10.1 Cap Touch Display Driver IC
I have reviewed the datasheet for the Toradex 1212 10.1 display from Logic Technologies, LT170410-2WHC. the Datasheet doesn’t identify the Source driver with LVDS interface. I’m using this display in relationship to the Dahlia Carrier Board with the i.MX8MP SoM.
I’m currently comparing the DTSI file of this display to a new display using a FIT EK79202B driver IC. Currently the new display is experiencing a vertical syncing issue and I’m trying to identify root cause as it might be related to the display configuration.
Display Comparison
Column 1 Column 2 C D E F Column 3 H Column 4 J
Logic Technologies NEW
LT170410-2WHC xxxxxx
LVDS - 4 Channel LVDS 4 Channel
Clock Frequency 1/Tc 68.9 71.1 73.4 68.2 72.4 78.5
Horizontal Display Area tHD 1280 1280
HS period time tH 1410 1440 1470 1380 1440 1500
HS Front Porch tHFP 12 72 132
HS Back Porch tHBP 88 88 88
HS Width tHW - - -
HS Width + BP + FP tHW+tHBP+tHFP 60 160 190 100 160 220
Vertical display area tVD 800 800
VS Period time tV 815 823 833 824 838 872
VS Front Porch tVFP 1 15 49
VS Back Porch tVBP 23 23 23
VS Width tVW - - -
VS Width + BP + FP tVW+tVBP+tVFP 15 23 33 24 38 72
DTSI File
Column 1 Column 2 Column 3 Column 4 E F G H
DTSI File DTSI Update
Original New Display
1280 1280
1341 1440 1469 1380 1440 1500
23 60 71 10 70 130
23 60 71 88 88 88
15 40 47 2 2 2
61 160 189 100 160 220
800 800
816 823 832 824 838 872
5 7 10 9 13 47
5 7 10 13 23 23
6 9 12 2 2 2
16 23 32 24 38 72
Looking for input on the display comparison and how best approach for the display panel integration including modification of the DTSI file.
The External TI MIPI_LVDS bridge IC can generate a stable image at both display targets, the Logic Technologies and the new display.
Hello! Thank you for sharing such detailed information. I understand you’re integrating a new LVDS panel (with FIT EK79202B driver IC) into your Verdin iMX8M Plus on the Dahlia Carrier Board and are having vertical sync issues, while your LT170410-2WHC panel is functioning correctly.
Let’s break down the best approach for stable LVDS integration and necessary DTSI (device tree) adjustments:
1. Understand the Critical Device Tree Parameters
LVDS panel timing parameters in the device tree must precisely match those specified by your new panel’s datasheet. Key fields for a typical LVDS panel are:
  • clock-frequency (in Hz)
  • hactive, vactive (horizontal/vertical resolution)
  • hsync-len, hfront-porch, hback-porch
  • vsync-len, vfront-porch, vback-porch
  • Color mapping/data mapping (fsl,data-mapping, data-mapping)
You’ll configure these within the display-timings node of your overlay.
2. Map Datasheet Parameters to Device Tree Fields
Referencing your tables, you’ll want to extract timing fields for the NEW display:
LCD Timing Device Tree Field Value (typical or mid-range based on your table)
Pixel Clock Frequency clock-frequency 72,400,000 (for 72.4 MHz for new display)
Horizontal active (pixels) hactive 1280
Horizontal total (tH) hactive + hfront + hback + hsync 1440
Vertical active (lines) vactive 800
Vertical total (tV) vactive + vfront + vback + vsync 838
For porch and sync calculation:
  • hblank = total - active
  • vblank = total - active
  • Assign values to hsync-len, hfront-porch, and hback-porch based on proportions in datasheet or, if given, direct values.
  • Assign values to vsync-len, vfront-porch, and vback-porch similarly.
Example Calculation (if values are given as in your table):
Suppose for hfront-porch = 70, hback-porch = 88, hsync-len = 2
Then: 70 (front) + 88 (back) + 2 (sync) = 160 (hblank)
3. Device Tree Example Snippet
Here’s an example display-timings node for your NEW panel (please verify the porch/sync lengths as needed):
panel_lvds: panel-lvds {
    compatible = "panel-lvds";
    data-mapping = "jeida-24";           /* Or "vesa-24", depends on your panel */
    width-mm = <217>;
    height-mm = <136>;
    display-timings {
        native-mode = <&timing0>;
        timing0: timing0 {
            clock-frequency = <72400000>;        /* 72.4 MHz */
            hactive = <1280>;
            vactive = <800>;
            hfront-porch = <70>;
            hback-porch = <88>;
            hsync-len = <2>;
            vfront-porch = <13>;
            vback-porch = <23>;
            vsync-len = <2>;
            /* Optional: polarity flags */
            hsync-active = <0>;
            vsync-active = <0>;
            de-active = <1>;
            pixelclk-active = <0>;
If color is incorrect or image is unstable, try swapping jeida-24 for vesa-24 or adjusting with fsl,data-mapping properties as per this discussion:
More overlay examples:
4. Color Mapping & Data Mapping
  • If the image colors are swapped/tinted, try both "jeida-24" and "vesa-24" settings.
  • Set both fsl,data-mapping and data-mapping properties in your overlay node for completeness.
  • See LVDS color mapping notes here:
    Verdin iMX8M Plus | Toradex Developer Center
5. Troubleshooting Tips
  • Make sure your device tree overlay is being applied (check /proc/device-tree/).
  • If timings seem correct but image is unstable, tweak the sync and porch settings by small increments, as LVDS panels can be sensitive to these margins.
  • Confirm clock-frequency matches within the datasheet’s allowed range.
  • If the TI MIPI-LVDS bridge works but direct mode does not, it’s likely timing or color mapping, not hardware.
  • Ensure the LVDS interface is in 4-channel mode if your panel requires this.
Summary of Integration Steps
  1. Align the device tree timings (including sync and porch) to the new panel datasheet.
  2. Set the appropriate color/data mapping (jeida-24, vesa-24, or as per your panel).
  3. Test and fine-tune: Start with datasheet mid-values; adjust porch/sync if you see jitter, tearing, or sync loss.
Let me know if you want a ready-to-use overlay based on the exact datasheet specs, or if you have the direct register/timing details for the new panel!
LVDS is a high-speed digital signaling standard, so you don’t need a dedicated driver for the display IC itself. Instead, you need an LVDS driver for the i.MX8M Plus SoC, and it should be configured to match the display’s parameters—such as resolution, pixel clock, sync timings, signal polarity, etc.
Please refer to this article for more details.
Alex,
I am using the overlay.txt file is how I am changing the display configuration using the overlay method described within the link provided. The tables provided is the configuration difference between the Toradex evaluation display 1212 and the display that has been chosen for this integration platform. I modified the “display-lt170410_sn65dsi84_overlay.dtsi” file and had that recompiled for the evaluation platform. Also changing the overlay.txt file enabled the overlay and enabled the display VIA the Texas Instruments SN65DSI84 MIPI-LVDS bridge.
Reference I’m using the following evaluation image
Toradex Embedded Linux Reference Multimedia Image 7.3.0+build.8 (2025-7-03)
I put that file into the boot directory and changed the overlay.txt file to include the
verdin-imx8mp_dsi-to-lvds_panel-cap-touch-10inch-lvds_overlay.dtbo
Due to the bridge being able to generate a stable test image I believe that the source is the dataset being sent to the MIPI-LVDS bridge. We have tried the new .dtsi file in the above table but with no change to the failure mode.
Note: I tried uploading the .dtsi file and the a video of the evaluation platform with both displays active, but the system won’t allow me due to being a new user for reference on the issue.
Could you please share the datasheet for your display (not just the EK79202B IC) as well as your device tree overlay code?
I can provide snippets of the display datasheet as necessary.
I’m not allowed to upload any files due to the following error.
“Sorry, new users can not upload attachments.” when I press the upload button.
Please advise how to attach files to the thread.
you can use our data server https://share.toradex.com/
Hi Scott,
Any updates for us here?
Michael Park
Toradex
