Hi Toradex,
I want to access to the SoM through ssh without need ip address, just username and hostname .
I am using Verdin Development Board
SoM: Verdin-iMX8MP
Any help?
Best ragqrds,
Ahmed49
Hi Toradex,
SoM: Verdin-iMX8MP
Any help?
Best ragqrds,
Ahmed49
Hi Ahmed,
To access your Verdin-iMX8MP SoM through SSH using the hostname instead of the IP address, you can follow these steps:
Find the Hostname:
<family>-<processor>-<serial number>, all in lowercase letters.hostname command.Add the Suffix:
.local to the hostname. For example, if your hostname is verdin-imx8mp-12345678, you will use verdin-imx8mp-12345678.local.Establish the SSH Connection:
root, the command would be:ssh root@verdin-imx8mp-12345678.local
Using Visual Studio Code Extension for Torizon:
By following these steps, you should be able to access your Verdin-iMX8MP SoM through SSH using the hostname without needing the IP address.
[Your Name]
Hi @Ahmed49
Were you able to access your device, or do you still need help with this issue?
If you don’t have any problems, could you mark the issue as solved?
