24 bit lvds on carrier board for t30
currently we are using T30 modules on Iris carrier board. As far as I can understand LVDS display adapter has only 18 bit color depth. Is that true? Is there available a “standard” carrier board that has the possibility to drive 24bit lvds output?
Hi @Lerimini,
I guess you are talking about the LVDS connector (X7) on the Iris Carrier Board.
You are correct; by default Iris carrier board and Colibri evaluation board both has single channel, 18 bit LVDS interface only.
Our Apalis computer-on-module products and carrier boards supports dual channel, 24bit LVDS interface. You can use either Apalis Evaluation Board or Ixora carrier board.
https://www.toradex.com/computer-on-modules/apalis-arm-family
http://developer.toradex.com/products/apalis-evaluation-board
http://developer.toradex.com/products/ixora-carrier-board
Let me know, if you have any further query.
Satyan Raj
