Add easy installer feed for local server
I would be glad if I could add a configuration file (like tezi_config.json) to easy installer image.json/filelist (without using SD card or USB flash drive) containing feed list additions like http://192.168.11.2/image_list.json.
So it would be possible without GUI interaction and without using removable media to install an image via RNDIS.
Hi @stefan.baumgart !
Have you tried the steps that we have in our documentation? Specifically the From a Local Web Server Announced via Zeroconf section.
Hi @henrique.tx
I am using Windows 10 inside a Network without DHCP. So it is not possible to use an AVAHI service.
I wrote my own local web server based on winsock.ocx as a feed source for TEZI.
It works but it is not capable of zeroconf.
That’s why TEZI can not automatically detect the feed source.
Best regards
Stefan
Hello @stefan.baumgart,
yes if you use the classic way of selecting a feed in the menu you have to typ the IP address manually.
Regrads,
Matthias
Hello @matthias.tx,
my feature request was to not have to use the classic way of typing the IP address manually.
This could be realized, as described in my first post, by supplying the TEZI with a configuration file that already contains the link to the http://192.168.11.2/image_list.json feed.
This way neither zeroconf nor manual input would be necessary.
Regards
Stefan
Hi @stefan.baumgart,
Well, if you can’t use Zeroconf/AVAHI/DHCP, I think that your last resource would be to set up redirection on a DNS setup, as you can see in the Custom Image Server without Local Media section of Toradex Easy Installer - Detailed Manual article.
Can we update the boot script to load the tezi_config.json from the tftp server and use it in the easy installer? Same like how the overlays.txt file is being loaded.
Hello @jesvinonnet,
Thanks for reaching out! Could you please create a separate thread on this topic with more details regarding your use case as well?
Done.
How to load tezi_config.json from tftp server along with boot.scr - Technical Support - Toradex Community
Hello Stefan!
I want to do the exact same thing! Were youi able to figure out a solution?
Hi @mag_oc ,
Were you able to proceed following the instructions provided here?
Daniel Morais
Hello @daniel_m.tx,
I have tried to follow this guide, but I still can’t get the URL to show up in my feeds or get it to auto-install. I’m not sure what I’m doing wrong. Is this the only way to make the image available automatically in my feeds?
I’m working with the iMX6ULL board.
Hi @mag_oc ,
Thanks for confirming.
Since this question is quite old, can you please create a new one describing all the steps you have executed?
Daniel Morais
Sure! This is the link
