I’ve have built this many times before on both Torizon 4 & Torizon 5, but it results in a build error when building for 5.2 & 5.3. Everything works except when i try to enable any of the flexcan devices.
Is this a bug or have you changed anything related to enabling the can devices?
Kernel is the latest available you have provided
branch: toradex_5.4-2.3.x-imx
Kernel: 5.4.91
Latest commit may 4th
ERROR: Task (/home/developer/yocto-torizon-5/build/conf/…/…/layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_compile) failed with exit code ‘1’
Here is a snippet from my device tree patch containing all changes, which is disabled uart … this works fine … but if I enable anyone of the 3 flexcan the patching process crashes when building the project.
/* Colibri SPI */
&lpspi2 {
mcp2515: can@0 {
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_can_int>;
reg = <0>;
clocks = <&clk16m>;
interrupt-parent = <&lsio_gpio3>;
interrupts = <13 IRQ_TYPE_EDGE_FALLING>;
spi-max-frequency = <10000000>;
/* To keep the CAN controller enabled by default,
* disable conflicting spidev. This spidev device
* enables with the devicetree overlay.
spidev0: spidev@0 {
status = "disabled";
&flexcan1 {
&flexcan2 {
&flexcan3 {
/* Colibri UART_B */
&lpuart0 {
/* Colibri UART_C */
&lpuart2 {
/* Colibri UART_A */
&lpuart3 {
status= "disabled";
//Best wishes Martin!
