon
process as I didn’t spot any other relevant information. You can see that it detects an ‘incomplete update’ but after some time (this seems random) it decides to update the containers. This usually doesn’t happen so soon.
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Aktualizr version 2020.8 starting
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/etc/sota/conf.d/100-offline-updates.toml"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/20-sota-device-cred.toml"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/30-rollback.toml"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/40-hardware-id.toml"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/50-secondaries.toml"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/60-polling-interval.toml"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Use existing SQL storage: "/var/sota/sql.db"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Couldn`t import data: empty path received
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Couldn't import client certificate: "/var/sota/import/client.pem" doesn't exist.
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Couldn't import server CA certificate: "/var/sota/import/root.crt" doesn't exist.
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Couldn't import client TLS key: "/var/sota/import/pkey.pem" doesn't exist.
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Initializing docker-compose Secondaries...
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Use existing SQL storage: "/var/sota/storage/docker-compose/sql.db"
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: No valid metadata found in storage.
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Incomplete update detected.
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Rolling back container update
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Running docker-compose up
Jan 18 15:23:52 verdin-imx8mm-07276186 aktualizr-torizon[885]: Running command: /usr/bin/docker-compose --file /var/sota/storage/docker-compose/docker-compose.yml -p torizon up --detach --remove-orphans
Jan 18 15:23:55 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating network "torizon_default" with the default driver
Jan 18 15:23:56 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-skippy ...
Jan 18 15:23:56 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-mqtt ...
Jan 18 15:23:56 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating siab ...
Jan 18 15:23:56 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating weston ...
Jan 18 15:23:58 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating weston ... done
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-skippy ... done
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-mqtt ... done
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-speech ...
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-bt ...
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-web ...
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-hw ...
Jan 18 15:23:59 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-wifi ...
Jan 18 15:24:01 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-bt ... done
Jan 18 15:24:03 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-speech ... done
Jan 18 15:24:03 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-wifi ... done
Jan 18 15:24:04 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating allora3-hw ... done
Jan 18 15:24:04 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating torizon_kiosk_1 ...
Jan 18 15:24:06 verdin-imx8mm-07276186 aktualizr-torizon[925]: Creating torizon_kiosk_1 ... done
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Removing not used containers, networks and images
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Running command: docker system prune -a --force
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[1835]: Total reclaimed space: 0B
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Adding Secondary with ECU serial: 8cd554796e9284d802bbc588840c9ea14bdb240847ce7f73b86b6d44256da8eb with hardware ID: docker-compose
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Checking for a pending update to apply for Primary ECU
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Pending update for Primary ECU was found, trying to apply it...
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Checking installation of new OSTree sysroot
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Current versions in storage and reported by OSTree do not match
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: No ECU version report counter, please check the database!
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: Failed to store Secondary manifest: no more rows available
Jan 18 15:24:07 verdin-imx8mm-07276186 aktualizr-torizon[885]: curl error 3 (http code 0): URL using bad/illegal format or missing URL
Jan 18 15:24:08 verdin-imx8mm-07276186 aktualizr-torizon[885]: curl error 3 (http code 0): URL using bad/illegal format or missing URL
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: curl error 3 (http code 0): URL using bad/illegal format or missing URL
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: Put manifest request failed: 3 URL using bad/illegal format or missing URL HTTP 0
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: PROXY: initializing...
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: PROXY: using TCP port 8850.
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: Offline Updates are enabled
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: PROXY: starting thread.
Jan 18 15:24:09 verdin-imx8mm-07276186 aktualizr-torizon[885]: PROXY: listening to connections...
Jan 18 15:26:02 verdin-imx8mm-07276186 aktualizr-torizon[885]: fetchMetaOffUpd() called with source_path: "/media/JABBLA-USB/update/"
Jan 18 15:26:02 verdin-imx8mm-07276186 aktualizr-torizon[885]: Current version for ECU ID: 8cd554796e9284d802bbc588840c9ea14bdb240847ce7f73b86b6d44256da8eb is unknown
Jan 18 15:26:02 verdin-imx8mm-07276186 aktualizr-torizon[885]: New updates found in Director metadata. Checking Image repo metadata...
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: 1 new update found in both Director and Image repo metadata.
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Event: UpdateCheckComplete, Result - Updates available
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Update available. Acquiring the update lock...
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Current version for ECU ID: 8cd554796e9284d802bbc588840c9ea14bdb240847ce7f73b86b6d44256da8eb is unknown
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Image already fetched; skipping fetching
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Event: DownloadTargetComplete, Result - Success
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Event: AllDownloadsComplete, Result - Success
Jan 18 15:26:03 verdin-imx8mm-07276186 aktualizr-torizon[885]: Waiting for Secondaries to connect to start installation...
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: No update to install on Primary
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Event: InstallStarted
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/etc/sota/conf.d/100-offline-updates.toml"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/20-sota-device-cred.toml"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/30-rollback.toml"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/40-hardware-id.toml"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/50-secondaries.toml"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Reading config: "/usr/lib/sota/conf.d/60-polling-interval.toml"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Use existing SQL storage: "/var/sota/sql.db"
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: docker-compose file matches expected digest
Jan 18 15:26:04 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading metadata from tarball: /media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/66cd4908444fd0a62337b8b87493ec19855b0c72747a60415d8cdb7ddc1d96ab.tar
Jan 18 15:26:21 verdin-imx8mm-07276186 aktualizr-torizon[1939]: Loaded image: jabbla/allora3-bt:digest_sha256_66cd4908444fd0a62337b8b87493ec19855b0c72747a60415d8cdb7ddc1d96ab
Jan 18 15:26:21 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading of "/media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/66cd4908444fd0a62337b8b87493ec19855b0c72747a60415d8cdb7ddc1d96ab.tar" finished, code: 0, status: success
Jan 18 15:26:21 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading metadata from tarball: /media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/eb8a8af46ce73a26a6f7fd3f6eaa794cd6e51df85b640dc0bc6c77b7ecbec443.tar
Jan 18 15:26:33 verdin-imx8mm-07276186 aktualizr-torizon[1957]: Loaded image: jabbla/allora3-hw:digest_sha256_eb8a8af46ce73a26a6f7fd3f6eaa794cd6e51df85b640dc0bc6c77b7ecbec443
Jan 18 15:26:33 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading of "/media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/eb8a8af46ce73a26a6f7fd3f6eaa794cd6e51df85b640dc0bc6c77b7ecbec443.tar" finished, code: 0, status: success
Jan 18 15:26:33 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading metadata from tarball: /media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76.tar
Jan 18 15:26:34 verdin-imx8mm-07276186 aktualizr-torizon[2004]: Loaded image: eclipse-mosquitto:digest_sha256_e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76
Jan 18 15:26:34 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading of "/media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/e3119fbc75341e4ae07c6e10187534739973be5109b780d715e31d93a3105f76.tar" finished, code: 0, status: success
Jan 18 15:26:34 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading metadata from tarball: /media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/32e21ceda65ee8082e24684f2560c914983eeb249110986f9a24eb755a0a3d0e.tar
Jan 18 15:26:54 verdin-imx8mm-07276186 aktualizr-torizon[2019]: Loaded image: jabbla/allora3-skippy:digest_sha256_32e21ceda65ee8082e24684f2560c914983eeb249110986f9a24eb755a0a3d0e
Jan 18 15:26:54 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading of "/media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/32e21ceda65ee8082e24684f2560c914983eeb249110986f9a24eb755a0a3d0e.tar" finished, code: 0, status: success
Jan 18 15:26:54 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading metadata from tarball: /media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/fb3135d78adef34128e8f00a33dd005573e0d7420e791a0255bf0be29a36c43c.tar
Jan 18 15:27:08 verdin-imx8mm-07276186 aktualizr-torizon[2092]: Loaded image: jabbla/allora3-speech:digest_sha256_fb3135d78adef34128e8f00a33dd005573e0d7420e791a0255bf0be29a36c43c
Jan 18 15:27:08 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading of "/media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/fb3135d78adef34128e8f00a33dd005573e0d7420e791a0255bf0be29a36c43c.tar" finished, code: 0, status: success
Jan 18 15:27:08 verdin-imx8mm-07276186 aktualizr-torizon[885]: Loading metadata from tarball: /media/JABBLA-USB/update/images/9e09b624ffc9ed5cfb13310d73da4a12d5f3b63f86e4de917fae840185cf7c67.images/d0b3d3bf914c481c4e640d37a46f5e5a5ffe213697fcccb49a1c6074bfbb110a.tar
Kind regards,
Ernest Van Hoecke
