Bootloader: U-Boot
Kernel version: 5.4.193-5.7.1-devel+git.1895b0052289 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP PREEMPT Mon Sep 25 08:49:04 UTC 2023
Kernel command line: root=PARTUUID=900ce727-02 ro rootwait console=tty1 console=ttymxc2,115200 consoleblank=0 earlycon
Distro name: Not known
Distro version: Not known
Hostname: verdin-imx8mp-tf3-controller-07011727
Hardware info
HW model: Toradex Verdin iMX8MP Q 4GB WB IT
Toradex version: V1.0C
BSP version 5.7.2
Processor arch: Arm
I am working on implementing thread priority using pthread for yocto platform and want to know if this can actually be done and used like RTOS. Is there any tool in yocto/linux like SEGGER Systemview for real-time analysis?
Here is the steps and test I performed to test this out.
Steps followed to set thread priority.
(1) Initializing thread attributes using pthread_attr_init().
(2) Setting the inherit-scheduler attribute of the thread to PTHREAD_EXPLICIT_SCHED using pthread_attr_setinheritsched().
(3) Setting the scheduling policy SCHED_RR using pthread_attr_setschedpolicy().
(4) Getting scheduling parameter attributes using pthread_attr_getschedparam().
(5) Setting thread priority using pthread_attr_setschedparam().
(6) Created thread with set attribute parameters. -
How I have tested.
Test
I first created 10 threads all with priority from 1 to 10 and a print log.
Started all threads one by one.
I have confirmed that the priority is getting set for each thread.
Output expected.
→ After few seconds, the prints from all threads should be in-order as per set priority.
Ex:
print: Thread 10 priority 10
print: Thread 9 priority 9
print: Thread 8 priority 8
Actual observed Output.
→ The prints are coming randomly without following any specific order even after a min or so. -
I did find few articles (related to raspberry pi) mentioning about the fact that this can only be applicable if the processor only has one core.
If there is multiple core is present then the thread can be assign to different cores randomly.
