Writing messages to docker logs stream
I’ve developed several docker images executing C++ or Python applications on a Verdin IMX8MP with Torizon OS. These applications write status and info messages with the default print calls to the console what works fine in debug mode (debug console). But once I’ve created a production image and execute this image on the SoM I can not access the log information with docker logs as I expected.
What do I have to change for Python and C++ applications in order to write on the docker logs stream.
P.s. at least for Python there are log messages written once I enter an exception that is not caught.
Best regards
KDehren
To ensure your C++ and Python applications running in Docker containers on Torizon OS write log messages to the Docker logs stream, you need to configure them to output to standard output (stdout) and standard error (stderr), which Docker captures.
For Python Applications:
  1. Use the Logging Module: Configure your Python application to use the logging module to send log messages to stdout or stderr. This can be done by setting up the logging configuration to output to the console.
    Example:
    import logging
    import sys
    logging.basicConfig(stream=sys.stdout, level=logging.INFO)
    logger = logging.getLogger(__name__)
    logger.info("This is an info message")
    logger.error("This is an error message")
  2. Uncaught Exceptions: These are automatically written to stderr, which Docker captures. Ensure other log messages are similarly directed.
For C++ Applications:
  1. Redirect Output to Console: Use std::cout for informational messages and std::cerr for error messages. Docker captures both streams.
    Example:
    #include <iostream>
    int main() {
        std::cout << "This is an info message" << std::endl;
        std::cerr << "This is an error message" << std::endl;
        return 0;
  2. Avoid Redirecting Output Elsewhere: Ensure your application does not redirect output to files unless intended.
Docker Configuration:
  • Run Container in Foreground: Ensure your Docker container is running in the foreground, as running in detached mode can affect log capturing.
  • Check Logs: Use docker logs <container_id> to view the logs. Verify that the container is running and the application outputs to the correct streams.
By following these steps, your applications should correctly log messages to the Docker logs stream, making them accessible via the docker logs command.
Toradex AI Assistant
How to log persistent from a application running in docker.
Hi
I think I’m at a similar stage to you (moved from VS Code to actually building images/containers on the Verbin via SSH/shell).
in Python:
I found logging.info() would be visible via:
docker logs container-id
to get print() in to the same output, I did the whole unbeffered thing:
print("message", flush=True)
# Dockerfile:
ENV PYTHONBUFFERED=1
CMD ["python3" , "-u" ,  "app.py"]
hopefully I am answering your question.
Thank you @KDehren and @geeday for bringing up ideas and tagging the solution.
Collin
