ADD docker to tdx-reference image
ERROR: Nothing RPROVIDES ‘docker’ (but /home//oe-core/build/../layers/meta-toradex-demos/recipes-images/images/tdx-reference-minimal-image.bb RDEPENDS on or otherwise requires it)
NOTE: Runtime target ‘docker’ is unbuildable, removing…
Missing or unbuildable dependency chain was: [‘docker’]
ERROR: Required build target ‘tdx-reference-minimal-image’ has no buildable providers.
Missing or unbuildable dependency chain was: [‘tdx-reference-minimal-image’, ‘docker’]
Thank you
The error you’re encountering suggests that the build system cannot find a provider for Docker, which is required by the tdx-reference-minimal-image. This usually means that the Docker package is not available in your current build configuration.
To resolve this issue, you can try the following steps:
  1. Check Layer Configuration: Ensure that the meta-layer providing Docker is included in your build configuration. You might need to add a layer such as meta-virtualization, which often contains Docker recipes. You can add this layer by including it in your bblayers.conf file.
  2. Update Recipes and Dependencies: Make sure that your local.conf or the image recipe includes the necessary dependencies for Docker. You might need to explicitly add Docker to your image recipe if it’s not already included.
  3. Verify Docker Recipe Availability: Check if the Docker recipe is available in your layers. You can search for Docker recipes in your meta-layers directory to ensure they are present.
  4. Synchronize with Upstream: If you are using a custom or older version of the build environment, consider synchronizing with the latest upstream layers from Toradex or the Yocto Project to ensure you have the latest Docker recipes and dependencies.
  5. Consult Build Logs: Review the build logs for any additional clues about missing dependencies or configuration issues that might prevent Docker from being included.
By ensuring that the correct layers and dependencies are configured, you should be able to resolve the issue and successfully include Docker in your Toradex reference image build.
Toradex AI Assistant
How to Add Docker to tdx-reference-minimal-image in Yocto.
Hi @bharath2204
The tdx-reference-minimal-image is a “minimal” image and doesn’t include the docker container engine and it’s intended as a reference for further development.
For a ready-to-use OS we recommend Torizon OS.
