Hi @ToradexAI,
I have facing error issue in the patch file of the uboot recipes-bsp in my custom layer.
device info:
root@verdin-imx8mp-15722244:~# tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 6.6.101-7.5.0-devel #1 SMP PREEMPT Mon Oct 27 12:24:20 UTC 2025
Kernel command line: root=PARTUUID=264a51a5-051e-4975-a6c6-a0920bffbd91 ro rootwait console=tty1 console=ttymxc2,115200 console=null quiet loglevel=0 vt.global_cursor_default=0 vt.default_redraw=0 consoleblank=0
Distro name: NAME="TDX Wayland with XWayland"
Distro version: VERSION_ID=7.5.0-devel-20260122114211-build.0
Distro variant: -
Hostname: verdin-imx8mp-15722244
Hardware info
HW model: Toradex Verdin iMX8M Plus WB on Ivy
Toradex version: 0070 V1.1A
Serial number: 15722244
Processor arch: aarch64
Failing on the u-boot-toradex at patch file,
hari@Administrator:~/oe-core/layers/meta-lokbest$ cat recipes-bsp/u-boot/files/verdin-imx8mp/disable-console-logs.patch
Index: git/include/configs/verdin-imx8mp.h
--- git.orig/include/configs/verdin-imx8mp.h
+++ git/include/configs/verdin-imx8mp.h
@@ -44,6 +44,8 @@
"fdt_board=dev\0" \
"initrd_addr=0x43800000\0" \
"initrd_high=0xffffffffffffffff\0" \
+ "setupargs=console=ttymxc2,115200\0" \
+ "tdxargs=quiet loglevel=0 vt.global_cursor_default=0 vt.default_redraw=0 consoleblank=0\0" \
"update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \
"if test \"$confirm\" = \"y\"; then " \
"setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \
hari@Administrator:~/oe-core/layers/meta-lokbest$ cat recipes-bsp/u-boot/u-boot-toradex_%.bbappend
FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
SRC_URI += "\
file://disable-console-logs.patch \
do_configure:append() {
# Set boot delay to 0 for fast boot
if grep -q "#define CONFIG_BOOTDELAY" ${S}/include/configs/verdin-imx8mp.h; then
sed -i 's/#define CONFIG_BOOTDELAY.*[0-9]/#define CONFIG_BOOTDELAY 0/' ${S}/include/configs/verdin-imx8mp.h
else
echo "#define CONFIG_BOOTDELAY 0" >> ${S}/include/configs/verdin-imx8mp.h
fi
# Remove existing fdtfile, if there is one
sed -i '/"fdtfile=.*\\0" \\/d' ${S}/include/configs/verdin-imx8mp.h
# Add new fdtfile for Ivy carrier board
sed -i 's/\("fdt_board=.*\\0" \\\)/\0\n "fdtfile=imx8mp-verdin-wifi-ivy.dtb\\0" \\/' ${S}/include/configs/verdin-imx8mp.h
Error in bitbake build:
Sstate summary: Wanted 522 Local 480 Mirrors 0 Missed 42 Current 5662 (91% match, 99% complete)##### | ETA: 0:00:01
Removing 3 stale sstate objects for arch verdin_imx8mp: 100% |###############################################| Time: 0:00:00
NOTE: Executing Tasks
ERROR: u-boot-toradex-1_2024.07-r0 do_patch: Applying patch 'disable-console-logs.patch' on target directory '/home/hari/oe-core/build/tmp/work/verdin_imx8mp-tdx-linux/u-boot-toradex/2024.07/git'
CmdError('quilt --quiltrc /home/hari/oe-core/build/tmp/work/verdin_imx8mp-tdx-linux/u-boot-toradex/2024.07/recipe-sysroot-native/etc/quiltrc push', 0, 'stdout: Applying patch disable-console-logs.patch
patching file include/configs/verdin-imx8mp.h
Hunk #1 FAILED at 44.
1 out of 1 hunk FAILED -- rejects in file include/configs/verdin-imx8mp.h
Patch disable-console-logs.patch does not apply (enforce with -f)
stderr: ')
ERROR: Logfile of failure stored in: /home/hari/oe-core/build/tmp/work/verdin_imx8mp-tdx-linux/u-boot-toradex/2024.07/temp/log.do_patch.703726
ERROR: Task (/home/hari/oe-core/build/../layers/meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-toradex_2024.07.bb:do_patch) failed with exit code '1'
