Command used
bitbake tdx-reference-multimedia-image -c populate_sdk
WARNING: qtsvg-5.14.2+gitAUTOINC+63961dd0c7-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qtsystems-5.14.2+gitAUTOINC+e3332ee38d-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtbase-5.14.2+gitAUTOINC+3a6d8df521-r0 do_populate_sysroot: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtbase-5.14.2+gitAUTOINC+3a6d8df521-r0 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtbase-5.14.2+gitAUTOINC+3a6d8df521-r0 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qtcharts-5.14.2+gitAUTOINC+0dbc3485d0-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qtserialbus-5.14.2+gitAUTOINC+4a0bdbfb75-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtbase-5.14.2+gitAUTOINC+3a6d8df521-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qttranslations-5.14.2+gitAUTOINC+c14fdb7653-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qttools-5.14.2+gitAUTOINC+9d5d92a492-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qttools-5.14.2+gitAUTOINC+9d5d92a492-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qttools-native-5.14.2+gitAUTOINC+9d5d92a492-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-m4-1.4.18-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qttools-native-5.14.2+gitAUTOINC+9d5d92a492-r0 do_populate_sysroot: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-bash-completion-2.10-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtxmlpatterns-5.14.2+gitAUTOINC+45bf71199c-r0 do_populate_sysroot: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtxmlpatterns-5.14.2+gitAUTOINC+45bf71199c-r0 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtxmlpatterns-5.14.2+gitAUTOINC+45bf71199c-r0 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtxmlpatterns-5.14.2+gitAUTOINC+45bf71199c-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-m4-1.4.18-r0 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-perl-5.30.1-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-bash-completion-2.10-r0 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-m4-1.4.18-r0 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-bash-completion-2.10-r0 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-m4-1.4.18-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-bash-completion-2.10-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-flex-2.6.4-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-util-linux-2.35.1-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtdeclarative-5.14.2+gitAUTOINC+23a000f9a1-r0 do_populate_sysroot: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtdeclarative-5.14.2+gitAUTOINC+23a000f9a1-r0 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qemu-4.2.0-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtdeclarative-5.14.2+gitAUTOINC+23a000f9a1-r0 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-qtdeclarative-5.14.2+gitAUTOINC+23a000f9a1-r0 do_package_write_ipk: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qt3d-5.14.2+gitAUTOINC+ea698681d9-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-autoconf-2.69-r11 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: qt3d-native-5.14.2+gitAUTOINC+ea698681d9-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-ca-certificates-20210119-r0 do_deploy_source_date_epoch: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-ca-certificates-20210119-r0 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-autoconf-2.69-r11 do_package: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-autoconf-2.69-r11 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
WARNING: nativesdk-ca-certificates-20210119-r0 do_packagedata: Error contacting Hash Equivalence Server unix:///home/shankar/yocto-ml-build/bsp-toradex/build/hashserve.sock: [Errno 2] No such file or directory
