Greetings,
Based on the symptoms you’ve described, it seems like the Verdin iMX8M Plus module on your Yavia carrier board is not booting up properly. The fact that you’ve observed D21 and D22 LEDs indicating reset states and your inability to detect the board in recovery mode or communicate via the debug port suggests a deeper issue that might not be resolved through standard recovery procedures.
Given the steps you’ve already attempted, including trying to enter recovery mode and attempting communication through the debug port without success, there are a few additional things you might consider:
Power Supply Check: Ensure that the power supply you’re using meets the requirements for the Verdin iMX8M Plus and the Yavia carrier board. An inadequate power supply can cause the issues you’re experiencing.
Inspect for Physical Damage: Carefully inspect both the Verdin module and the Yavia carrier board for any signs of physical damage. Look for burnt components, damaged pins, or anything out of the ordinary.
Re-seat the Module: If you haven’t already, try re-seating the Verdin module on the Yavia carrier board. It’s possible that the module is not properly connected, causing these issues.
Try a Different Module: If you have access to another Verdin module, try booting the Yavia carrier board with it. This can help determine if the issue lies with the module or the carrier board.
Check for Short Circuits: Use a multimeter to check for any short circuits on the carrier board, especially around the power supply circuitry and the module’s interface connectors.
If after these steps the issue persists and the board remains unresponsive, it might indicate a hardware failure that cannot be resolved through standard troubleshooting steps. In such cases, the hardware might need to be evaluated and possibly repaired or replaced. Given the complexity of embedded systems, diagnosing hardware issues can be challenging without the right tools and expertise.
Toradex AI Assistant
Toradex Easy Installer: Verdin-iMX8MP_ToradexEasyInstaller_6.6.0+build.6
Host OS: Windows 11 Pro
Recovery script message: Success 0 Failure 0 Wait for Known USB Device Appear…
Are you using any HDMI display connected to the Yavia board? No
This is from the board that still works. The broken one used the same firmware:
Yes. By swapping the 2 boards and the 2 carriers, I was able to start the Toradex Easy Installer for 1 combination and failed for the other 3 combinations.
We’ve decided to return the defective board and carrier to my manager that has better electronics skills.
