So the question is could you recommend us some bidirection voltage shifters which will work with the Yavia boards UART and I2C ?
Preferably it should be a break out component which can be soldered into the UART connection.
Can you recommend something? Or does anyone can recommend a working component?
I have a similar issue with the SOM on a Dahlia carrier board. The UARTs 1 and 2 use 1.8v ttl and I need them at 3.3. I am also using a level shifter to match the logic levels, but it’s not working. After wiring up the UARTs from the expansion headers, i cant read any data from verdin-uart1 or 2. The attached UART devices are running fine, just not ability to communicate from the Dahlia.
Could you please share the schematics of how you connected the UART and I2C lines of Verdin iMX8MP to the level shifter and to the Raspberry Pi? Please also share the VCC and GND connections.
Also, are you using a breadboard for your tests? This can be problematic with high baud rates.
And which baud rate are you using for each interface?
@Glitch , I am focusing on @dan’s issue now since he created the thread. Hopefully, you will find the solution for your case in this discussion. If not, please create a new topic so we can help you with your specific case, ok? Thanks for the comprehension
