Yocto recipes to build u-boot
i need to modify the u-boot recipes, but which is the recipes to use between bitbake u-boot, u-boot-toradex or virtual/bootloader and in this case wich is the recipes used.
Thank you.
Best regards
Flavio
Hello Flavio,
For modifying U-Boot recipes in Toradex BSPs, you should use virtual/bootloader(1)(2). This is the virtual recipe name that represents the bootloader component in the Yocto build system.
Which Recipe is Actually Used
When you build with virtual/bootloader, the actual recipe used is u-boot-toradex(1)(2). You can verify this by running:
bitbake -c checkuri virtual/bootloader > log
(1)(2)
This will show you the actual recipe path, which will be something like:
/work/oe-core/build/../layers/meta-toradex-nxp/recipes-bsp/u-boot/u-boot-toradex_2020.04.bb
(1)
Recommended Workflow for Modifications
  1. Initialize the build environment:
cd /work/oe-core/
. export
(1)(2)
  1. Clean the bootloader recipe (if you’ve made previous changes):
bitbake -c cleansstate virtual/bootloader
(1)(2)
  1. Use devshell for development:
bitbake -c devshell virtual/bootloader
(1)(2)
  1. Create patches using quilt (from within devshell):
quilt new YourPatchName.patch
(1)
  1. Apply patches via bbappend files - Create a .bbappend file in your layer to add patches to the recipe(1)(2).
Important Notes
  • Always use virtual/bootloader rather than directly calling bitbake u-boot or bitbake u-boot-toradex
  • The bootloader virtual recipe name ensures you’re building the correct U-Boot variant for your Toradex module(1)(2)
  • After modifying U-Boot, you may need to clean and rebuild your OS image as well(2)
This approach ensures you’re working with the Toradex-specific U-Boot implementation that includes all necessary patches and configurations for your module.
