I have created a recipe to copy my application into my image to install on my product.
When i set it to copy a file such as an image it builds fine.
When i set it to copy an application then it complains that the libraries the application was built with are not provided
I have tried adding DEPENDS but still not joy
this is the recipe
Package summary
SUMMARY = “add folders”
License, for example MIT
LICENSE = “MIT”
License checksum file is always required
LIC_FILES_CHKSUM = “file://${COREBASE}/meta/files/common-licenses/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302”
MY_FILES = “/home/adrian/filestocopy”
S = “${WORKDIR}”
do_install () {
install -d ${D}/home/root/
install ${MY_FILES}/adrian.png ${D}/home/root/
install -m 0755 ${MY_FILES}/myapp ${D}/home/root/
}FILES:${PN} += "
/home/root/
myapp
I know my apps makefile includes
LIBS = -lgpiod -lpng
and when im building my image i get error statements such as
ERROR: addfolders-0.1-r0 do_package_qa: QA Issue: /home/root/myapp contained in package addfolders requires libgpiod.so.2, but no providers found in RDEPENDS:addfolders? [file-rdeps]
How do i get it to accept the libraries that have been installed in the image ?
(Note : If i just try copying the adrian.png then it builds fine and the image includes the image file in the correct location on my device)
