Yocto error update_gio_module_cache
Hello everyone!
I need some help from you guys, i am working on a Colibri VF61 SOM. I am new in Yocto, i cloned Yocto (Dunfell branch) project and download all the Layers, updated the bblayer file and also local.conf file with the machine name. when i try to compile the minimal image i get the following error:
core-image-minimal-1.0-r0 do_rootfs: The postinstall intercept hook ‘update_gio_module_cache’ failed, details in /home/ricard/Yocto/poky/build/tmp/work/colibri_vf-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_rootfs
I don’t understand what’s wrong, does anyone can help with this?
Thank you so much!
The error you’re encountering, “The postinstall intercept hook ‘update_gio_module_cache’ failed,” typically relates to issues with the GIO module cache update process during the root filesystem creation in Yocto. This can happen due to several reasons, such as missing dependencies or incorrect configurations.
Here are a few steps you can take to troubleshoot and potentially resolve the issue:
  1. Check the Log File: The error message points to a specific log file: /home/ricard/Yocto/poky/build/tmp/work/colibri_vf-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_rootfs. Review this log file for more detailed error messages that can provide insight into what specifically went wrong during the update_gio_module_cache process.
  2. Verify Dependencies: Ensure that all necessary dependencies for GIO and related packages are included in your Yocto build. Sometimes, missing dependencies can cause post-installation scripts to fail.
  3. Check Configuration Files: Double-check your bblayers.conf and local.conf files to ensure that all necessary layers are included and that the machine configuration is correctly set for the Colibri VF61.
  4. Update Layers: Make sure that all your layers are up to date. Sometimes, issues can arise from using outdated layers that may not be fully compatible with each other.
  5. Consult Yocto Documentation: Since you are using the Dunfell branch, refer to the Yocto Project documentation for Dunfell to ensure that there are no known issues or additional steps required for your specific setup.
  6. Community and Support: If the above steps do not resolve the issue, consider reaching out to the Yocto community or Toradex support for further assistance. They may have encountered similar issues and can provide more targeted help.
If these steps do not resolve the issue, it may require more specific investigation into the log file and your build setup.
The postinstall intercept hook 'update_pixbuf_cache' failed - NXP Community.
Hi @RIki89d
Are you following a specific guide on how to build with Yocto?
The Colibri VF is a quite old SoM, I think you first need to check which is the last compatible version.
Hello @allan.tx
Yes, i did it.
I figured out the problem, is it just i was working on a wrong branch, the suitable branch is dunfell, so i just did a checkout to it, then it works.
Thanks for your reply.
