I need to install x11 / VNC server in toradex linux for iMX7D 1GB through serial console terminal in host PC. How it can be possible?
Hi @asifalilu
Could you provide the software version of your module?
Colibri iMX7 Dual 1GB (eMMC) 2.8
Hi @asifalilu
Thanks for the information.
You can install x11vnc using opkg update && opkg install x11vnc
please refer here for more details.
Thank you
What is the reason it says
" * opkg_prepare_url_for_install: Couldn’t find anything to satisfy ‘x11vnc’."
Hi @asifalilu
Could you please provide me the full log file and also cat /etc/issue log.
is this a custom image?
This is not a custom image. Installed through toradex easy installer.
Is there any BSP available with vnc server for iMX7D 1GB?
Can we use windows IoT BSP for i.MX7 from NXP ?
It is successful to remote terminal monitoring through SSH also, but only terminal, not GUI.
Hi @asifalilu
No, You have to customize the Linux image by adding vnc server packages(eg:x11vnc ). Please click here for more information on how to add x11vnc to custom Linux image.
opkg update && opkg install x11vnc not working for you??
No, we have not tested.
