I’ve recently build an image with a kernel type zImage. But now, I’m trying to build this same image but with a different type for kernel image : uImage. I then set KERNEL_IMAGETYPE=“uImage” in my conf/local.conf to overwrite the precedent configuration.
But what is the best way I have to follow to create this new kernel image ?
I follow what you wrote but in my deploy directory the uImage doesn’t appear. I’ve also tested with a new rootfs extension (IMAGE_FSTYPES+=“ext3”) but the rootfs still remains in ext4.
Maybe I missed something…
EDIT :
After cleansstate of virtual/kernel, bitbake [my image] instead of bitbake virtual/kernel works.
Hi, @max.krummenacher : IMAGE_FSTYPES was just another test to identify if the problem concerns my local.conf file or an other file.
@cleitonbueno : I’m currently compiling an image, I’ll post the result asap. But the local.conf overwrites the variable if there is a conflict with other files isn’t it ?
