Xen Hypervisor on Apalis iMX8 QuadMax
Need Guidance for Implementing Xen Hypervisor on Apalis iMX8 QuadMax (Ixora v1.3)
Hello Toradex Team,
I am working with the Apalis iMX8 QuadMax module mounted on Ixora Carrier Board v1.3.
My Host Setup:
• Ubuntu 24.04 running in a Virtual Machine
• Goal: Implement Xen Hypervisor from scratch
• Objective: Dom0 Linux + DomU guest setup
I would like guidance on:
  1. Recommended Toradex BSP version that supports Xen
  2. Whether Xen is officially supported on Apalis iMX8 QuadMax
  3. Required Yocto layers and meta-xen compatibility
  4. Any reference documentation for hypervisor setup on this platform
I am new to Xen implementation and would appreciate step-by-step direction.
Thank you.
Xen Hypervisor Support on Apalis iMX8 QuadMax
Based on the available documentation and community discussions, I can provide some guidance on Xen implementation for your Apalis iMX8 QuadMax setup.
Current Support Status
While the Apalis iMX8 QuadMax is a powerful module featuring up to 2x Arm Cortex-A72, 4x Cortex-A53, and 2x Cortex-M4F cores with advanced hardware security and safety features (1), Xen hypervisor support is not officially documented in Toradex’s standard BSP layers and reference images.
Community Experience
There have been community attempts to implement Xen on the iMX8QM platform, but with mixed results. One user reported encountering kernel panic issues when booting the Xen hypervisor, specifically with the error “Unable to copy the kernel in the hwdom memory” (2). This suggests that while the hardware may theoretically support Xen, there are implementation challenges that need to be addressed.
Recommended Alternative: Torizon OS
Instead of pursuing Xen hypervisor implementation, I strongly recommend considering Torizon OS with containerization (3). This approach provides:
  • Container-based virtualization using Docker
  • Official Toradex support and maintenance
  • OTA update capabilities
  • Production-ready solution for application isolation
  • Simplified development workflow
BSP Information
For standard development, Toradex provides comprehensive BSP layers through the Yocto Project framework (4). The build process involves:
  1. Installing prerequisites and configuring git
  2. Downloading repositories using the Repo tool
  3. Exporting environment setup scripts
  4. Setting up your machine configuration
  5. Using bitbake to build images (4)
Next Steps
Given that Xen support is not officially documented and community implementations have encountered issues, I’d recommend:
  1. Evaluate if containerization meets your requirements - Torizon OS may provide the isolation you need
  2. Contact Toradex support directly if Xen is absolutely required for your use case
  3. Consider the heterogeneous multicore capabilities of the iMX8QM for real-time task offloading to Cortex-M4 cores (1)
Could you share more details about your specific virtualization requirements? This would help determine if Torizon OS with containers could meet your needs more effectively than a traditional hypervisor approach.
Dear Toradex Support Team,
Thank you for your earlier response and the recommendation to use Torizon OS.
I am new to Xen and hypervisor-based systems, but for my usage I would like to try implementing Xen on the Apalis iMX8 QuadMax instead of using containers.
Could you please guide me on how to start as a beginner?
  • Is Xen technically possible on this module?
  • Which BSP version should I use as a base?
  • Do I need specific bootloader or device tree changes?
I would really appreciate any pointers, documentation references, or example configurations that can help me begin.
Thank you for your support.
Xen Implementation on Apalis iMX8 QuadMax - Beginner’s Perspective
I understand your interest in exploring Xen hypervisor implementation despite the challenges involved. Let me provide guidance based on the available information.
Technical Feasibility
The Apalis iMX8 QuadMax features a powerful NXP i.MX 8QuadMax processor with 2x Arm Cortex-A72, 4x Arm Cortex-A53 cores, 4GB LPDDR4 memory, and operates from -40° to 85° C (1). From a hardware perspective, the ARM architecture and multi-core setup could theoretically support hypervisor functionality.
However, Xen is not officially supported in Toradex’s BSP layers and reference images. The community experience shows significant implementation challenges, including kernel panic issues with the specific error “Unable to copy the kernel in the hwdom memory” (2).
BSP Foundation
Toradex OS images consist of several key components that would be relevant to your Xen implementation (3):
  • Kernel: Manages hardware resources and provides low-level services
  • Bootloader: U-Boot runs at system startup to initialize hardware and load the kernel
  • Device Trees: Describe hardware components to the kernel
  • Board Support Package (BSP): Collection of drivers, configurations, and patches
For device tree modifications that you’ll likely need, Toradex provides device tree overlay capabilities (4). These allow you to modify device tree configurations without recompiling the entire device tree, which could be useful for Xen-specific hardware configurations.
Implementation Challenges
Based on community reports, users have encountered significant obstacles (2):
  • Kernel panic during Xen hypervisor boot
  • Memory allocation issues for the hardware domain
  • CPU compatibility problems with big.LITTLE architecture
Recommended Approach
Given the complexity and lack of official support, here’s what I can suggest:
  1. Start with standard Toradex BSP - Use the current BSP 7.x.y as your foundation
  2. Device Tree Modifications - You’ll likely need custom device tree overlays for Xen-specific configurations (4) (5)
  3. Bootloader Configuration - U-Boot modifications may be necessary to load Xen instead of directly booting Linux
  4. Community Resources - Review the community discussions for insights into specific error conditions (2) (6)
Important Considerations
Since Xen implementation on this platform involves significant technical challenges and is not officially supported, you should be prepared for:
  • Extensive debugging and troubleshooting
  • Potential hardware compatibility issues
  • Limited community support for this specific combination
Would you be open to sharing more details about your specific use case requirements? This might help determine if there are alternative approaches using Toradex’s supported technologies that could meet your objectives more reliably.
Hi @naresh1!
As I answered in your private message, unfortunately, we have never tested Xen Hypervisor with our modules, so I can’t say whether it should work or not.
That said, I recommend checking our Partner Network, where you can find partners with the expertise required to help with your project.
If you have any trouble finding a suitable partner, feel free to contact us.
Best regards.
hi @lucas_az.tx
Need partner who did successful implementation of xen hypervisor on imx8 quadmax, ixora carrier board.
Hi, @lucas_az.tx
Is there any resources available for building the yocto image with added xen-hypervisor for apalis imx8quadmax and carrier board is ixora 1.3A.
Hi @naresh1,
Unfortunately, we do not have documentation covering Yocto builds with the Xen Hypervisor.
Additionally, we are not aware of any partner who has successfully implemented the Xen Hypervisor on the Apalis iMX8QM. Therefore, you would need to reach out to our partners to check whether they would be able to support or implement this for your project.
Best regards.
